+ 1000000000, as I meekly wait for my replacement X40 carrier which is now in Guangzhou…and when it eventually arrives, put it to the test, simple as that.
Just to think how much good some of those angry guys “with” influence could do it they set their mind on cleaning the world from UltraFire batteries, they could actually be useful…
Ha ha ha…this is a good one…Strictly speaking, If the X60 ever explodes and cause casualty accident in America, he becomes the Co-murderer as he has started the GB and when product’s defect was discovered, he interfered and advised Authority not to take action on the import ban.
Ok…put jokes a side, safety always comes first and we should give all some rooms to move around. Let’s wait a while and see what will turn out to be the solution provided by Bella. She somehow will be judged fairly with all the expert here after they test it.
Since it takes time to test each carrier carefully, we cannot replace all those who sent emails at the same time.
As the new carriers become available after testing, the shipping out of the carriers is based on the chronological order of the emails as received by Acebeam.
To all those who sent us emails, please be more patient and surely your turn will come up and you will know it when you receive a shipping notice from us with a tracking number attached.
the new battery carrier looks similar to the original one except it is now labeled as Acebeam, if there’s something you guys want me to do/test please feel free to suggest, i’ll try my best to do it.
i’m guessing do several run tests and check the cell individual voltages with a DMM periodically, ( after 10 minutes run, 30 mins run, 1 hour run, etc. ) then do charges with cells in the carrier in the light using the light built-in charger port and after charged check the individual voltages again with a DMM to see if the new carriers keep the cell voltages close to linear with each other during the drain and charge tests.
You have to get at least 3 pcs new, never been charged or discharged cells ( implies: same capacity, same brand, same mоdel, same batch), then you should charge them with quality charger like Opus BT-C3100, after charging leave them resting for several hours, after that you should test voltage and pair 3 pcs with identical voltage, if there is difference of 0.01V you should not use that cell for the test.
When you have 3 cells with identical voltage (up to second decimal place) them insert them in the flashlight and use them until they are at about 20-40% of their capacity, basically drain them. before you start charging them again, write down voltages of individual cells, put them back in the flashlight and use built in charger for charging, when light signals that they are fully charged measure individual voltages again, write them down. You have to repeat this discharge-measure-charge-measure process at least 3 times (preferably 5 or more times).
Only then you will be truly able to comment results…
PITA job if you ask me…
To get conclusive and usable data every test MUST be carried several times (regardless what type of the test it is), 2 is bare minimum. Point in multiple discharge-charge cycles is to use cumulative effect and try to achieve “significant” consistent difference. If you charge cells only once and then measure difference of 0.01V that will tell you absolutely nothing, it could be your multimeter or it could be to the cell or to the battery carrier, one cell could have slightly lower IR, charge faster, charging could be terminated several minutes earlier, voltage could sag for 0.01V (or whatever V).
Also I forgot to mention, during test cycling individual cells should not be moved (they should alway be charged by the same IC) after completion of several circles in this setup cells should be shuffled so that different IC would charge cells and test should be repeated several times, this will rule out and differences in cells them self.
Optimal number of tests should be 9 (3 discharge-charge cycles x 3 charging ICs - so that each cell would be charged 3 times by each IC).
This is related to X40 battery carrier of course, I do not have X60…
Not sure how you came up with the obsession thing but it’s pretty easy to understand why would you repeat test 3 x 3 times:
Battery carrier holds 3 cells (again, I am talking about X40 since I don’t have X60) and has 3 charging IC-s (Integrated Circuits).
You also have 2 variables that can affect results, properties of IC-s that we are trying to assess here and properties of cells.
You following me?
If you charge 1 cell via 1 charging IC only once you will have the result but you won’t be able to know what influenced that result. You have to repeat test at least one more time to check for consistency, if you get the same result that is great but if not you have to repeat the test.
Since battery carrier holds 3 cells, uses 3 charging circuits you want to charge each cell with each IC this way, if the same result is following one particular cell you will know that the result is cell dependent otherwise, if particular IC archives same results regardless which cell is charged that means that the result is IC dependant and this is what you want, you also want for this results to be repeatable and that’s why is recommended that the test results are repeatable.
You can ofcourse charge 3 cells and write down those results but they can’t be used as serious arguments.
The carrier has circuits in it. I would do a drain test on the carrier also.
Have it sit “out” of the flashlight with three balanced and equally charged cells, with matched voltages at the start time, then check the voltage of each cell a week later ( or even a month later) to make sure there the parasitic drain is equal. Though the Charging voltage cut-off is more critical and more important.
