I guess I’m the unmentioned Customer C then since I only got 4 out of 5. Were those V1’s made with cockroach parts? They seem harder to kill than anything else in my collection.
No need to hit 2c, which I never have with either light. By the time you get to top of ramp smoke is already coming out. But you can think there wasn’t really a problem with the lights, which required a change, and that it was just user error if you like.
LOL
you dont wear a baseball hat?
Hmmm. Between the ones I have and the ones I have gifted I have had 25 of them go through my hands. Some of each version and type of material that they ever offered. A V1 spent an average of 18 hours a day every day in my pocket for the best part of 3 years. Early on, I bought and used nothing but the Vapcell H10 cells. I used that light a lot. I have not burned an LED on any of them. Nor has anyone that I gifted one to.
Perhaps I was just lucky. But I did disable turbo on all of them. Well, except on that V1 I kept in my pocket for all of that time. But I trusted myself not to push the little light beyond what it would take…
This doesn’t mean that I don’t believe that you had the problem. But possibly you are just unlucky with yours and the problem was not as widespread as you think. Sure Wurkkos took steps to protect us from ourselves and reduce occasional failues… but that only makes sense, yes?
Maybe the light took your handle to heart… Thermolumo? ![]()
Avoiding Turbo is the key solution to avoiding smoking problems.
Ceiling in Smooth Ramping is also a problem with the original firmware. Because in the original firmware Ceiling in Smooth Ramping is set to Turbo by default.
There IS a problem with Ceiling in the original firmware. Ceiling in Smooth Ramping is set to Turbo by default (level 150/150).
So even people like Thermolumo, who do not intentionally use 2C to reachTurbo, are still actually using Turbo. When using original firmware and ramping to Ceiling in Smooth Ramping.
This Ceiling = to Turbo setting became even more of a problem with the new batch of CSP LEDs. Because they burned more easily on Turbo and Ceiling = to Turbo
Never happened to me. Ever. Even the 219b went without a puff. Granted, I only have 12-13 of 'em, so I might just be lucky. Not saying it doesn’t happen, but I feel that if there was an inherent issue then the odds are so astronomically against my expereience being even theoretically possible that I apply Occam’s Razor.
I also know that some folks use too much flux when soldering, and don’t always clean up after themselves. Seems far more plausible than the exponential odds of me and Mandrake being lucky AF.
It’s also how I know a post that claims to be from you is actually from YOU ![]()
Seriously though, a part of me suspects that my “luck” involves not spamming Turbo when the rampdown hits. IMO, thermal rampdown is there for a reason, and overriding it never ends well.
When was that? I mean, I know that the V2’s had an issue with the revised CSP2323 being inferior to the old ones and blowing until they revised the firmware, but every single one I’ve had has a definite difference between ceiling and turbo. I don’t adjust the ramp on most of my lights aside from setting the ramp speed to half-speed.
Do any of your TS10 have 2023-07-29 firmware?
TS10 lights with Factory firmware version 0713-2023-07-29 have Advanced Smooth Ceiling set to Turbo (level 150):
TS10 with Advanced Smooth Ceiling lower than Turbo started in lights with Factory shipped firmware 2024-04-20. Lights with this firmware do not smoke, not even on Turbo. No ceiling change is needed, and it is not necessary to disable Turbo.
TK lowered the ceiling starting with firmware date 2023-10-31. But it was not a Factory shipped firmware. It was only available to people who know how to reflash.
For people who have a TS10 with firmware 2023-07-29, possibly including @Thermolumo, if you want to lower the smoking Turbo Ceiling, and disable Turbo, read the instructions in this thread
These Turbo and Ceiling issues do Not apply to the new TS10V3.
I should have mentioned that I set (per your suggestion BTW) top of ramp to 110/150 on all of the lights that I gifted. Not so much because I was worried about burning LEDs (which I am sure would prevent) but because it is closer to the sustainable output for the little light. On the ones that I kept, I set it at 125/150. Trusting myself to use that level in a way that would not kill the light. I guess the fact I have never had a burned LED , or otherwise killed a TS10, indicates that I have done OK on that.
IIRC, reports of burned LEDs were quite limited . At one point I thought even those were limited to cases where people were using the H10 cell??
That’s the point dude, and why your experience isn’t relevant.
I think everyone’s experience is relevant when a discussion is about how prevalent a potential defect is in a flashlight.
The discussion is not about prevalence but about whether it’s user error or manufacturer error.
The ones I have here and can find are 2022. Old date format and all. Some are MIA… maybe under the stove.
Most of mine are V1.
Like me. I rely on simply releasing 1C when the light is as bright as I want/need, but there is enough variability in how high that is that I would rather have and not use than need and not have. Those who want to limit themselves for simplicity are fine doing what works for them, but I don’t roll that way.
Yeah, that can be a problem for something that often finds it’s way into the hands of those who haven’t been doing techy nerdy things for decades. Then again, the previous point makes it moot for me.
Unless your intent is to substitute your opinion for actual observable fact that also aligns with what another independent observer has also seen, I say that my experience is quite relevant. Moreso than gaslighting.
I never outright refuted claims of burnt emitters, merely cited a statistically significant number of counter examples that are of sufficient quantity to avoid Fallacy of Composition.
Given that different batches are different and that there is notable variability even within a particular batch. I’m not sure “error” is entirely correct. It many be of note that most of mine are the older ones with tougher emitters. It’s also possible that there are differences in manufacturing technique since most of mine were made, or maybe the soldering department used a different brand of flux, or less of it.
I cannot say for sure, only relay my experience to compare notes. And I’m the type of person who lets the weight of the evidence determine the outcome rather than simply dismiss evidence that does not confirm my hypothesis.
That said, I think that going forward, it would be good to limit output to the emitters of a V3, whether in firmware or hardware. Given that 14500s range from 3-10A, software limits are a little tricky, but using a tiny boost/buck driver drives up cost compared to FET+X, and much of the appeal of a TS10 is the low price.
It seems that 90 lumens is a good guesstimate of sustained output, though I was never quite sure where that was on the 1-150 scale. Coincidentally, it’s right around where the light goes from the 7535 to the FET.
I think it is closer to the 250 to 300 lumen range. Mine will run at that level for a good amount of time and not get too hot… nor destroy themselves. Battery is not going to last long though. When I want something to use at that level for longer periods, I grab a bigger light.
I like to TS10 because it is a handy little tool to keep in a pocket for short term lower light level requirements. Around the house for navigating at night (heck for that I usually use the floor setting that I have set for maybe 10 lumens). Looking under furniture for that part that escaped. Reading labels on the back of gear in an equipment rack. That kind of thing. Most of those can be done easily at under 100 lumens. Higher levels and the ridiculous “turbo” ( on the earlier versions) are strictly a gimmick to impress people for a couple of seconds and used very, very infrequently.
fwiw i just received and posted a review of the TS10V3
its a very handy little light.. and does not smoke ![]()
Does it vape?
Or maybe “chew” ?
about clips..
the EO5 clip is too tall at the top and would not allow tailstanding of the TS10V3
the HD10 clip is a better height:
Please vote in the New Poll.. Fancy Metal TS10V3
I just received a sample of TS10v3 too, but haven’t done much with it yet. In part because I’m recovering from a covid shot and I feel like I got rolled around in a tumbler for a few hours… everything hurts… and in part because I’m still healing from a throat issue and coughed up some blood this morning…
… but also because it’s sticky.
I opened it, touched it once, got some sort of yuck on me, and put it away. Dunno what’s up with that, but … gross.
Why. Is. It. Sticky.
Should probably go wash it so I can start on the firmware.
feel better soon!
