I received a Palight GS2600 flashlight today. Gearbest sent it to me for review. By now, you know what that means... A long drawn out review that takes forever and simply says, "It could be better". Pessimistic me? Yep.
The light is listed on the Gearbest website for $83.72 USD.
Here are the specs according to Gearbest, which seem fairly correct:
Main Features:
● High power CREE MTG2 LED, max output up to 2600LM
● User-friendly night light design, avoids accidental activation
● Infinitely variable brightness system, last used brightness will be memorized
● When in the highest brightness, long press upper button to enter strobe mode
● Waterproof charging port, with charging indicator light
● Waterproof accords with IPX-6 standard, against water jets from any directions
● Built-in battery protection board ensures the batteries' safety
● Stainless steel switches, tail on / off switch, side dimming switches
Caution: Can not fit batteries with protection board (diameter over 26mm). Please install the battery in the right position and cover the tail cap carefully
Operation:
Tail Switch:
● Single click to activate tail night light
● Long press to turn on the flashlight
Side Switches:
● Upper button: Increase brightness
● Lower button: Decrease brightness
Indicator:
● Red indicator informs low battery capacity
● Blue indicator goes out when charging is completed
Battery:
Type: 26650
Capacity: 5600mAh
Voltage: 3.7V
Charging current: 500mA
Discharging current: 3000mA
Charging time: 16h
Specifications
General |
Brand: Palight |
Specifications |
Power Source: Battery |
Dimension and Weight |
Product weight: 0.680 kg |
Package Contents |
Package Contents: 1 x Palight GS2600 LED Flashlight, 2 x 26650 Battery (3.7V 5600mAh), 1 x USB Cable, 1 Pair x Gloves |
Here's the full review, which has been shortened considerably:
www.youtube.com/embed/cTcrWu71SLE
Here are photos of the driver. I am looking to see if I can just change a resistor, to up the power:
My thoughts:
The Good:
Well constructed, good fit and finish
Small led on tail for finding the light
leds for battery state
Almost step-less dimming and last step memory
Hidden strobe
The bad:
Body and head "O" rings too loose and get pinched/damaged
Tail cap switch is redundant and hard to press/hold
Price is a little too high
Overall: I really like the feel and weight of the light and with a little modding of new O rings and a little more output, I would be happy.
Many thanks to Gearbest, who provided the light without knowing if I would like it of not and also for the giveaway that they just sponsored, by sending this light to me.
04/30/16
Now for the MOD!!
XHP70 High CRI led and the driver mod.
I love the XHP70, even with the dreaded dark + sign of death in the center, due to the split in the 4 dies. I still love the amount of light one led gives out.
The XHP70 is on a 20mm star, but that doesn't clear the reflector. The stock MT-G2 was on a 30mm star, so I had to get the wires outboard of the reflector and keep things low. I did it by using copper strips to move the wires out and away from the center of the reflector.
Now there is plenty of clearance for the wires and the reflector still sits low on the star.
Remember the two "Pins" sticking up out of the stock mcpcb? I thought they were locating pins, but they were screws that were screwed in backwards into the led shelf. Why I don't know. They were designed to hold down the mcpcb, but they weren't used for that. Now they will be used for holding down the new mcpcb and I also had to drill out the wire holes, since I went with 20ga wires.
A little thermal paste...
Star is now screwed down and everything is set.
I went ahead and bridged for the resistor here, to up the amperage for all it can do.
I assembled the light and tested it. The dreaded black + was there in full force. The force was strong with this one, so I went back and sanded the dome of the led.
But, as I said, the force was strong enough that even with the sanding, there was still some of the dark +, so I stippled the reflector too!
and that's the mod for the XHP70. Now the beam is smooth as silk and the spill is brighter and smoother too. That's the way I like it.![]()
Beam shots tonight!
EDIT: I received a question from my YouTube channel about Gearbest and how it is to deal with them, especially they have gotten to be a bad taste for many people and my answer is:
It's like any other vendor. They can be real good or real bad. What you have to do with any of them, is to wait to place the order, till after you work out the agreement that you seek. Most items are not in stock at the seller's location. They are just selling things that someone else has and they often drop ship, so the seller never sees the product they are selling. If you want to only buy items that the seller has received and handled themselves, then you must specify. If you want the seller to inspect the item and say you do not want scratches, then tell them you will not accept any or the item goes back. Tell them exactly what you expect and make sure you are willing to back up your end, by returning the item, (at your cost), if they do not fulfill the contract. If you do not want to go to all that trouble, then you are at their mercy and it will be hit or miss. It's all in how much you are willing to put into the pre-order work.
I feel that none of the sellers fall outside of this category. It's hundreds to thousands of miles from buyer to seller and it only makes sense to treat a prospective business partner as one who has to be questioned about everything, in order to maintain one's own investment. As has been said before, buyer beware, especially over long distance. Gearbest, for me, is a valid seller, if proper precautions and questions are used before hand. Hell, I still think even Wallbuys was ok, if you worked with them before hand, even though their practices were questionable for me, they obviously weren't for them. Different cultures, different strokes... Tmart, was always the worst for me.
