Thank you very much JasonWW.
It makes total sense, I have never dealt with SMD components so I would never have guessed that.
I actually saw your Conloy L6 thread and that’s how you added the resistors to yours.
Lexel,
Can you please give me a total for:
(1) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), with spring
for Convoy L6
for my courui D01 i want a FET driver with e-switch ,low 1% medium50% high100% ,no temp control ,always start from low ,no memory,size i dont care 20-30mm will be fine, prefer the ones with hole in the middle.
what shall i get ,what it will cost ? (worldwide shipping)
I wonder what kind of output you could get with a fet driver in the MF01? Over 12k lumen?
I think the xpg3 when pushed hard can do 700 lumen. Stock it’s doing 12k ÷ 18 = 667 lumen each. When taking into account the voltage sag you might not get any higher output. So I guess the real improvement is the user interface.
Scratch that. The xp-g3 can hit 1800 lumen at 8 amps! So there is definetly more potential there.
I think the “3 level” choices are:
5 35 full
10 35 full
2 20 full
2 40 full
In either ascending or descending order.
These need to be checked though as Narsil was not fully ported over to 3 channel use. For instance, one of my 3 level settings was only 2 levels. The documentation is not correct for 3 channel use.
One of the Bistro UI might be better if you want non ramping.
