I brought a pair of Redilast 2600 mAh batteries they took 19 days to get to me in Australia, they are $14.75 USD each pluss shipping.
First impressions well made nice thick wraper, good quailty cell,s and they look nice for a battery lols so i gave them a quick check over.
Cell A 3.78 volt out of the packet, Internal Resistance 94 milliohms
Cell B 3.78 volt out of the packet, Internal Resistance 94 milliohms
Cell A Discharged to 3 volt (they can go to 2.75 volt) and then i recharged at 0.5 amp
Cell B Discharged to 3 volt (they can go to 2.75 volt) and then i recharged at 0.5 amp
These have to be the closest matched cells ive seen, so far i give them the thumbs up.
A quick description of the above tables
Zenit [s] is time of the charge, it is updated every 2 seconds.
Input [V] is how much volts my power supply is giving my Ichager 106B+
Voltage accu [V] is battery voltage
Current [A] is how many amps the charger is charging or discharging the battery or batteries.
Capacity [mAh] is how long the battery will last under load. A 2500 mAh battery should be able to give 2.5 amps for one hour till empty.
I will do some high draw dish charge test when i have time.
