Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Wait, whaaaaat??!
Oh, thanks for clarifying! :smiley: :smiley: :smiley:
:cry:
I want a light wich is easy to mod. And I dont want to drill a pill or drill out the head. Because I have no drilling machine.
We have spent so many time now. A little more time for e better flashlight shouldn’t be a problem!
It was only the first prototype. It wouldnt be e problem with two more. And the last will be have the same as the production flashlight!
It might not be a problem for us but tbh Thorfire might not be able to implement the change at this point.
If they did do the dual XP/XM footprint design on the MCPCB, assuming you want to mod it for XHP50's, how would you mod the battery compartment for 2S2P? Wouldn't that need mechanical changes? I'm thinking you'd have to do major modding on the tail/spring PCB, as well as a different driver?
Please add me to the list. Thanks!
Welcome to BLF new members!
Ifni recall correct we even wanted a triangular shape next to the ledboard to get the heat to the rest of the housing as easy as possible. This is harder to machine so seeing the pics of Tom I see a highly optimized shelf with that raised edge around the ledboard.
I have been thinking and here is another pull from my memory, a custom copper DTP board with all the bells and whistles that were drawn (all those pads for fuses, xm and XP footprint and such) would cost us $17 a piece (Djozz you had a manufacturer for bit right?)
I am willing to start a thread for such a thing if the Q8 is done and maybe we can get Simon to do it for those wanting one?
Drawings are done, sizes known and he is closer to the action in China and has a AliExpress store.
Would that be a good solution?
Sounds like a great solution. Sifting through a couple hundred posts for info on modding the Q8 would be a challenge. Thanks!
I’ll take one. Please add me to the list.
Thanks for posting on Reddit!
David, I am thinking about your ideas since I read it and at first I thought you were joking
Yet you seen serious.
Sorry we know of manufacturers giving away a handful of lights for review that is normal.
It took a lot of trouble and convincing that at the $40 the good PR and marketing should be seen as profit. Thorfire said at a certain point they could not continue for tge low price we asked for but after emails of us saw the advantages and were back in.
It would be impolite and simply not feasible to ask or expect them to give away 600+ lights, I hope you understand that, it is THORfire we talk about, not Ultrafire that would need a lot to gain respect, Thorfire is considered a decent brand with decent quality :wink:
For us it is hobby, the man hours they have put into it, the testing, making of stuff, paying for express shipping to and from and later selling the Q8 for $40 after investing all the $$ needed to make 1200-1400 pieces should be received with thanks and to expect a soda can light to sell for $100 when at that price point there are other lights as good (RMMs Supfire M6, Nitecore TM06S, a modded light by a BLFer) is just not realistic, I forsee a fair price of $60-70 after the groupbuy if they want to sell lots of it
I wanted to do it similar to my SRK with 3x XHP50: SkyRay King mit 3x XHP50 - Bilder lastig | Taschenlampen Forum
Pictures: Skyray King SRK XHP50 | Taschenlampen Forum
On the driver-side I wanted to use the following board and put it rotatable with a screw to the stock driver (with zener mod). I wanted to connect Bat- with bypassed springs over some pins which have to fit in new holes in the flashlight-body (between the batteries). Or Bat- similar to my SRK with 3x XHP50. Bat+ gets contact over the screw and perhaps similar to my SRK.
The main Advantage of the Q8 would be that the shelf is verry thick and solid and I dont have to use an other heatsink. Thats why I want to get a dual-footprint MCPCB and a 40mm wide shelf to put alternitive MCPCBs on (perhaps for other emitters).
Here are some detail Pictures of my SRK:
Old and new Adapter:
Old driver (drjones with some slave boards)
New dual channel driver (star momentary):
I’m in for one flashlight, thanks!
The swap to 2s2p is actually fairly simple, Just swap to the Multi-cell 46mm TA driver and for 2s2p the tailcap PCB doesn’t even need to be changed.
Now allowing the cells to be installed easily is a bit harder, which is why a threaded hole in the center of the tailcap would be great and make it a lot simpler. Still not that hard though.
For a 4s1p setup you can use the tailcap I made a long time ago to do that quite easily.
With the XHP50.2 coming out now that apparently do not have the donut hole issue this is something that should really be considered. Plus I expect the xhp50.2 to give the current gen XHP70 a run for it’s money. I think that 5000 lumens per led should be possible.
Easily over 10k lumens in a Q8 for sure.
Basically supporting the 5050 led footprint would be a wise idea, plus we have no idea what the XM-L3 would do if it is released.
That said it is also pretty late in the game for major changes. Maybe they could have some MCPCB’s made in the 5050 footprint for sale separately?
Yeah Thorfire is all about making flashlights as a whole.
I am sure that if we have a list of people interested in the ledboard you drawn we can ask Simon to source and sell it via his AliExpress store, he is about parts as well and J-Dub74 has a good communication with him.
The quote that I had for a 40mm DTP copper board was if I remember well a bit over 10 dollar a piece when 50 were made. And well under 10 with larger quantities. All well within reach of an enthousiastic BLF member to organise!
Ah there you go! so maybe the 38.5mm is even a bit cheaper because less copper
Let’s see if J-Dub74 see these posts befoe taking further action :wink:
Yikes, I'm glad we got OSHPark now - makes the driver and wiring simplistic, either way - as a complete SRK driver replacement, or a smaller one piggyback'ed in.
I think I need to be on the list for 2 now (1st at #42), before the Reddit, Run.
At this point, to honor our intentions with Thorfire, we should stay the course. If we start demanding changes this late in the game, yet another manufacturer may walk away from us, further limiting our potentials that were so voraciously fought for.
Texas Ace makes a point, but fails to relate that 10,000 lumens in the SRK is simply more heat than this light can handle. One thing for an advanced hobbyist, another thing altogether for a noob, of which we have many in this Group Buy.
I have a few 10,000 lumen SRK’s and while they are overpowered surprisingly they handle the power better then I would have guessed.
They handle the heat a lot better then the BLF A6 / S1 thats for sure but do still get too hot after a few minutes.
So a 10k lumen version of the Q8 is no worse then an A6 which is a production light. The latest version of narsil also has thermal regulation & turbo step down to keep things from getting too hot as well.
I see no reason why an XHP50.2 version of the light could not be made by thorfire to be honest and sold as a 10k lumen monster. for a bit more cash obviously. The only changes needed would be minor and quite easy to do.
Although like I said before it is too late to go changing things now, just options for future versions/upgrades for the Q8.
And what is with the screws that shall connect MCPCB and reflector? Was it discussed with Thorfire already after we got the prototype?
It was hardly discussed in this thread to avoid damaged emitters.
