The Skilhunt EC150 is an everyday carry flashlight powered by a single AA, or 14500 size Li-ion rechargeable battery. It features a floody beam profile, USB-C charging, magnetic tailcap, a selection of body colors, and two LED options. It’s capable of impressive maximum output over 1600 lumens, and sustains over 400. The lowest mode is well under a lumen, which preserves dark adaptation while providing some visibility. The optional Nichia 519A 5000K LEDs look like sunlight and renders colors nearly identically.
Great review as always.
I really like the EC150, particularly the 519a version. Great beam and it exudes quality.
As you note in your review, your results are both inconsistent with Skilhunt’s published specs (which tend to be accurate, if very slightly conservative) and other reviews. I think this level of output is impossible from an 800mah battery. I can’t remember if it was you or someone else who also had trouble measuring a different 519a light. I wonder if there is some connection. In any event, as you note it’s plenty of output!
Either way, it’s a great light and I prefer it to the d3aa as a rugged and reliable everyday light.
thank you for the review,
in the link you mention that the H150 is Potted. Can you confirm the Potting with a photo?
This EC150 review by SammysHP does not show potting:
If the EC150 now has Potting, that puts it on par with the Zebra, whose claim to fame is Potting. I prefer the Skilhunt UI over the Zebra UI.
Although the D3AA is not Potted, I have not seen any reports of a D3AA breaking from being dropped.
One of my concerns with the EC150 is the switch is not recessed. I like that both the Zebra and D3AA have recessed rubber switches. They are very unlikely to turn on in pocket accidentally.
I like that both the EC150 and the D3AA use Boost Drivers, with very stable Lux outputs. And both are dual fuel.
The EC150 has USB-C charging. In the D3AA I use USB-C batteries to gain a similar utility.
Things I like better about the D3AA are Anduril, the NTG LED options, and the additional color temperature choices.
The potting is usually found on the other side of the driver, where it fills the cavity (sometimes only partially).
Skilhunt does use a white rubbery adhesive material, possibly a type of silicone, in some areas. I was unsure if that is what Zak meant when he used the term conformal coating:
it does look like a good material to help protect from drops
Do you have a dual channel D3AA? If so, do you find yourself making frequent use of it? Or would you say the single channel D3AA is worth going with for the price difference?
I EDC a dual channel D3AA because I like having a Red light option. It displaced my KR1AA
more details in this post
and even more details in this thread
On the EC150, there’s a different grey material over the components on the board that’s in contact with the positive battery terminal.
There’s not a perfectly clear line between potting and conformal coating. If it fills a lot of space such that it’s overflowing through the hole in the center of the MCPCB as with the EC150, I am likely to call it potting.
I have EC150, but ordered it with SFT-25R. Output 1500 lm, and ANSI throw is 200 m (vs 86m from your 519a?). Kinda thought I should have ordered it with 519a, but feel a little better now for the throw lol.
My best subjective description: this light looks and feels like a little jewel. I love it. Amazing that they add USB-C charging in such a small light. Must be among the smallest 14500 lights with USB-C?
I think you made the best LED choice for outdoor distances.
A complementary model for close range and handsfree use is the H150.
No USB-C port, but you can can choose the BL-113C battery which has USB-C in the battery. And you have an additional 519a option, of 3000K…
It is a very nice little light with the same UI as your EC150, and they can share batteries.
second from right, and also dual fuel:
