Thought I would share some initial impressions on this unbelievable thrower.
Purchased this "Turbo Head King" for $43.99 and it came with an L2i tube. (body/switch, no head) Screwed it onto one of my L2Ps with an extension for 2 x 18650. The MP Pro 1 is rated for up to 16 volts so, conceivably, 4 x 18650 is possible. It is fully regulated so it probably will not be any brighter with multiple batteries. I'm using two Solarforce protected 2400s for right now and to be honest, three or four 18650 batteries makes for an unnecessarily long and quite unattractive torch. Not to mention the extra caution required with multiple Li-on use.
Tail cap amps:
single Solarforce 2400 - 1.0
2 x Solarforce 2400 - .75
3 x Panasonic unprotected - .51
4 x Panasonic unprotected - .39
Cree XR-E (WC R2)
The crenulated bezel keeps all the parts above the pill in place. Unscrew it and remove the hard, flat gasket.
Under that is a soft gasket with a lip into which a glass lens seats that looks like it has a coating of some kind. This rubber ring sits directly on top of the reflector.
The reflector is aluminum and very well finished. It is not rippled or bumpy around the emitter opening like so many others.
The pill screws in from the bottom until it seats.
I tried to remove what appears to be an easily unscrewed whateveryacallit above the driver (you can see the resulting scratch from my ham-fisted efforts) but I simply could not make it budge. Either Hercules put it in there or they used Loctite or something.
If you break out the magnifying glass you'll find a bit of Solarforce marketing on the driver. To the naked eye it looks like spilt solder.
No beam shots and this is not a full review. I'm planning a big thrower comparo soon but after a few minutes in the back yard, I can already see what kind of performance this bad boy has. This light has given me new respect for the XR-E and seems to shut down the Skyline 1 big time. It's a little ringy but it can put a whole lotta light on something a long ways away. The Masterpiece Pro 1 is a serious thrower with spectacular build quality. It looks, feels and performs like a flashlight costing double or more. It's performance honestly, has my jaw on the floor.
This is an unbelievable thrower.
More to come.
doublewowFoy
