What kind of driver will it be? Linear?
Potentially in
Potentially in
Interested!
Interested!
I’m in…if it doesn’t break while sitting in the closet, like my LT1 ![]()
Interested!
I’m still hoping a “Camping” edition of this is released, with red led output lowered to levels acceptable for use at night, and no anduril.
UPDATE: We are pleased to announce that the LT1S Pro will be available this month. It was initially designed to use the 519A LEDs. unfortunately, the final version will be equipped with the Samsung LH351D due to 519A‘s limited availability, it is a bit difficult to procure in large quantities from suppliers. Don’t worry, Anduril UI is set in stone.
Interested, especially if there can be a 519a limited edition, don’t like the low R9 of LH351D.
Same flashing pads as SP10 pro and LT1 mini?
Pretty disappointed there’s no 519A, but it’s out of your control it seems. Thanks for your efforts. The 519A was the most compelling thing of the LT1S Pro for me though, so I guess I’ll be waiting until hopefully supply can be secured and a 519A version will be released. Maybe a small limited edition production run would be nice though?
Hey there, thanks for letting me know about your preference for the 519A version. I meant that obtaining the 519A version is not difficult, but it is a bit challenging to procure the 2700K 519A LEDs. We’re doing our best to make it happen for you. We’ll keep you posted on any new developments.
Yes please use 519a leds. And allow flashing pads
2700k is the best 519A ![]()
Hi Sofirn. Not regarding the LT1S Pro but some of us noticed new lights on your aliexpress store (but not shown on the Sofirn website). It looks like the pages for both models have been taken down, but are you able to tell us anything about them?
SP60 : New Sofirn SP60 thrower using 2S cells
SC02 : New Sofirn sc02.
I think a lot of people would like to know more! ![]()
Can you dedome the 2700k LH351D? That drops the CCT to make it closer to a candle flame and makes the tint less green. But the 519A is better. E21A 2000K would be PERFECT.
LH351D are not as easy as the 519A to dedome, I don’t think a big manufacturer like Sofirn would be able to do it. E21A is also very pretty but low output, I think 519A 2700k with a DIY dedome (around 2200k) might be best compromise between availability and CCT/tint.
Neat!
I’ve been out of the loop, didn’t know it existed until today… and now it’s almost ready to launch. ![]()
It sounds like I should get in touch with @gchart to get the latest version of the code merged in upstream. It would also be helpful to have hardware to test on to make sure I don’t break anything during merges or updates.
@ToyKeeper
I noticed my Wurkkos TS10 has a model number which isn’t in your models.text
0714
Firmware: 2022-07-19 0714
TS10 sent direct from Wurkkos 2023-01-31
I found 0714 on: gabe on launchpad
(I gues it is GCHarts)
It seems the numbers 07xx are for Sofirn/Wurkkos lamps
Maybe @Barry0892 knows more?
Maybe it is a good idea to have the link to Gcharts model.text mentioned in your models.text?
Or a hint like the 07xx models are mostly handled by Gchart?
It’s an auto-generated file which pulls data out of the repository’s build targets to generate a list. I just need to merge changes more often, to keep things more synchronized and up to date.
I‘m interested too!
