<span class=“language english the in myself express to way correct the me suggest and phrase” “strange a wrote i where me point wanna you if corrections and suggestions accept I me. with compliant be please so error, grammar of lot a making surely am i english, in write to good so not am i”>
First impressions:
Shipped from: Banggood http://www.banggood.com/Lumintop-Tool-AAA-XPG-R5-80-Lumens-Keychain-EDC-Flashlight-p-929235.html
but also GearBest sell it http://www.gearbest.com/led-flashlights/pp_203080.html
At first glance it seems like a shrunked standard flashlight, keeping all proportions in a good way, difficult to find in small aaa flashlights.
This is the NEW model of lumintop tool, it DOES use the XP-G2 led with 3 modes instead the old one XP-G with 2 modes.
I cannot find official info of this newer model in the lumintop official page, but some online reseller write which this one is capable to use a lithium 10440. (and i tested it)
Modes and estimated lumens:
Switch type: MECHANICAL
There are “ 3 ” modes in the following order:
Med – hi - low
My estimated lumens are 80/100 with nimh and 300 with my Efest IMR 10440
Compared to my olight i3s , the tool is slightly brighter (fairly similar) on nimh maybe just because its tint is a little cooler than the i3s, and you know cooler tint appear brighter to eye. On 10440 both are comparable ( i have only 1x 10440 so it’s impossible to compare both at same moment)
>>LIGHT >>> The angle of refraction:
Weight and dimensions measurements (made myself, not by specs):
This flashlight weighs precisely 14 gr
Height 8,2 cm
Diameter 1,1/1,2 cm central tube
Head diameter 1,9 cm
Construction quality:
It’s a really high quality tiny flashlight, everythig seems made in perfect way.
The most attractive feature is the rear switch, hard to find on 1xAAA flashlight, and i prefer it instead of the twisty design.
Did you notice my estimated lumens with a 10440 battery?
I compared it with my thrunite tn12 2014 at medium , (that’s officially rated at 280 lumens by thrunite , but SELFBUILT estimated in his review 330Lm) and i found that this lumintop at Hi is EQUAL if not slightly better ( just 5/10%) than it.
It’s impressive……but it warms up quite fast.
Lanyard hole: PRESENT (two)
Threads came FULLY GREASED and there’s an additional o-ring included
Led Tint, reflector and lense:
The led is well centered and its tint is pure white, tending to cold
Reflector made of: ORANGE PEEL – not tested if made of plastic or aluminum
Lense made of: GLASS
Outside beamshot at 25 meters, only at FULL power (same place for all my reviews)
Wall beamshot at 250 centimeters, from lower to higher power (same place for all my reviews)
Ceiling bounce test with LUXmeter:
PROS:
- About 300 lumens with my 10440 efest
- good priced
- overall construction quality
- does have rear mechanical switch
CONS:
- can’t find a real con, except for the reduced recommended runtime with 10440 due to excessive heat production ( but it is NORMAL) .
Final thoughts and why you should buy it:
I am not a flashlight veteran but i think that for the price it is more than you can expect for a flashlight.
Lumintop seems to be a reliable brand , this item is sold at an affordabe price…. and if you prefer to use (like me)a real mechanical switch in all your flashlight i must recommend this one.
Thanks for reading……
….and if you notice some bad written phrases, feel free to correct me suggesting the right way to write it!!
