In the end I ordered m2 host and it came in extremely fast. My first time soldering anything in my life went extremely smoothly. Thanks remang I used your advice. As for focusing led, in the end I tried a dew different spacers. ( Thanks RMM) the one that came with the light is what I ended up keeping, it gave me the best beam I feel, thanks Wight I used your method. Over all extremely successful. Now I am waiting on the m1 and I may mod a c8, and s2+ tan edition. What have I started…. hahaha
After all of the questions I have been asking, I have received some great help and info.
I am planning my first build. I want to make edc convoy m1 for my back pocket.
I have another question though. Do I need to buy the spacers for xpl or the butterfly spacer xpl?
I plan on using 22g silicone wire.
Mtn 17ddm New updated version fet +7135 guppydrv firmware
17 mm Forward clicky from mtn
Arctic silver under led mcpcb. Mtn
Cree xpl hi U5 on noctigon Mcpcb mtn
4 feet mg chemical 63/37 lead .025 mtn
1 30Q mtn to power this bad Larry.
I also outt two qlite rev with guppydrv in for my c8 and my s2+
Does this seem like a good edc? Can this set up handle the driver I chose? I have my cart ready to check out, just need to be certain
Most important, kapton or electrical tape over your positive lead on the LED board. I have lost a couple of drivers and switches due to shorting the + lead to the reflector. The reflector is essentially a ground or a direct short across the LED if it hits both leads.
Kapton tape is thinner, but regular electrical tape does well too. Even with the spacer for the LED, your soldering may not lay flat enough and can make contact, safe practice to cover it. I seem to regularly forget this, but I feel OK helping to send Richards kiddies to college with my mistakes…
That is great info. Thank you! I actually put a roll of kapton in my cart, it looked important. I just didn’t know how to use it.
I may end up doing driver swap in the c8 first. I would hate to destroy the fet driver. Cheaper to mess up qlite =/
Go slow and enjoy the build Jake… There are plenty of pitfalls, the one I listed about shorting the driver with the reflector has been the most aggravating to me. The build is almost done and perhaps tested… Then pooof, the whole thing is a reset. The last one I had happen was an aluminized plastic reflector, I did not think about that one… Toasted a 3A Qlite with moppydrv…
The S2+ has the threaded pill that makes putting the thing together a bit different. I usually put a finger through the front (wear disposable nitrile or latex gloves) and press on the lens and reflector assembly while screwing the pill back in, keeps a lot alignment issues minimized.
My C8’s have all been different enough builds that I did not have the same issues in any of them. The XPL HI in the C8 I had to focus by using just Kapton tape to insulate the reflector and putting it against the noctigon…
But it won’t center the LED in any sized reflector. That butterfly one is specifically for use with XP- sized reflectors. With XM- sized reflectors it will only insulate, not center.
In fact, I believe that the M1 includes a special centering ring / spacer. If this ring focuses correctly you have two three options:
The M2 has a centering ring for XML. With a XPL or XPG it will center with a little shaking and trial and error. The corners of the XPL will line up with the center of the flats on the XML ring.
2 squares smaller one in the center turned 45 degrees .
The light is not what is made for a specific LED, the reflector through hole is. The M1 reflector has a hole big enough (designed for) a X*M*L sized LED (5mm x 5mm ?) and will fit the smaller X*P*G and X*P*L sized LED’s.
Your larger XML centering ring will also fit the XPL HI just fine with a little patience. You will see it when you go install it. It will look like a square inside a square, or a diamond shape in a box…
Maybe others can chime in here but I found the forward clicky from Mountain to be to tall to fit the M1. Likely can be modded somehow but I’ve never tried. Once I got used to reverse clicky I decided I liked it better anyway.
I can visualize the diamond in box now thank you.
If the switch is too tall, is there another one that will fit? The one I already ordered can probably go on a c8
The one linked above is the one I have, more than sufficient. Heats fast and holds temp well enough for anything I have done.
My one hint for this station, especially when soldering leads to Noctigons or other heat sucking items, Use the biggest tip you can, this transfers the heat better. I think you said you have a ten pack of tips coming, if it is the mixed tips, use the one that looks like a rod with an angle cut on it.
I just flux with a toothpick the noctigon and put a small blob of solder on it, then flux the pre tinned wire from the driver…. I put the wire on the solder blob, and push down on the insulation right next to the solder blob. I then use the angle cut tip on a hot setting and press the wire onto the solder blob with it. When the solder melts, the pressure from the push down on the insulation makes the wire sink into the solder blob. Lift the iron away and then a few seconds later when the blob has solidified, take the pressure off the wire on the insulated part.
Cant wait to hear of your success with your build! Perseverance may be needed, but stick with it!
