The images in this review belong to Hiram, and the images are being used with Hiram’s permission.
I used a program called Topaz Gigapixel AI to improve the image quality.
I received this zoomie flashlight today.
The Hiram Aurora is a nice zoomie, but it has some flaws
The Hiram Aurora has a Luminus SFT70 emitter.
I like this choice in emitter, and the flashlight does throw pretty far in full throw mode.
The flashlight is also quite bright in the brightest mode.
The tint is neutral white.
It’s about 4500K.
Here are the brightness levels according to the manual:
3000 lumens Level 1
1500 lumens Level 2
750 lumens Level 3
350 lumens Level 4
100 lumens Level 5.
The mode spacing is very nice, and there isn’t a big difference in light level between adjacent modes.
The light does get quite hot after a few minutes on Level 1.
Level 1 is supposed to step down after one minute, but it did not step down for over five minutes (which is the maximum continuous length of time I tested Level 1.)
If the flashlight head had more mass, or if it had cooling fins, it wouldn’t get hot so quickly on Level 1.
On Level 2, the flashlight head does get quite hot after a few minutes, but the lower half of the flashlight does not get that hot even after five minutes.
Level 2 is supposed to step down after four minutes, but it did not step down for over five minutes (which is the maximum continuous length of time I tested Level 2.)
To turn the flashlight on or off, press the button once.
To change modes, quickly press the button twice.
The flashlight goes from Level 1 → Level 2 → Level 3 → Level 4 → Level 5 → Strobe, and then back to Level 1 again.
There is no way to avoid Strobe in the mode selection.
Luckily, the flashlight has perfect memory and remembers the last mode it was in (except it will not remember Strobe.)
Double clicking to change modes is not ideal, to say the least.
Also, double clicking is not super easy because you have to press the button pretty far for just a single click.
It is kinda difficult to change modes, but if you don’t change modes very often (like me), that is less of a problem.
The flashlight comes with a few accessories.
The flashlight can be attached to a long gun, and I think it comes with everything you need to do that.
(I don’t own a long gun, so I didn’t test any of those accessories.)
Also included is a proprietary 21700 cells.
I usually can’t stand proprietary cells, and in my opinion, they’re frequently completely unnecessary.
This flashlight will not work with a regular 21700 cell.
You must use the one provided by Hiram.
Also, you must charge the 21700 cell in the flashlight with a USB type C cable.
I usually don’t like charging batteries in flashlights.
This battery choice, in my opinion, is the flashlight’s biggest flaw.
The fit and finish of the Hiram Aurora are excellent.
There are no sharp edges anywhere, and the ergonomics are nice and simple.
The flashlight claims to have IP68 waterproofing, but I don’t see how that is possible if the USB type C charging port is exposed.
The user manual is in English only.
I only skimmed the manual, but the part that I read is well written and easy to understand.
The Hiram Aurora is very nice, but I don’t like Hiram’s choice to use a proprietary 21700 cell.
Also, it is difficult to change modes, and it’s impossible to avoid Strobe when cycling through the modes.
Other than those complaints, I do like the flashlight.
THE END
