UPDATE 200802: Color Mixing PROBLEM
UPDATE 200703: Progress
UPDATE 200613: Progress
UPDATE 200526: Progress
UPDATE 200329: Packet shipped from Shenzhen in 200325. Should be here in approximately 7 days. But due to limited activity allowed in Bali, I can not promised anything earlier than 200406 (end of Bali’s soft lockdown).
UPDATE 200303: Order placed to Skilhunt, EXPECT delay. I’ll update the shipping and delivery time later.
UPDATE 200217: China holiday extended to 200224 due to health and safety concern of corona virus outbreaks. GB listing reopened until the factory go back to normal operation.
UPDATE 200201: OK, thanks for all the participants =)
The Virence Skilhunt H04RC is now ended. I will start to place the order to Skilhunt on monday. Any new orders is subject to normal pricing PLUS shipping (you can find it later via my store).
UPDATE 200129: GB Interest list will be closed on 200201, 00:00 GMT +8
Thanks for all the orders guys, I decided to close the interest list soon so I can start making the lights. Looks like waiting for 200pcs order would be too long. For those still undecided, you guys can get it later via my store.
Regards,
Clemence
Original Thread
OK, I’m ready to take orders. Below is the output and partial runtime using 3500K D220 R9080 E21A. More thorough test by Maukka, check HERE.
Here’s what you get outside the normal OEM accessory:
- 16mm medium microlensed TIR optic
- 16mm medium-wide microlensed TIR optic (default)
- 16mm wide microlensed TIR optic
- 16mm oval microlensed TIR optic
- Quadtrix E17A/E21A LED module (installed)
Features:
- Very high CRI of R9080 minimum guaranteed (For all CW and WW E17A and E21A, except for 2200K which is R9050 minimum)
- Available in wide variety of CCT: 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, and 6500K. All in very high CRI.
- Sensible, fully regulated, and dependable output levels
- Longer regulated runtime
- Due to very low forward voltage of Nichia E series, combined with 4P setup, this headlamp works with almost any 18650. No high drain battery needed to get max output.
- Highest mode can be restarted multiple times with very little output reduction in each succession. OEM LED suffers heavy output reduction with multiple highest mode restart.
- Four different optics to choose included
- Better reliability and consistent performance with two mounting screws for the MCPCB. Threads are deep and roll formed.
Out the front output with 3500K D220 R9080 E21A using widest optic:
- Mode 1: 0,19lm
- Mode 2: 2,16lm
- Mode 3: 8,95lm
- Mode 4: 30,13lm
- Mode 5: 65,92lm
- Mode 6: 174,64lm
- Mode 7: 256,52lm
- Mode 8: 562,26lm (2 minutes step down to mode 7)
With OEM XML2, the highest mode behaves like direct driven (unregulated), the output follows the battery voltage. After each step down, max output restart will be significantly lower. With E21A you can have multiple max mode restarts with same max output.
Price: $75
Click THIS link and add your order as comment there. Don’t try to edit the Gsheet, it’s locked. You can only add comment, I will edit the list accordingly.
25 ,26 first order will be ranked according to the received payment date. Paypal the payment to: clemenceronald@gmail.com
Order will be placed to Skilhunt as soon as 200pcs order reached they’re back operational (almost all factories extend their holiday due to corona virus outbreaks).
Regards,
Clemence
