The MF01 driver has a bigger diameter
I got the same issue as I order when 3 MF01 are requested
I have here still 46mm SRK drivers left that I can modify for MT03, I did that 2 times and one is already in use, the center solder mask needs to be romoved for the spring and the Diode replaced with LDO
Del had 2 capacitors added for protection
Only that 27000lumens light with the Infineon FET killed the AMCs, while it worked with SIR404 that I use as well
The claw AMCs take it well so far, the voltage is not the poblem its when the FET comes to play
old quote, but FYI the latest Q8 e-switch build maps the TA modegroups onto a FET+1 driver. It's e-switch, it applies an indicator voltage on pin 3, and the modegroup ramps are matched up (matching transition from 7135 to FET) ideally for a driver that outputs 16A, That last part is always an issue though unless ramps are customized for a particular light, but it's not a big deal, just affects mode spacing a little in the middle modes.
Anyway, I can easily configure a build for FET+1 clicky switch, either with or without OTSM, that uses TA tripple modegroups. This requires no real programming change, just customizing the configs before compiling. If there is demand for it, let me know. This kind of configuration doesn't have to be done by me either. HD is designed to be reconfigured in these ways, but I wouldn't expect lexel to do it unless he just wants too, it's certainly extra work for mass distribution and he's selling these real cheap. Sometimes I might do it, and of course enthusiasts can do it themselves and re-flash.
Oh, yes, the reason I was trolling this thread is because of that Q8 firmware. It's a stock Q8 firmware, not a TA Q8 firmware. I think the bistro-eswitch-HD-TA should probably work on the TA Q8 board, but I'll review it. I assume the TA Q8 board doesn't use an indicator led (no pins left)? Now that I look at it again, it should work fine on the 2S/4S board too.
I hope the other AMC7135 suppliers claw type work as well as the old supplier ones
When they do I do another big order of parts from Digikey and Mouser
Hi, I have Bistro HD OTSM and trying to install lighted tailcap in S41 with stock tailcap board. I’m adding resistors in the tailcap with LED. The problem is: if resistor value is to high (>220), green led does not work; if resistor value is around 220 and lower, green diode is working but I cannot change modes.
