It appears that’s the answer then. Thank you!! It’s one of those things that are so simple that slips our mind and bamboozles us when we stop to think about it lol. Just like those convoy lighted tail switches. It bugged me for a while before I asked to you guys. Thanks!
I guess you figured it out but you should still buy a $3 usb thing that shows you volts and current going in they come in handy sometimes.
Also, if it’s an old or really abused battery sometimes the self discharge is faster than the charger end point of the CV charging stage. Like if your charger is waiting until current drops to 10mah to cut out, and micro usbs do wait to get that low sometimes, especially if it’s a real small battery, but your battery is so messed up self discharge is higher than 10mah, the charger will just keep trying until maybe some timer just shuts it off.
I’ve had cells from an old gaming laptop that ran at 100% charge and like 65°C it’s whole life and it’s self discharge was higher than the 100mah cutoff my charger was waiting for.
Also important to know is that since the tail switch does not completely electrically isolate the battery from the body of the light, these types of lights can have parasitic drain similar to an e-switch light.
From forum member SammysHP thread titled "[Review] Sofirn SC31T (with tail switch!)":
Oh I got one. Who makes a flat-top adapter for the sofirn sp36/q8’s like the ones convoy uses? I know somebody must make them. Its just a plastic disk and some brass buttons. I assume sofirn doesn’t make one because of something to do with the onboard charging? Just a guess. But I never use that. Somebody makes an adapter right?
I missed his review of that light…thanks for sharing that tidbit and good to know about the small drain. I hadn’t even thought to check for that on this light, assuming the tail switch was “normal.” I’d be interested in knowing more about how this circuit is laid out. Maybe Sammy or thefreeman will happen by here and explain. I was a little surprised when the light turned off as the cable was connected…clearly not the typical charging circuit.
Have a look here. If you find it, it might be available on amazon or ebay for cheaper, or with free shipping or something. Streamlight branded clips sorted by price.
I was looking at getting a spare Apple Lightning USB cable recently, but noticed the pins looked different on the one I was going to get. There’s 6 pins (or “contact pads”) on it, with one apparently “skipped.” This is in contrast to the one I have that has 8 pins.
So does anyone know if Apple changed the Lightning specification for the iPhone 12 and know if that version of the cable is compatible with older iPhones and iPod Touch? Thanks!
Between Convoy M21B and Fireflies P03, which one would you get for 2700K Dedomed? One is tiny other has better runtime. Is there any difference apart from that?
If I wanted to use an optic in front of a mule flashlight to give it a bit of throw (nothing significant like a reflector or TIR), what would be useful? Would a thicker lens (aspherical) give the most throw, or would it create a donut? Is it preferable to have a double-convex lens? My plan would be to seat it in a plastic collar that I could place over the head of the flashlight for occasionally narrowing the spill a bit.
