I received a Review Sample of the Wurkkos TS25
here are some first impressions
I like the LEDs Color Temperature, and Tint Duv. The beam profile is also to my liking, as it has a good hotspot.
The TS25 is a nice size for a jacket pocket, and weighs 145 grams with battery. It feels good in hand, not too large, and I like the slender waist body design.
The switch is also nice, it can be located by feel, because the button protrudes with straight sides. I also like the travel and feel of the button. It is crisp, predictable, and easy to use.
Light arrives in simple smooth ramping mode and turns on at 75 lumens
there is Last Mode Memory enabled
Aux arrive in multi color changing mode…
7C from Off cycles the Aux. There are a total of 6 steps, including Aux Off
The different Aux colors have different brightness. For example the red is dimmest and reads 0.09 lumens on my meter, whereas the green is brightest and reads 0.38 lumens
The aux create a pattern with many petals, like a mandala. The multi color changing Aux setting is very colorful:
Battery check with 3C works to make the main LED count voltage. The aux turn on in between. Instead of staring into the optic, I just shine the light on my hand. This makes it easy to count the white light flashes, without being distracted by the Aux lights.
The Green button light turns on for 5 seconds when the light is first turned on. It is Off at all other times.
I have set my Aux to Red, for now:
The thermal calibration is accurate, within 1C of my IR gun. I ran the light at the ceiling in advanced ramping until it stepped down, at which point the body was at 49C, from which I infer the thermal ceiling is set to 50C by default.
I have one suggestion for future revisions:
I would like the green button light to stay On all the times,
both when main LEDs are On and also Off…
I like illuminated buttons. ![]()
