Not real throw!? There are hunters in this forum who uses dedomed XPG in C8s with about 160kcd and less than 1,000lm. The MT07 is very close to that number at 130kcd and delivering many times the hotspot size.
A thrower is not purely how much peak kcd it makes but how it manages to deliver usable light at long distances.
The L6 XHP70 isn’t a pure thrower either, so don’t waste your money on that either. You want a pencil beam thrower. This light is for those of us that want to put a lot of light a moderate distance down range and still have decent illumination everywhere else. Pencil beam throwers are amazing, but I have no use for a pencil beam thrower, and aside from a couple zoomies, I don’t have a single pencil beam thrower among my shelves of lights. Do what’s best for your needs. There are plenty of good lights, and this is one of them even if it doesn’t suit your particular requirements.
Totally agree, that’s exactly my thoughts on long range lights. I hate laser-like 750klux 2” wide beams.
But when I read someone saying a dedicated thrower didn’t hurl enough light down-range, that’s the kind of thing I take notice of. BTW - I’m one of those C8 weapon mount users :sunglasses:
Mine has the same dedomed U4 as the 2X Shooter in it.
I believe the electronics works differently in the 4S config - it's a buck driver in this state, and he said 4S has current regulation, so I'd expect the runtime curve to be flat, or flatter, therefore more power (I * V) used during the cycle resulting in shorter runtimes.
Updated the turbo mode discharge curve in the OP. here it is:
This is now scaled in time properly, and the temperatures were taken with a IR thermometer at the hosttest section of the surface, which is just above the switch.
Yes the 4S batteries can sustain the Turbo output constantly and it consumes more power overall, I agree on this.
The problem is we don’t really have a standard to define the runtime of a light can offer (i.e. until it drops to how many % of initial output), this is why some manufacturers have this “Turbo mode can last for a few hours” kind of claim lol, which is quite misleading I know.
Well, 4s setup is preferred from the vantage point of future compatibility with 12v led emitters. If an idealistic future 12v xhp90 Hi is produced then this host can be taken to a whole new level with just a emitter swap. Just need to confirm if this driver is 12v led capable in the 4s version which is highly likely . Anyway xhp70 is no longer young and a new Cree emitter might be already in the works, the xhp50 /70 Hi version ought to be the next rollout after xhp35Hi.
Hhmm, I agree - not too crazy bout how the pics came out. Meter and outdoor testings shows the MT07 throws further though. Sorry - @work, can't recall details - have to re-check, but I think the camera showed a surrounding corona as part of the hotspot, so the true hotspot is smaller. Seen this before - I'm not a camera hobbyist, so just trial&error with camera settings.
On my compact Lumix, used Manual mode - F6.3 1/8 sec, auto WB, auto ISO. Could not get any available white balance setting to look like what I was seeing - AWB looked the best. Realized after should have used a fixed ISO setting though. Lights were 4' 8" from wall, camera was 5' 6.5" from the wall.
Thanks for this review. With all the heat sinking in this light my main use would be with it mounted on a tripod as a work light running at about 1k lumens (500 would provably suffice). I would think in this configuration you would be able to get relatively good runtimes being as how you can get 7 minutes from it at almost 5k lumens before it steps down. Still waiting on reviews of the MT03 before I decide on which model to get though.
Yep, this light is built like a tank. GA's are the best for this light, fit with no issues, so would have 14 amp-hours. The $5 price per GA is a good deal, being offered in the group buy for this light here: https://budgetlightforum.com/t/-/42727.
