Part #2 : BEAMSHOTS & CONSIDERATIONS
On this part I will show how this flashlight illuminates and express my comments/ considerations about this flashlight!!
Let’s start to say that there is no PWM on this flashlight (from Low to Turbo):
I will start by saying that the beam produced by this flashlight is quite large, it is kind of throwy (due to the SMO reflector) and also…has a yellowish shift that marks the corona and, in some part, the hotspot. XPL2 Leds tend to do this (at least from my experience from other flashlights).
This is mostly noticed against a white wall or object, but it can also be noticed outside, in some occasions against non-white objects. Please note that this photo doesn’t make entire justice to the beam as it is, due to the photo and the upload itself!
These are some attempts to show the beam pattern! ![]()
Left – Inside the light box w/ lights out /// Right - Over a white plastic board
TINT COMPARISON
Let’s proceed with some tint comparison!!
(Left) Manker E11 > Wuben E05 > Sofirn SP10A (w/ XPL-HI U6-3A)
(Right) Wuben TO10R (XP-G3 CW) > Wuben E05 > Wuben TO46R (XP-G3 5000K, 90CRI)
( L ) Zanflare F1 (CW) > Wuben E05 > Amutorch AX1 (XPL-HD NW)
( R ) Manker E11 > Zanflare F1 (CW) > Wuben E05 > Amutorch AX1 (XPL-HD NW)
( L ) Convoy T2 > Wuben E05
( R ) Nitefox ES10K > Wuben E05
( L ) Convoy S2+ (XPL-HI U6-3A) > Wuben E05
( R ) Olight M1T Raider > Wuben E05
( L ) Amutoch S3 (Nichia 219C w/ diffuser) > Wuben E05
( R ) Amutorch S3 (w/ XML2 T6-4C) > Wuben E05
( L ) Amutoch S3 (XP-G3) > Wuben E05
( R ) Olight M2R Warrior > Wuben E05
BEAMSHOTS
Now, some beamshots inside home, with 14500 Li-Ion and with AA Alkaline batteries!! (photo quality decreases a lot with GIFs and upload :person_facepalming: )
Please note that in all the photos the 14500 Li-Ion (4 modes) is on the LEFT and the AA Alkaline (3 modes) on the RIGHT !!!
Only with 14500 Li-Ion battery:
Left - 6 m /// Right - 15 m
BEAMSHOT COMPARISON
I decided to pick 2 other flashlights that attain more or less the same amount of lumens on max (900 lumens) and compared them with the Wuben E05 (always with 14500 battery). Those flashlights are the Manker E11 and the Olight S1R Baton (I).
So, now we will have the sequence:
Left – Manker E11 >>> Middle – Wuben E05 >>> Right – Olight S1R Baton
18 m (tree) >>> 20 m (bottom of tree) >>> 40 m (white factory)
The three flashlights have different types of beams, and on max/turbo they reach almost the same distance! The Wuben E05 has a larger beam and is, at the same time, very throwy, what gives a good sensation while trying to illuminate wide ranges!
CONSIDERATIONS
My opinion about the Wuben E05 (and package) after using it and “testing” it on the last days!
WHAT DO I LIKE?
1) I like the machining, the design, the feeling of this light in the hand! It is really well made, with no machining flaws and has excellent quality, and is…classy !!!
2) I like the form factor and “ergonomics”, as it is thinner in the body and larger in the head and tail, allowing a good grip!
3) I like the shortcut to Turbo and Strobe/SOS from ON or OFF, and also the lock/unlock feature!
4) I like the way the pocket clip helps to locate the switch! Yeah, seems awkward, but the fact that it doesn’t move, helps to locate the switch better!!
5) I like the max output of this flashlight and the mode spacing it has! Wuben never lets down on this
(well, at least in the 3 Wuben flashlights I have)
6) I like the magnetic tailcap, always handy ![]()
7) I like the accessories it brings, specially the diffuser and the pouch :heart_eyes:
Well, the USB-rechargeable 750mAh 14500Li-Ion protected battery is also very good, specially because it is possible to recharge it with a powerbank, and because otherwise I would just use Alkalines, not proofing from the full potential and power this light has ![]()
WHAT I DISLIKE & WOULD CHANGE…
1) There is no direct access to Low mode, what would be a big plus in this flashlight as it is used for small ranges as well and would avoid accidental blindings. However, I do like the fact it has memory.
MY SUGGESTION: implement direct access to Low even if it implied changing the way to access Turbo from OFF.
2) The tint shift: the yellow shift on this light is not good, and is noticed –sometimes – in outdoor use. The XPL2 Led is capable of this even with Orange Peel reflectors, so with a SMO and AR Coated lens, the yellow shift will appear, even being a Neutral White LED.
MY SUGGESTION: change the type or bin of LED for one that gives a good output with less tint shift. (another possibility is to mod the flashlight, either adding a diffuser or changing the Led :p)
3) The pocket clip, although being good, I would prefer it a deep carry pocket clip, aligning it to the bezel. A good example is the one of the forthcoming TO50R.
MY SUGGESTION: change the clip and make it deep carry !
4) I would like to have some more information in the User Manual about some aspects, namely the LED, Reverse Polarity Protection and the body material.
MY SUGGESTION: please add it ![]()
EDIT [the morning after
5) I forgot to mention another thing that bugs me a little bit, that is…the long press for OFF. Yeah, it its longer that in other AA flashlights around (Manker E11, Sofirn SP10A/B) and it annoys.
MY SUGGESTION: change the way to switch the flashlight OFF. At least by reducing the time for pressing a little bit.
So, my final thought is that this is very good flashlight! I like, and the minor things I mentioned do not take it any quality it has!!! Even compared with other “direct” competitors, it surely wins in some aspects such as form, power and “feeling”!
I want to thank Wuben again, for providing this light for review!
Thank you and keep up the good work!!
If you have doubts or comments, let’em come!
Best regards :+1:
