LED test / review - Cree XLamp XHP50.3 HI H2 45G (90 CRI) - High performance but severely damaged after short time at higher currents
LED test / review
Cree XLamp XHP50.3 HI H2 45G (90 CRI)​
XHP50D-H0-0000-0D0UH245G
2023-06-24
This test was primarily started due to recent problems with the ultra-bright Imalent SR32. During the passaround of this light in the German flashlight forum, two XHP50.3 HI LEDs were damaged for the second time (after the first repair which consisted in replacing the whole lamp head).
For this reason, I decided to quickly test the XHP50.3 HI to at least determine the maximum possible power and to check to what extent the LED itself could have something to do with these defects that have already occurred more often. I have tested here the 6 V version, in a variant with 90 CRI and 4500 K, because I usually only buy LEDs for testing that I eventually want to install in my own lamps and therefore place little value on low-CRI variants with the highest possible Bin, but in general the electrical performance should also apply to the Low-CRI variants of this LED type.
Technical data
Tj 85 °C, If 1,400 mA
Order code: XHP50D-H0-0000-0D0UH245G
Typ: multi-die
Binning: H2 (900 lm +/- 7 %)
Color kit: 45G (3-step 4500 K)
CRI: min. 90
Rated voltage: typ. 5.6 V (max. 6.2 V)
Maximum rated current: 3,000 mA
Maximum pulse current: N/A
Viewing angle: 120°
Thermal resistance: 0.4 K/W
Max. temperature Tj: max. 150 °C
Datasheet (newest version, Cree)
First appearance
The XHP50.3 HI is a LED without dome (domeless). The 4 LED chips are clearly visible. In the 6 V, 2 of them are connected in series and 2 in parallel (2S2P), in the 12 V configuration 4S.
Noticeable is the luminous area on the top left, which seems to be somewhat “offset”. However, this should not affect the operation of the LED itself. Both my samples show this anomaly in the same way.
This variant is similar to the XHP35/.2 LEDs, which also come with a similar luminous surface, but only in XP format and with 12 V nominal voltage.
The footprint in the 5050 format (external dimensions 5.00 x 5.00 mm) fits on XM boards without any problems, and the symmetrical package means that commercially available XM centering aids can be used. When using commercially available XM boards (such as Noctigon XM20), the LED is in most cases operated in the 6 V configuration, which is also the usualing wiring in flashlights.
The small gray box on the thermal pad indicates the cathode.
At low operating current, a faint glow around the illuminated area is visible, indicating lateral radiation from the LED chips, similar to the older XP-L2 or the XHP variants XHP50.2/70.2. In the test of these LEDs it was determined, that this radiation was the reason for relatively strongly visible color distortions around a strongly bluish spot.
In contrast to the earlier LED platform, this effect is less pronounced in the XHP50.3, which improves the light image. The LED is quite usable in OP reflectors, although there are still slight color shifts between spot and corona as well as (sometimes) spill. For most applications this is not a problem, if this LED is used with a frosted or heavily textured TIR optic, the color shift is no longer noticeable.
Performance and overcurrent
The relatively suddenly reached maximum (12.8 A @ 3891 lm @ 7.72 V) and especially the rapid drop in luminous flux when exceeding this is striking. The Vf is relatively high, but Cree also specifies a relatively generous range up to 6.2 V @ 1.4 A (typ. 5.6 V), which could possibly indicate strong outliers in individual samples.
For a sample with 5.6 V @ 1.4 A, a Vf of below 7.2 V at maximum current is quite realistic.
At the maximum current of 12.8 A, an efficiency of only 39.4 lm/W was achieved; a value that is already sometimes exceeded by special high-power halogen lamps (mostly used for projectors or studio spotlights).
There are hardly any surprises in the comparison chart. Based on the performance compared to XHP70 LEDs, I suspect that primarily the limited heat dissipation area of the XM footprint limits the maximum achievable performance with the XHP50.3, at least if the thermal resistance of only 0.4 K/W actually applies to series samples.
However, something else happened that could explain the LED failures in the Imalent SR32 mentioned at the beginning - or at least gives a hint: the LED tested here has been destroyed while testing. This normally happens very rarely or has to be deliberately done, as it is the case in so-called “crash tests”.
Failure
After the first run (determining the maximum of the LED luminous flux in regular way) the luminous area looked like this:
The maximum current was only maintained for a few seconds, in the range If > 8000 mA this sample was in operation for a maximum of two minutes.
This is indeed an error pattern which already circulated in pictures, also in connection with the Imalent SR32. It should be noted that NO flux residues or similar were found on the light area. The luminous surface was absolutely clean before the start of the test, this was checked before the test, moreover, I never touch the luminous surface with bare hands. In my case, this damage only occurred in the highest power range (above 9000 mA).
It is interesting that this dark brown spot appears on almost all damaged LEDs at the same spot on the LED chip, almost as if a local hotspot was created there, possibly due to uneven heat dissipation. The position of the individual LED chip on the substrate does not seem to play a role. It is particularly noticeable in this image of a review video of the SR32 (min. 26:17).
During the determination of the luminance, the emitter was finally completely destroyed - something that was to be expected considering the earlier damage, although the extent of the damage is nevertheless enormous:
The luminous surface is pretty much burnt in the middle. Of course, this is the extreme case, because in this case the LED was driven to almost 11 A for a second time (after that I immediately stopped the test), but the damage pattern is very similar to the damaged LEDs in the Imalent SR32, where the same approaches are visible.
Failure analysis
To get more in depth with the cause of this failure, I took a closer look at the XHP50.3 HI LED tested here and damaged in the process.
First, I tried to get the black undefinable mass from the luminous surface. Interestingly, there was still undamaged phosphor underneath. This alone is a sign that we are not necessarily dealing with an overheating of the LED chip. At least the burn did not extend down to the LED chip, which should confirm the good heat dissipation of the LED chips – the source of the heat is likely not coming from the LED chips itself.
I can’t exactly explain why the LED was so catastrophically damaged here. It seemed as if the silicone was burned by too high temperatures during massive overcurrent. Only - by what? There were no dust or flux residues on my LED. I would have seen these, especially on the smooth white surface of a HI-LED.
Considering the de facto identical damage of the LEDs in the Imalent SR32, this cause could be identical. At least a burn of the silicone by overheating of the LED chips is excluded, rather I assume that the extreme light flow in the silicone itself was the cause for a massive heat rise.
Whereby there are more interesting things like the already documented “dark spots” at almost the same places on the LED chips. This dark spot also occurred in my case, although it was a bit more visible. Starting from this dark spot, the massive burn may have originated at the end and then spread further.
One theory could be that the silicone is thicker or less permeable to light at these points due to some circumstances and that this creates local tiny hotspots, which burn the silicone starting from a certain luminous flux/operating current. Since dark residues are created by the combustion and these in turn heat up massively due to the extreme luminous flux, they burn further silicone, which again creates dark residues and so on.
This could explain the error pattern so far, but the actual cause for the dark spots remains unclear.
A more yellowish discoloration of the phosphor is noticeable at the spot where the dark spot was created later. These discolorations can be seen more or less symmetrically at the same places of the respective LED chips, pretty much at the same places that can also be seen here (screenshot YT video review SR32), partly on several LED chips of one emitter.
For me, this speaks against the contamination of the LED surface by flux splashes or darker dust. In such a case, the dark burn marks would have to appear more or less at random places, since the distribution of dust or flux is also subject to chance. In addition, when LEDs are reflowed - especially on an industrial scale, as is likely to be the case at Imalent - so-called PCB stencils are used.
These are thin stainless steel sheets with precisely milled openings in order to apply solder paste to the PCB as precisely as possible and according to very precise manufacturer specifications in precisely defined quantities. Among other things, these manufacturer recommendations are also designed with regard to avoidable contamination by flux, which makes me think that this cause is very unlikely in the case of the SR32’s defects.
I only have one XHP50.3 HI left in stock and would hate to use it for another test, as it was originally intended to be, or still is, for a lamp conversion.
However, it seems to me that there is not “the one” cause for this error pattern here. What is striking here, as mentioned, is the relatively constant error pattern with very similar location of the cause of the error (dark spot).
This is how the XHP50.3 looks without silicone encapsulation and phosphor. The four luminous surfaces are conctated via flip chip mounting on the underside, there are no bonding wires.
At first glance, the LED chips did not suffer any damage. At least no (heat-related) damage is visible.
The chips light up without any problems at a few mA. The bright appearing lines between the chips are phosphors, which I could not remove.
And here also confirms what I already suspected: the LED chips also emit light to the side.
This explains the weak glow even directly next to the luminous surface. This effect was first noticed with the XP-G3 and XP-L2 LEDs a few years ago.
In general I strongly recommend being very careful with overcurrenting the XHP50.3 HD and HI (both LEDs differ only in the applied dome) to extreme levels and generally advise against it due to the damage pattern that occurred. Presumably, the series dispersion also plays a decisive role at which current and which temperatures the failure shown above can occur.
Extreme temperature test
To be sure what the XHP50.3 HI can really withstand and what damage would look like if the LED chips overheated, I ran an extreme temperature test.
Before that, however, I let the LED run continuously for fifteen minutes at 21 A (power supply maxed out) and 8.711 V Vf (power: 182 W!) with as perfect cooling as possible. This already showed the robustness of the emitter, because obvious damage was hardly visible afterwards:
Only a small burned area can be seen between the two lower luminous surfaces. However, this did not affect the function of the LED chips. Possibly, this area comes from the burning of the silicone left in the small gap between the LED chips or other foreign objects.
The overtemperature test was performed up to a temperature of 280 degrees, which was monitored with a thermal imaging camera. (Note: Tjmax XHP50.3: 150 °C).
Even at 280 °C the chips still glow! (Snapshot from video recording)
Everything is already smoking here, including the LED board used in the test. Whereby here a LED chip is close to failure, on the other hand the robustness of today’s LEDs in general is very impressive, as these operating conditions are far above what the manufacturers generally state as the maximum temperature of the LED chips.
The result after the extreme test:
The substrate is darkly discolored, and some of the LED chips were very easy to remove (they were still attached to the substrate however). Any damage to the chips was only from the removal process. The chips themselves were still in place before removal.
In summary, from the LED chip side the XHP50.3 is an extremely robust emitter that can withstand even 20 A. In this regard, it is in good company with the XP-L2, which withstood nearly 15 A before destruction. So the failures in the Imalent SR32 have likely nothing to do with overheating of the LED chips, but are due to the silicone or the contamination of the surface (although this is rather unlikely, as already explained).
Color and light quality
The light color of the XHP50.3 HI tested here is okay. The duv is a bit higher, but subjectively the light is usable without slipping too much into hues.
With an Ra of 92 and R9 of 66, this is one of Cree’s much better LEDs when it comes to color rendering. However, the XHP50.3 doesn’t stand a chance against a Nichia even in the 90 CRI variant; the duv of 0.0053 is immediately noticeable in direct comparison; the light appears greenish and the colors are accordingly not as saturated as it is the case with the Nichia and also the LH351D.
I could not perform more precise tests due to the destruction of the emitter, my second sample may deviate significantly from the above values despite tighter 3-step binning.
Conclusion
Pro
  • compatibility with XM accessories given
  • relatively good tint and CRI values
  • high power and luminous flux
Neutral
  • relatively high Vf
Contra
  • destruction of the emitter clearly before achievable luminous flux maximum
  • operation of the emitter only with nominal data or very careful overcurrent recommended
I hope this review was helpful for your next moddings. :slight_smile:
Greetings, Dominik
21 Thanks
Thanks for the test.
Two of the XHP50.3 HI out of 12 I have have a dark spot under the silicone, it seems evident to me that the phosphor would start burning around these spots when overdriven. I don’t know if yours had one, but even if there was no spot visible, there might still be some irregularities since they clearly have some manufacturing/QC problems.
Not the phosphor itself, I think, but the silicone layer above it. Maybe the dark spot is inside the silicone layer.
Because after removing the burnt residue from the silicon top layer, the phosphor was still intact (in the images the blue spots were due to too harsh removal).
Maybe. In case of the Imalent SR32 (which was the reason to spent so much time with failure analysis and testing) I think, that the LEDs were too warm despite active cooling also too hard overdriven, what results in damages which were (I think) much more often than expected…
Ah ok, i thought it was from the picture. Anyway it’s difficult to see if the dark speck are in/on the phosphor or in the silicone on my two samples, maybe they’re in the silicone.
Edit : I forgot to mention it, but these two LEDs are new/not used.
Yes, it is difficult to see this.
In any case, it seems that the damage of other XHP50.3 HI LEDs happens more often than it should. Can you make some close-up pictures of your damaged emitters?
I failed to mention it, they are new LEDs still in tape, that’s why I said it’s a manufacturing/QC problem.
Then it is even more interesting to see some pics! Otherwise the tape is not clear, but more opaque and so details are not as visible as if they are out of the tape.
I’ll try tomorrow with better light because I can’t seem to take a good picture now.
No problem :slight_smile:
Can you pry a LED out of the tape for the pic? (You can put it back afterwards and close the tape with some adhesive tape, I do this often)
Of course, it’s already out of the tape.
Fairly thorough destruction testing there! Excellent stuff
As i was reading through it made me think of heat measurements, but then you put it under a thermal camera.
I wonder if something like the infiray cameras they use for pcb review would work in this case. One of them has a stick on macro lens and it would be interesting if you could see the dies warming, or possibly warming inconsistently.
I think so. I don’t know which model you mean, but even my less expensive thermal camera can detect the temperature of the LED chip. If you can get a sharp image of the LED from nearby with the macro lens, it should be good. Only thing you should keep in mind is that the heat coming with the enormous light flux at highest current is very high and could make measurement difficult due to heating of the camera and the sensor itself.
Thanks for doing this testing and presenting it here. It is thought provoking.
Your data would suggest that the LED failures in Immolate’s SR32 are caused by overdriving the LEDs to ~400% of the maximum current rating, and then blaming Cree for QC problems.
If they want to blame CREE for QC issues, they better be driving the LEDs in the SR32 at their rated current, not multiples beyond.
The 90 CRI variant may perform differently than the low CRI variant. The phosphor layer being thinner (and of a lighter color) should not get quite as hot on the low CRI variant.
Being a 90 CRI LED, the tested LED has a thick phosphor layer, and unlike some high luminance LEDs which don’t appear to have a silicone top layer, the XHP50.3 LEDs do have a silicone top layer. Phosphor can withstand high temperatures iirc which is why lasers can be aimed at them and white light produced, but silicone, not so much.
The LED apparently fails because it’s driven to a level that causes the silicone to burn.
  • There’s very little output to be had beyond 9A and it comes at a substantial loss to overall efficiency, which is to say it’s mostly heat. To get to 12A, it’s an extra 30W for just 400 lumens gain, and mind you, this LED isn’t even rated for 30W.
  • 400% overcurrent is way beyond max spec. That a failure at this drive level comes with the recommendation for a “very careful overcurrent” is funny, but misleading.
Maybe not 400 % or 12 Amps, but at least 7-9 A per LED; at least if the stated 120,000 lumens are really reached by the SR32 (every LED has to deliver 3,750 lumens which is quite high even for highest-binned XHP50.3 HI) and 6 V config was used. This is - consider the count of emitters in this head - still a critical thing in terms of heat, dissipation and of course local temperatures / hotspots of the single emitter itself.
Maybe. I don’t know how thick the phosphor layer of the XHP50.3 HI 90CRI really is and if there is such a big difference. I am also not sure that the phosphorus layer is the cause for the failure and subsequent damage.
The strange thing is, that this did not occur while testing the XHP70.3 HI, which goes up to 20 A without damage. It seems that there is a very specific problem with the silicone layer at these ultra-high currents, but I can’t say for sure what is the real cause for this.
Not really. Overcurrenting has always to be done very carefully (and you have to know what you’re doing), but in this case it might the best to use the LED in the intended power range or with mild overcurrenting (4-5 A).
If we were to rate purely on overcurrent, either these tests would not exist here (without overcurrent there would simply be nothing interesting), or many enthusiast lamps would not exist either. That Imalent has gone too far with the S32 is possible. But if overcurrent must be avoided, then a whole area in flashlight technology is up for debate.
Whatever it actually is, hopefully the problem is resolved soon, maybe Cree got a bad batch of silicone.
Is there any possibility of also testing the HD version to see if it also has the problem with dark spots? Maybe sliced 50.3HD ends up as a better alternative to HI.
Let’s ask provocatively: why? Cree has released the XHP50.3 for a maximum current up to 3,000 mA (6V variant). Up to this operating current, Cree guarantees the life specification and reliability, and to some extent guarantees its product to meet the specified parameters. As long as not row upon row of LEDs at the official maximum current break, I see little reason for Cree to somehow take action due to these defects at massive overcurrent.
It is still important: the operation of LEDs outside the manufacturer’s limits does not fall under any warranty, there are no empirical values for this, it is ultimately operation “at your own risk”. No more and no less, Cree will simply say “you have operated the LED improperly / outside the specifications” and that’s it. And you can not blame them for this. Only the operator of the LEDs (or the lamp manufacturer) is responsible here, not the LED manufacturer.
Even if it turns out that sliced XHP50.3 HD seems to perform better at highest current, since I cannot test hundreds of them it is still not clear if in general this ‘workaround’ is better. Trying to determine this on the basis of a single LED test with only one sample does not work due to a lack of sample size.
I couldn’t manage to take good macro shots so I took pictures through a cheap microscope.
4500K 90CRI from Mouser, defect that was present out of the tape :
New spot that wasn’t there initially (the LED mounted on a heatsink was used on my bench for testing drivers, driven up to 6~8A)
Now that I’ve taken a closer at these spots, they look indeed to be in the silicone, not the phosphor.
New 3000K 90CRI from Kaidomain :
The darker spot in the middle is much more pronounced to the naked eye, easy to see at first glance.
Since dark colors have strong absorption and convert most of the incident energy into heat, a defect of these emitters is likely at higher operating currents.
At first glance, it looks like foreign bodies in air pockets (especially in first picture), but I’m not really sure. It could also be some residue in the silicone that have a minimally different light refraction or higher opacity and thus absorb slightly more light than the silicone itself. With the high light flux in the smallest space, this minimal deviation in the optical properties could well be enough to cause local overheating or even burning of the silicone. Once dark spots have formed, the complete destruction of the silicone can hardly be stopped without switching off the LED or setting the operating current much lower…
How long was this LED operated at which currents?
I don’t know exactly, maybe a few 10-20s bursts at 8A, 30s-2min at 6A, like 30-50 times.
