Ok guys I am going to start NEW production of copper pills, this time no limit in number of them, and the price will be 23$ for Europe,and 25 for the rest of the World . Price include shipping and tracking number. Please let me know how many of you are interested this time . Special PayPall account for this sale is couruiD01bighead@gmail.com
Awesome news, thanks Nikola! I will definitely be in for at least one.
Again, if you’ve got the patience, a slightly custom one like last time. Got another Courui on route for a new project and it desperately needs some copper
I’ll send you a PM soon.
Awesome news… A friend saw my modded courui in action and I had to sell it. With this new one I will use 32mm instead because of the flat reflector base, it did not sit all the way down with a 20mm board…
Is there a maxtoch 31.5mm mcpcb avilable for XP-L? Or it only comes in xm size?
No fear, that’s the hole for the optic leg if you’ll be using an optic. The optic legs are between the emitter pads, the two holes off center of the pads are for wires. Just wanted to be sure you knew that.
(the one’s at 7 O’clock and 1 O’clock in your picture are for wires or maybe screws… the slots might be intended for wires)
Edit: if you’re going to use only the center pad for an XP-L, almost any OTHER hole would work better for your wire, that hole is actually between the traces that go to the center pad and you’ll be wanting a larger hole for 2 20ga or 2 18ga leads.)
i know that it was for the optics ,but i assumed its the nearest way to go to the - pad for the single led,since the base of the reflector of the courui its very big(26.5mm ).i’ve tested a 18awg wire and was ok but just in case i have 20awg teflon wire.but you are right about the traces its not the perfect hole to use.
i will decide when i have all the parts to complete the flashlight ,yet i have not boufht the flashlight
