I want to make on topic with my boards I have shared on Oshpark
The updated TA drivers are still pending as I want to test them before they get public
All build drivers can be bought in my sale topic or PM me
Q8 (12mm) side switch boards
order those in 2oz for right thickness
2x2 LED with balance resistors
MF01/MF02 (11mm) side switch boards
Lighted tail switch board replacing the washer around the switch
For the exampke pink and warm white, other combinations possible the board with balance resistors could use more than 2 different colors
17mm
https://oshpark.com/shared_projects/yplKNhqL
16mm
17mm
https://oshpark.com/shared_projects/aqiAxQx1
20mm
https://oshpark.com/shared_projects/fWtrkfax
17mm Remote switch tail board with FET
16mm
https://oshpark.com/shared_projects/F096lqpK
for Osram IR emitters with Anode on thermal pad
Osram DTP driver Tripledown (TA Bistro/Bistro HD OTSM 3 Channel compatible)
Inverted Biscotti single channel
TA and Triple Board designs
15mm
new board . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . old board
17mm
20mm
21mm
22mm
Made a 38.5/40mm design on my own, working in 3P or 4P hosts, 1S and 2S availiable
SRK board with fixed ground ring issue
SRK/Q8 Tail board 2S/2P with switch
TN40, TN42 TA 2S/2P
not tested yet
