Great news Glenn. Get those batteries charged so you don't make us wait for your impressions. Also, I found making the battery carrier mod on this torch makes it a bit easier to use 3100 cells. It doesn't require it nearly as badly as the DRY did, but it does make it easier to load and unload the higher capacity 18650's.
It came! It's built much better than the Dry, and seems to be as bright so far. I'll test it tonight outside. There's absolutely no battery rattle! Feels more secure in the the hands. As you can see it's quite a bit bigger than the Dry. I'm freaking happy!
The Dry has a larger hot spot at about the same brightness shinning on a white wall about 10 feet away. I know this isn't a way to compare, I'll do that outside tonight. So far I'm thrilled with it.. BTW, I weighed both of them on my digital scale. The Dry is 476 grams with batteries, and the UF-T70 is 673 grams also with batteries
With the tail cap removed and the battery carrier loaded in the body, I used my DMM and simply touched both soldered connections where the switch attaches to the board. Tapping one of the leads switches modes and it doesn't make a difference which side you place the leads on.
FWIW I've attached a plot of reported lumens versus measured lux for my lights from my shoebox lightbox. Of course it's not a calibrated integrating sphere and I'm using a luxmeter that you can buy on Amazon for $13.32 ( http://www.amazon.com/Light-Meter-LX1010B-Luxmeter-display/dp/B000JWUT6O/ref=sr_1_2?ie=UTF8&qid=1331259688&sr=8-2 , but I think it does a decent job of quantifying relative brightnesses. Using the key at the right you can see how the lights stack up against each other and from the regression formula, my estimated lumens for this light is 2100.
EDIT: Updated the regression model and plot with 2400 reported lumens per UltraFire website (as opposed to 2500 from hkequipment) which improved the R-squared and slightly lowered estimated lumens to 2100.
