UPDATE 6/1/2016 I posted a tint thread showing these hosts’ tints with various LEDs here: Dedomed LED Tints Compared: XP-G3, XP-G2, XP-L
This is a group-buy purchased by me which I will distribute within the 48 states.
These are brand new-in-box arrivals. O-Light M3XS-UT-G2 Javelots. Factory dedomed XPG2 S2 1A emitters with neutral tint (no more green!), 350kcd spec (vs only 250kcd for the standard dedomed XP-L version).
Full factory carry-case kit with holster, 2*18650 extension tube, CR123 spacer sleeve, O-rings, and instructions.
O-Light improved the MCPCB on these with a solid copper DTP board that is about 1mm thicker than the original M3XS-UT Javelot MCPCB was (much thicker and more massive than a Noctigon 20mm). They also machined the reflector base and host interior on these to adjust reflector depth/focus a bit over the original M3XS-UT Javelot DD XP-L model.
Battery capability: 2*18500s or 3*18350/16340/CR123-primaries in short tube config. 2*18650 or 4*CR123-primaries in long tube config.
-Side button switch illuminates RED to show when the batteries are at roughly 10-15% capacity.
Price is $130 + $6 USPS flat-rate insured shipping within the US 48 states.
* IF interested, I will open the light and install a dedomed XP-L V6 0D, 1A, or 3D, or a dedomed XP-G3 S5 emitter for additional $12. All outperform the factory XP-L by a considerable margin, and the V6 is the highest XP-L bin available.
*This is a limited run light, not a new model.
PM to make your order confirmation; I will reply with my Paypal address, or to any other questions you may have. First come, first serve. ![]()
Thank you for enjoying photons! ![]()
Original XP-L @ 250kcd below
With dedomed XP-G2:
