【The SOFIRN budget EDC buck light new release soon】
Hi BLFers,
Now we have got the parameters of the SR12 from the factory.
Parameters:
Emitter : 1x SFT-25 6000-6500K
Max Lighting Distance: 396m
Battery: 1×18650
Output: 1450 LM
Driver: buck driver
Charging Connector: USB Type C
Water Resistance: IP68 waterproof
Mounting Type: Magnetic Mount
Cap Shape: Crenulated Bezel
Size: 25(head diameter)*112.5mm(length)
Weight: 65g(without battery)
If you want to participate in the review of SR12, please enter in our lucky draw.
:boom:Giveaways: 3 * SR12
:boom:The entry rule: Leave the comments in this post
:boom:Deadline: November 29
2024-11-25 updated
Hi BLFers,
We mentioned a few days ago that we were planning to release the New SOFIRN budget EDC buck lights soon.
Now we have gotten the new EDC buck light prototype(SR12) from the factory and SR12 prototype has been briefly tested. But, the parameters of the prototype are still waiting for the factory to provide the data.
This SR12 is comfortable to hold and its size is very portable. Here are some comparison pictures of the SR12, SP35 and SC31 Pro. Please see below.
2024-11-21 updated
Hi BLFers,
Sofirn SC31 pro and Sofirn SP35 have been released more than 3 years now, and we’re not sure if the two models still suitable enough for people used. After careful consideration, SOFIRN Factory decided combining the advantages of both two models in one.
Also, SOFIRN engineer just told me they have been completed the testing of the prototype, and I’ll be receiving the samples within the next three days. Before the prototype arrived, we hope to get more opinions or ideas on community.
What do you think makes a high-quality budget EDC buck flashlight? What features, specifications, and innovations would you like to see in this new flashlight? Producing a best budget light is our goal forever.
7 Thanks
I have both models, so I’m fascinated to see what comes of this combination!
In order of importance:
  1. Anduril, Anduril, and Anduril. You have it already in the SP31 Pro, so please keep it on the new light.
  2. Ditto, the regulated driver from the SP35.
  3. Please use the ATTiny1616 (or even better, the new AVR32DD20) and standard 3-pin flashing pads in the @gchart/@thefreeman layout (ground on center, positive and signal in the extremities) – I think you do it already in the newest versions of the SP31 Pro.
  4. Please stop using that awful SST40 LED – nowadays at least the SFT40 is the minimum acceptable. There are also other nice LEDs around (and I’m pretty sure other posters will be giving you a piece of their minds about them :smiley: ) , but I’m familiar with the SFT40 and it really rocks when compared to the SST.
  5. RGB Aux LEDs on the switch would be nice. Ditto USB-C port for charging and powerbank (aka reverse charging) capability.
  6. Also please keep the reversible tube from the SP31 Pro, ditto the magnetic tailcap option.
That’s what I can think of for now. Thanks for asking! :+1:
9 Thanks
Do you mean Anduril+Buck driver ?
That is the most thing I would wish for. Anduril + Buck. SFT40 5000K please :slight_smile:
7 Thanks
Both of these model will be excellent with BUCK constant current driver.
SP35 already has regulated output, but it should be updated to be even more efficient.
You can call them SC31 Pro ‘C’, and SP35 2.0 - or SP35C.
I don’t mind UI of SP35, but if you make BUCK version of SC31 Pro, it should remain ANDURIL 2.0.
I will buy 12 pieces if this model is created. :+1: :+1: :+1:
I would like to see, in addition to an efficient constant-output driver:
  • lower CCT choice of the emitter <=5000K
  • 18350 tube option
  • a rotary jog dial switch like in IF30 and/or an indexed dial around it (like in DL08) - anything that would limit the proliferation of the Morse-coded, multifunction button :-). An on/off button is great and functional but it becomes a liability when attempting to assign too many functions to it, I recon.
Might be an unpopular opinion, but I believe a simple UI version is needed if the desire is to be recommended for family and friends. Don’t get me wrong, I’d want the Anduril version but I can’t say the same for my coworker or their family.
I came to appreciate a good button and protection as well. The Emisar D3AA with a raised button retaining ring and very affirmative button press make me able to pocket carry without fear of accidental turning on.
9 Thanks
Perfect! You are right it’s time for a refresh. Please give us the option of Anduril and a simple UI. Anduril because you can adjust the thermal limit and it has the best smooth and stepped ramps out there.
Also, no more sst40. There’s much better 5050 size or 3535 options like xhp50.3 HI, SFT40-w, sft70, or sft25R. I don’t think the 519A is good enough for a serious EDC light doesn’t throw enough or get bright enough with a regulated driver).
  1. Stick with Anduril
  2. Power bank function would be nice in EDC flashlight
  3. Maybe You can design nicer looking switch? Something like Wurkkos did with FC13
  4. Neutral tint LEDs as standard and Nichia 519A version - 519A 4000K would be great!
  5. And most important of all, but You’re already at it - buck driver
I currently own 4 SC31 Pro.
  1. My biggest issue with them is the beam, it’s Very Ringy.
    I believe the reflector is to blame.
    It’s also Very Ringy with a SFT40.
  2. The pocket clip needs a redesign. No need for a 2-way clip but a deep carry clip would be great!
I also own a fair number of SC31 Pro and a few of their step siblings the Wurkkos FC11C
Currently the FC11C us my go to EDC light as it checks a few more boxes on my list of features I want.
The features I want in a single light are
1, 18650 and 18350 compatibility, Smaller for EDC but the option of swapping for a larger battery for runtime in needed.
2, Aundrul UI, mainly for the ability to customize the step settings and for battery voltage checks.
3, Regulated Driver for constant Brightness and better efficiency.
4, High CRI LED, I strongly dislike the harsh light that low CRI LED’s produce, The 519A seems like the best current option
5, Choice of warmer/neutral color temperature, My preference is strongly toward 4000K as a good tradeoff.
The current SC31 PRO only checks off the first two. The FC11C checks off everything but Anduril.
In my opinion both Anduril and a regulated driver are needed for a 18350 light to truly make the most out of the limited capacity the battery has. the FC11C is really good but I lack the ability to fine tune the brightness vrs runtime tradeoff. Only having 3 steps (not counting moonlight and turbo) is really limiting. On the other hand the ability to sustain high with only battery capacity being the limit is very impressive. My SC31 Pro lights cannot match it.
Who ever Figures out how to put all of these things into a light in the price range that these lights are in is going to have a winner and sell lots of them. We are getting closer with every new release from Sofirn and Wurkkos, Eventually one of them will make the light that I suspect lots of people really want. Just look at how much attention the FC11C got since its release and how much the SC31 pro is still recommended as a good light the try and see if you like Anduril.
Unno, I still say a nice TIR lens would be way better than a reflector. 20mm is as much of a “standard” size as you can get, and can be swapped out for anything from a narrow spotlight to a wide floodlight.
So maybe a SS bezel that unscrews and holds in the lens (and possibly a reflector of the same exact dimensions, for those who still favor reflectors) would make a customisable light as far as the beam, swappable quickly and easily, vs disassembling a glued head to get to the reflector/lens.
The only clips I don’t immediately pull off and promptly “lose” would be true deep-carry clips, one way only. I don’t intend on having a full-length tubelight sticking off a cap’s brim like some light-emitting banana, so 2-way clips for huge lights just seems retarded.
Dressing up a light in a clown-suit (aux lights, goofy blinky modes, etc.) is waaaaaaaaaaaay down my list of must-have features. They can be nice for a toy-light, but almost all of my truly must-have lights don’t have any of those “features”.
Next time, it might be a good idea to involve the community before creating a new prototype, rather than after.
Here’s my wishlist:
  • Efficient Driver: Preferably buck or boost for optimal performance.
  • Anduril UI: Must-have, with flashing pads for customization.
  • As Slim As Possible: Essential for a comfortable pocket fit. Thin body tube walls with no empty space inside. No aggressive knurling.
  • 519A LED: Excellent CRI with the flexibility to dedome for a warmer CCT with rosy tint.
  • Magnetic Tailcap: Use a strong magnet so it holds even on curved surfaces.
  • Backlit Button: Configurable RGB or red.
  • 18350 Short Tube: Optional accessory. Make it as short as possible (e.g. not for button tops).
  • USB-C Charging: nice to have.
  • Optics Options: Offer both a reflector and multiple TIRs with different angles as accessories to allow beam shape fine-tuning.
The SC31 Pro comes pretty close to my ideal, it just falls short in a few areas:
  • Needs a buck driver.
  • SFT-40, ideally in 5000K.
  • I would prefer a TIR over a reflector, but please put a glass lens over it.
7 Thanks
Starting from humble origins as the first entry level model, the SC31/SC31B/SC31 Pro had proven to be pretty successful, by focusing on getting the fundamentals right, and not adding superfluous features.
At the time, IIRC, the Pro was the least expensive light available with Anduril, and brought it to a wider audience at a low entry price point. The micro USB port gave way to a Type-C port.
Its cousin, the FC11, brought a high CRI emitter to the game, along with a more modern look, and magnetic tail.
I hope this next iteration is a further refinement, and not an attempt to reinvent the wheel.
Nor spring unpleasant surprises like auto lock on users.
More modern emitter. Improved driver. Updated optics. Improved clip and magnetic tail. Even some spiffed up looks.
All would be welcome, but don’t mess with the basic formula. It doesn’t need to be anything that it isn’t already.
Nice, but no Anduril :frowning:
Its nice to see Sofirn making a good thrower flashlight. This is going to be a very interesting light, and would like to try and review it for sure.
I have an SC31 Pro, so would be very interested in doing a side-by-side comparison with this new model!
In for the giveaway!
I love SFT25+Reflector lights, and throwy compact EDC with buck driver is going to be matching great with my preferences.
Great work!
