First of all: thank you for all the work you all put in.
I’ve been a silent reader for quite some time and now you made me have to sign up to get one of these beautiful monsters.
So please put me on the list for one for now.
Guess my dad will also want one sooner or later. So I just might come back at you in a couple of days
Can’t wait and really hope “when it’s done” is rather sooner than later
Wiesel, good point
As it was done in the Prototype the ledboard is screwed down to the shelf. This of course is good for the heat
We did in our original plan wanted to screw the reflector to the shelf with the ledboard in between
The main question here is, does the prototype work or do we need to pursue our original goal?
I lean towards let it be as in the proto since that won’t require shelf and ledboard rework and only leaves proper alignment of the LEDs adaptation of the reflector but I am sure Tom has more input on this.
Yes, it was discussed with ThorFire after reviewing the prototype. It was designed for screws but the reflector in the proto didn't have the holes. So, this is why the center hole is so wide, and why there's holes in the MCPCB. I'm assuming they didn't get a custom made reflector yet at the time, or it was a proto for the reflector without the screw holes.
I am seriously saying that giving away a few hundred lights could be done and that it could end up being profitable for the manufacturer because of the advertising value and the potential future (high profit) price of the light.
I am not suggesting that it should be done at this time with this light. We already have an agreement with Thorfire, and that’s great. But, Thorfire’s hesitancy to “lose” a little on these lights shows they have a problem understanding how economics work and how valuable (profitable) advertising really can be. I think that after this group buy is over and they see how much money they make selling these at “market” price, they’ll be happy they worked with us. That is, if they deliver as promised and don’t try to screw us like other manufacturers have done.
I can not wait to push the Q8 to its limits. Waiting for a source for XP-L2-W2 LED´s. Could not resist the price (~25€) an bought a second pair of batts for the Q8. First set :4*NCR18650GA´s and the second set : 4* US18650 VTC6. I’m curious how far i can push this light with spring baypass, new W2 LED´s and a spring PCB mod (8000+?).
Has anybody done a output test for the XHP50.2? Can not find anything here on BLF. Hope that the new XHP50.2 will be a good upgradef or my modded TN31 (K40M driver with resistor /spring mod and dedomed MT-G2 LED + i added a lot of copper to help with the extra heat).
In regards to using batteries in parallel: I read somewhere that you can use 1-4 batteries. What special considerations would there be to this setup? I’m guessing you’d want to use the same batteries, but would they need to be at the same charge level as well? And what happens if they aren’t? I’d appreciate any insights
Super technically any 4 (or 3 or 2) cells that are reasonably close is charge (say within .5V of each other) would work just fine.
Un-technically that is NOT recommended.
The recommended setup are 4 matching cells, charged and discharged together so that they are always pretty closely matched in charge level. This is the safest setup.
…and depending on the difference(s) in charge levels and relative health of the cells, it could be anywhere on the range from “nothing noticeable happens” to “catastrophic failure” AKA “venting with flame!”
HIGHLY unlikely it would lead to any kind of venting. I have put cells in parallel that were up to 1 full volt difference with not even any signs of high amperage flowing. Someone else said they measured it and it was only a few amps, which I believe.
Remember that both cells with voltage sag and meet somewhere in the middle. From 3v to 4v, they would meet in the middle someplace, which that amount of sag is only equal to ~10A or much less in most cells. Less then a single cell running this light would be pulling.
Now if the cells were already hurt, well anything is possible but you should not be using cells like that in an FET light anyways.
With good quality brand name cells, the “risks” are quite small but still unnecessary. Simply charge and discharge the cells together.
I once ate burgers on the grill at a friends house and literally saw him hunting for wood to use to smoke the burgers. He found a piece of 2x6 in the ditch, knocked the dirt off , shrugged his shoulders at the paint that was on it, and threw it on the fire to cook the burger I was about to eat! Point being, you never ever know what the other guy is capable of. Even an old friend and work buddy that you’ve known for years.
Lap pulls, cheap **fire cells, you just never know what someone is going to stuff in a flashlight.
So I’m thinking of getting on the list for a second one, for a good buddy who will love it. I’m just bouncing this off you guys, for pricing. A Lii-500 is probably the way to go for him, yeah? Plus 4 GA’s and the light. Sounds like about $90 all in, right?
