I think both your lights are too close to say. With the tk70 putting out twice the lumens, all the air in front of it and the camera is too lit up. I really think the only way to maybe tell the victor is for the camera to be down close to the barn. And even then you might have to have the lights even a little further like 550m or 600m. On my long distance testing and shots that’s about the only safe wa to tell when you get distances in the ranges you are shooting at. Unless of the lights are markedly different in throw - which isn’t the case with your two nice throwers.
Irregardless they both do a great job for certain they both very close in throw.
And thanks for taking the time to do all the shots.
ILF, it helps. But more to make me think that your TN31 and TK70 is equal in throw.
I cropped and resized the last two barn pictures as below, and still difficult to call who is winner here.
I know it is difficult to get the beams pointing at remote target so it could have some error for most beam shots pointing at remote target. I didn’t pick any pictures, just that someone ask for help in the thread to zoom in and so I did but I don’t know how to do mouse over.
And I just look at the first set, because the way the beams lights up a lot of particles in air with reflection, I don’t think it is as good as the last set for comparison. It could be brighter caused by refection. Just my opinion.
You know, you may have something there. So should we say they are about equal in throw, or should I just go do a slower shutter speed at some trees say 220yds or so away?
This is a lot less hassle and usually provides more conclusive data by eliminating variables.
Take a picture with both of them shining at a surface (at the same distance of course). Under expose it like crazy until you can distinctly make out the hot spots. Then you can make a mouse-over of the two hot spots and see which one is brighter.
Look at the brownish-leaf tree at the right side of the third post. It is even behind (meaning farther) than the barn.
Which do you think throws farther? Isn’t it the 70? Look a post #61. Somehow both pics does not appear here.
It can be 1 meter or as close as you want, as long as the light doesn’t saturate the picture. If your camera can’t take fast enough exposures then of course you’d have to move the lights further away to lessen the intensity of the hot spot.
It’s a bit fast, but decreasing shutter speed would only make the spots brighter, and the difference between the two would still be nearly indistinguishable.
