2026-10-25
UPDATE: Close-up images of the disassembled LED chip can be found here!
- Type: lateral, quad-die
- Bin: G3
- Color group: FA3 (4000 K)
- CRI: typ. 95
This LED tested here was bought from Kaidomain in 06/2026. It is labeled as “G3 FA3” for binning.
SFT-70 tested earlier had a metal frame around the LES, which holds the white silicon molding. This was changed to a white (silicone?) frame in this version, likely to save costs. This indicates a slightly changed production process.
There are bonding wires visible, although these are completely by white silicone. Bonding wires are likely to cause higher Vf compared to LEDs in flip chip design.
The SFT-70 fits on standard 5050 boards, like the earlier variants. With changing the solder pad layout, a 12 V config is possible. On standard boards, only 6 V is possible.
(Please note: the image of LES was taken from the LED after testing up to 5 amps where I interrupt testing to assess damage. There is a small burned area which was not there before testing. So no damaged or dirty phosphor was already there right from the factory.)
- Maximum reached at 6.6 A, at this point 2118 lm @ 6.66 V
- Power at maximum 44.0 W
- Efficiency at maximum 48 lm/W
The SFT-70 4000 K 95 CRI tested here performs way worse than the other SFT-70 I tested, especially in terms of maximum current. With only 6.6 Amps the current is much lower than for cool and warm white SFT-70 alike, which topped out at around 9-10 Amps.
The slightly higher efficacy compared to the 3000 K variant is expected, since the binning of the 3000 K is even better (G4 compared to G3, although I don’t know how consistent the batches of these warm white SFT-70 are since May 2024).
Since the LES is exactly the same, luminance is also basically identical to the 3000 K variant, maybe some percent higher.
More problematic is the destruction of the emitter tested here. At around 5 Amps it started smoking, at maximum current of 6.6 Amps it smoked even more, and at around 7.5 to 8 Amps is was burned. The phosphor mix burned, which is “clearly” visible.
I would not recommend to drive the SFT-70 4000 K 95 CRI with more than 4.5 Amps. Maybe my sample was faulty in terms of thermal resistance (was the thermal image with the huge difference between chip temperature might suggest - 225 and 168 °C at 6 Amps is way too hot), but since I only one more sample left which is intended for another emitter swap I cannot confirm this.
The tint is very neutral and matches exactly the stated CCT. The CRI is very high.
There is a multi-phosphor mix used which fills the cyan gap quite well, which is likely done with BSON phosphor. Maybe also a mix of LED chips with slightly different peak wavelengths or modified chip is used.
From BSON aside, LuAG, YAG:Gd (maybe blend with SSN) and SCASN phopshors are likely used as well. The tint shift is low and is almost not visible, which is a huge improvement from earlier SFT-70 with very clearly visible tint shift.
- Ra: 95.5
- R9: 97
- CCT: 3992 K
- duv: -0.00169
The light quality is great, beam profile is good, and it fits on standard 5050 footprints (6 V only). But it’s performance is not as good, especially considering the low maximum current and the risk of burning above 5 Amps.
Keep in mind, that I was only able to test one sample, maybe there are better performing SFT-70 from other or same batches out there.
Apart from that, it is a nice emitter for using in flashlights.
Thank you for reading this test. ![]()
