I would try much better batteries first. There is no way that those batteries are 4000 mah or even 3000
Ok - so what do you recommend?
The xtar 2600's w/ sanyo cells. Best cheap batteries you can get.
Before I found BLF I ordered 2-UF 4000 mAh cells. In myUltrafire KH-T60 the draw is 2.4 amps. The Panasonic cells I got from the good Reverend I get 3.4 at the tail. Brinyte C5 with UF 4000 2.6 with Panasonic CGR 2.8.
+1 and there is still a special on.
I use the Hi-max batteries from eBay in this light with great success. They are reviewed on this site.
Where abouts? Might get some. I am looking at the Xtar 18700s. These seem to be the protected version of the 18650. ie slightly longer. Just in case you did not know, the '18' means the width in mm. The '65' is the length. So a 18700 is 70mm long.
Does anyone know if the 18700s will work in the Skyray?
Definately get some. They do work.
I'll find the link
You can see the archived poll results on the Wayback Machine: XTAR 18700 Li-Ions group-buy (Status in 2nd Post) - BudgetLightForum Deal Alerts - BudgetLightForum.com
They are all I use with 2 x 18650 set ups
[quote=edc] https://budgetlightforum.com/t/-/72497 [/quote]
Please note promotion is to be run out at the end of this month, so hurry up.
Mine just short circuited and squished tailcap spring. I believe it is the drivers fault. After close inspection I noticed that the driver board with spring is just a board without elements only some circuits printed. Perhaps the driver and the board are too close and can short circuit. A plastic sheet (like they use to cover the leds) would solve the problem if placed in between.
EDIT:
For those of you disassembling the light: place the reflector back EXACTLY as it was. Finding the right turn of the reflector solved my short circuit problem. The light is shining again
Yes, I just ordered 2 pairs. Not a bad price at all.
So I'm starting to think that this light just isn't so well made on the inside, no? It seems a number of people are having theirs burn out or arrive duds. How many of us have had our 3800s for a while and are still finding them strong?
What little disassembly I did seems to indicate that the quality is pretty good. Mine arrived as a dud, but these things can happen. The hardest thing so far is getting the chinese seller to actually read my emails. It took me 3 emails to convince them I was using 18650 batteries (which they sold to me). Still no resolution on that front. But everything looks good on the torch - double o-rings, for example. Very nicely made threads, solid feel. The batteries were a nice tight fit (ie did not move around). All in all, I am very happy with the build quality. As soon as I resolve the ‘not working’ bit, a friend is going to buy one as well.
There have been a few duds but I think there are a lot of them are out there. I cant remember a light that got so much attention when it came out. I would like to know how many are out there. For the record my original type is still going strong. only glitch in mine is that sometimes it will snap out of low mode to full power. Not real often though.
Just a FYI, My light is rev0 and after taking it apart and putting it back together, I noticed it was only pulling 2.30 amps.
After opening it again and looking at the driver, I noticed what looked to be a cold solder joint. I decided to take a chance a re-solder it.
After re soldering the joint, it is now pulling 2.98 amps on the exact same batteries.
Not sure if this will help anyone else, I noticed some people were reporting very low amp readings, perhaps look at the driver for cold joints and re-solder if necessary.
I have the drop in version, and it is still going strong. I don't use real long run times, but it has been worth the purchase to me.
Ordered 7/17. Received 7/29. I'm not really sure what my version is. I don't think it's a drop-in because I tried pulling it out and it doesn't budge. It screws and unscrews so I think it might be Revision 2.
Definitely, since it unscrews. So how's the performance? Still 2.5A at the tail? No DOA?
Together with the Fandyfire STL-V6/Sky Ray STL-V2 throwers, plus these 3 XM-Ls, these are all excellent lights which all flashaholics must experience. And do get some IMR 18500 from bestinone.net, E1320 and I have tested them. Very good stuff and utterly capable of 2.5A-3 plus amps that the 3 x T6 requires, orange wrappers. They improve slightly on the length and cut it to 180mm so that its more manageable.... in fact you can put it into your pocket or jacket easily.
You just shouldn't have to be re-soldering stuff and lights shouldn't flip out of modes. That's what bothers me (as a non-mechanically inclined person). And having to struggle through language barriers and having people reply: "Maybe you are happy with only 100 lumens?" It would be too much.
This is the first light that I've bought for a long time. My trustfire flames are charging right now. How are IMR cells different from my trustfire flames?
