Convoy L6
Summary:
Battery: | 2x 26650 (18650 can be used, not recommended) |
Switch: | Forward Tailcap Clicky (On/Off +momentary) Electronic Side Switch (Modes) |
Modes: | 4+: Low - Medium - High - Turbo + Hidden Strobe |
Mode Memory: | Last Mode Memory |
LED Type: | XHP-70 Neutral White |
Lens: | AR Coated Glass |
Reflector: | Aluminum - Orange Peel |
Price: | $55.36 |
Provided by: |
Function:
The Convoy L6 has two switches. The switch in the tailcap is a forward clicky switch that offers a momentary on feature and controls power on/off. The electronic switch located on the side just below the heatsink fins on the head controls mode switching.
From off:
Half press and hold (no click) the tailcap switch to turn on the light at the last used mode. Release to turn off the light or press the switch further until it clicks to fully engage the switch. After the click the light will remain on when the switch is released.
While on:
Press the side switch to change modes. Cycling through Low - Medium - High - Turbo.
Click the side switch twice rapidly to activate strobe. A single click will return to the last mode used.
Press the tailcap switch until it clicks and release to turn off the flashlight.
Data/Measurements:
Tailcap Amps measured with a clamp meter. Freshly charged LiitoKala 26650 5000mA cells.
All throw measurements are lux values taken at 7ft and calculated back to 1 meter (Rounded to the nearest hundred). Estimated Max Output (Lumens) values are calculated based on measurements taken 30 seconds after turn on and are obtained through a DIY 'pvc lumen tube' in an effort to achieve diffusion of dissimilar beam profiles. As such, these values should be taken as "rough approximations."
The following test took place in 75°F Ambient temperature, indoors, with very little air movement. The flashlight sits head facing down on a piece of glass that is recessed inside a 4" PVC pipe. A small fan directed at the flashlight is activated where indicated.
The Convoy L6 puts out some serious heat with it's serious output. Rapidly climbing until 16 minutes when the L6 has come 'too close for comfort' to dangerous temperatures for Liion cells and a fan is activated and remains on for the rest of the test. Interestingly, the output slowly jumps back up to a level just under the turn-on output before starting a slow decline. At 70 minutes the output begins declining rapidly until the Low Voltage Protection (LVP) kicks in and slowly strobes at the 80 minute mark. The cells measure 3.12v.
Pictures:
The L6 arrived in a generic brown cardboard box with ample protection with cutout foam on the inside. It took a pretty serious hit in shipping and remained pristine.
The anodization on this beast is just a glorious matte black. The machining is perfect. No sharp edges to be found.
The side switch sticks up a bit. It has a very tactile, satisfying, and audible click when pressed. Almost no squish to it. It is kind of difficult to find by feel.
Note: The smudges/shiny spots seen in a few of the pictures is thread grease. The only problem with this finish is that it holds oil/grease pretty well even after thoroughly wiping it down.
Can you see that? Most people can't. :) Gif explanation further down.
Would you look at that block style knurled tube. :love:
Some more grease. Argh!
Bare threads that thread into the head. Nice and square.
Back of the tailcap. The forward clicky switch has just a bit of travel before activating momentary, and a bit more to click. Spot on imo.
Factory Bypassed switch spring.
Factory Bypassed driver spring.
You see it now, right? ;) Just another indicator of how well this beast is machined. Pretty easy to miss. The tactical ring threads onto this spot if you so desire. I actually like the smooth ring myself.
Square, anodized threads for a physical lockout.
Don't accidentally turn this monster on while looking at the LED. 3500 lumens is not something you want to blast into your eyes. Trust me.
That scuff on the bezel is the only minor defect I've come across.
Now that's an LED! One big Ol' XHP-70.
Comparison:
From left to right: ThorFire C8s, Convoy L4 (2x 18650), Convoy L2 (Optional 2x block style tube), Convoy L6, Maglite 2D (MT-G2), DST.
Popped on the Tactical Ring and turned off the sun.
Convoy L2, Convoy L6, Maglite 2D, Nitecore TM16.
Beamshots:
As with all beamshots in my reviews, every shot is taken using the same setting in manual mode.
The central tree trunk is about 50 yards away. The water line is about 35 yards away. The hanging tree limb in the upper left quadrant of the pictures is about 10 yards away.
The TM16 has a very bright, and very wide spill with a decently tight hotspot. The 2D Maglite modded with an MT-G2 at 5 Amps has a very floody 'hotspot' with a very wide spill. The Convoy L6 is pretty well in between both of them with a slightly larger hotspot than the TM16, and a comparatively dim and truncated spill. The Convoy L2 is in a completely different ballpark. The L2 is a super thrower with a very concentrated hotspot and a narrow and dim spill.
Convoy L6 - Medium - High - Turbo
Conclusion:
The Convoy L6 is one of the best quality to cost ratio of any flashlight I've held. This thing just emanates quality from top to bottom. From every finely machined edge to the factory bypassed springs to the beautiful AR coated lens.
If you're looking for a high quality light with 3k+ lumens with decent throw and a great tint in a manageable size this beast just might be for you. :THUMBS-UP:
