(Click pics for full-size)
The Packaging/Accessories
The light comes with a very nice holster, a lanyard, two extra O-rings, and an extra gasket for the switch. The light comes wrapped in a satin-like plastic bag, then in the holster, then in the pictured box which has more foam on the inside. My sample was provided by Thrunite through their Amazon store, so it was then in a separate cardboard shipping box with air shippers.
The Construction
This light is about what I expected it to be: high quality. The finish is not shiny, but also not rough under your finger. I like it alot. I could not see any flaws or machining marks poking through. The only sharp edge is on the lanyard cutout, which you can see in the top picture. The knurling on the battery tube is on the aggressive side, which is good because there isn’t any knurling on the head at all. The bezel appears to be SS with a bead-blasted finish. The lens is AR coated and both it and the lens are immaculate. No dust or smudges inside (until I opened it up myself). The switch surround is pronounced so it is pretty easy to find, but the switch itself is level with the surface so an accidental activation would be rare. The base is flat so it tailstands perfectly, even with the lanyard attached. The battery carrier is also very nice; polarity is the same on both ends. The LED is mounted on a very thick copper MCPCB, not sure if it’s DTP or not but that doesn’t really matter at these amp levels.
The dimensions are:
115.4mm long x 45.6mm wide
The reflector ID is approx 34.5mm
Here is a comparison with the Supfire M6, EagleEye X2R (same size as Convoy S2+), and an SK68.
The UI is as follows:
From off:
Click and hold: Moon
Single click: last mode memory
Double click: Turbo
From on:
Click and hold: jump to low, then ramp up through L > M > H > L > M > H etc
- So if you are in Medium and want to go to High, you will click and hold. It will first jump down to low, then ramp up from there.
Single click: off
Double click: Turbo
Double click from Turbo: Strobe
Moon, Turbo, and Strobe are not memorized. So if you start the light in Medium, then double click into turbo, then click off from there, the next time you turn it on it would go to your last used “normal” mode, which was Medium.
Input Current: This was measured with my power supply giving 5v to the stock driver, with my DMM in series to get the measurements.
Moon: 1ma
Low: 28.1ma
Med: 200ma
High: 0.92a
Turbo: 1.47a
Strobe: 0.62a
Output Current: This was measured with the power supplied by the stock battery carrier, and my DMM directly in series with the LED.
Moon: 0.68ma
Low: 32ma
Med: 250ma
High: 1.26a
Turbo: 2.49a
Strobe: 1.14a
Performance:
Overall I think it’s quite good, especially for a light running on AA’s. The properly focused reflector partnered with the XP-L HI makes for a nice focused beam. Other than the typical Cree corona, there are no artifacts to speak of. The fact that you can’t go directly from Medium to High is weird, especially for anyone who has used the Olight UI before. If this was the first UI you learned, it wouldn’t be hard to get used to. This would be a great light for someone who wouldn’t do well with Lithiums, or someone who just doesn’t want the extra investment. The tint on my sample was Cool White. It isn’t as cool as others I have had, I’d guesstimate it is closer to 2A than 1A. Props to Thrunite for also offering it in Neutral White. There is battery monitoring with an indicator in the button. Blue for ok, Red for low, Flashing Red for very low. I’m not sure how reliable it is though, at one time it was flashing red on just-charged batteries.
Mod Forecast: Sunny
Nothing on this light was glued, it all came apart easily. There is a solid shelf under the LED, and the E-switch is on it’s own PCB. An emitter swap would be easy, though I suggest using the stock MCPCB since it is thicker than normal and it looks like there is a thermistor mounted on it. An XHP35 mod with 4S 14500’s would also be interesting.
Recap of the cons:
- The switch bump is the only anti-roll portion of it, so it will roll 80% of the way around before stopping.
- The sharp point on the lanyard attachment hole
- The UI isn’t perfect, but not awful either. It’d be nice to not step down to Low before ramping up every time.
- The battery level indicator seemed finicky, but it could just be my old Energizers causing that too.
You can buy it directly from Thrunite using these links. Thrunite Direct does accept Paypal.
ThruNite Official Store: (5% OFF Coupon Code:THRUNITE , limited time!) http://www.thrunite.com/
Amazon US: Amazon.com: ThruNite
