Just solder boobed 8 VTC6's. I call it "ST" (Solder Top) vs "FT" (Flat Top) or "BT" (Button Top). I bypassed the springs in the round #3 proto with 22 AWG wire.
Pretty much all the spring issues go away when you bypass them - they stiffen slightly but might still disengage on a good bump. I also gave the stock ones a little stretching so they sit at 11 mm now. There's no risk of over heating the springs with the bypass.
From the best I could figure, there's 73.6 mm of space for the cell and spring. VTC6's are about 65 mm dead on, and the solder adds about 0.8 - 1.0 mm. So in theory, a 10 mm spring would have to compress 2.4 mm, or with a 11 mm spring, 3.4 mm.
10 mm spring: 63.6 mm of space for the cell, a 66 mm cell compresses 66 - 63.6 = 2.4
11 mm spring: 62.6 mm of space for the cell, a 66 mm cell compresses 66 - 62.6 = 3.4
I measured a 30Q BT at 66.75 mm, so you would get 0.75 mm more compression. The issue is the range 1 spring needs to support, figure shortest cell is a GA FT at 65.3 and I got 2 protected cells at 69.7 and 70 mm each. So the one spring has to support a variance of close to 5 mm. On many (most) lights, this variance is easier supported by two springs, one at the driver, one at the tail.
So with my newly wired up tail PCB, rigged with an 18 AWG loop for a clamp meter, and also cut down the 18 AWG LED wires and soldered/shrink tubed them to 16 AWG wires, and on a new set of VTC6 ST's:
at 4.20V: 21.2A at the tail, lumens: 6,800 @start, 6,375 @ 30 secs, throw: 66 kcd (514 meters)
I'm thinking that if we had a 13 mm spring, might be better to stay with a relative soft spring, so the 70 mm cells aren't a problem threading up. I dunno - maybe these guys doing the design of the lights understand all this well, but certainly there's an optimum zone the light should be designed for. If we picked a cell range of 66 mm to 70 mm, a 12 mm spring would give you 4.4 mm compression on the shortest, and 8.4 mm compression on the longest. Now 8.4 mm is a lot of compression and force, specially x 4 for 4 cells. A soft 12 mm springs could handle that, but a stiff spring might be hard.
