I don’t think that would work, unless you wanted to do a quasi-direct drive with it? If not, you’d need a constant current driver, which might be difficult to find in the desired voltage range and current output. If your host can fit it, it would be hard to beat an H6flex, which will put out up to 6A (I think). Pricey though and relatively large at 40mm or so.
I know one of the modders with a lathe needs to buy one of the 100mm aspherics and make a head for it, for the MT-G2. Put the head on a Maglite and Make it a real thrower.
Unfortunately those multi-emitter LEDs and asphereics don’t play well together. You wind up projecting an array of dots. You could use a diffuser or defocus the lens, but you lose throw and light.
You’re right, but from all the pictures I’ve seen, it looks like the MT-G2 has a single die (and a massive one at that ). The previous version of the MT-G however, had multiple dies, which would cause the effect you mentioned.
Everybody with me now!: De-dome! De-dome! De-dome!
I don’t know if it’ll work or not. It appears to limit the voltage to 5V or 6V depending on switch setting, and current max is 3A, but my question is, will the LED attempt to draw more through the thing and just trip the overtemp circuit?
Edit- Just looked and found this PDF Manual and it looks to have an overcurrent protection at 3A. Would I be correct in assuming it would just hit that and trip immediately?
I agree but i want actual comparable lumens, if you say lumens it should be lumens, ceiling bounce and reflector should either be corrected or stated as lux
