Hi All,
This is going to be a different sort of build thread as I’m actually only doing it for one fella. My uncle recently asked me to build a brightish, high CRI, side switch flashlight for “light painting”. Near as I understand it this is a photography technique involving dark and light. Point is, I recently got him to buy his first set of eneloops and now I get to build him a real flashlight. Many of the techniques here is old news to many members here but the old uncle is a complete muggle, so enjoy the pictures I took using dark and light.
Short version is that we’re stuffing four Nichia 219 90+ CRI emitters into a blue 2D mag and driving them to 3+ amps each with 8 eneloops in 4S2P electrical configuration. We start by tearing down the maglite.
Then we tear apart the switch.
Then we throw away this sh… stuff, cause it’s useless.
Let’s focus on the switch and driver for an hour or two. Start by cutting that plastic tube off the switch.
Cut the tab off the end of the negative path/switch anchor, solder an 18 gauge wire to it and put it back where it goes.
Now we’re working on the driver but still working on the switch. We’re going to solder all those little parts to the circuit board designed by a member of this very forum.
But first we need to program that little spidery looking chip for one mode operation. Yes I could just use direct drive but I’m expecting over 12 amps to the emitters and the driver allows me to route power around the switch mechanism. First step is to pinch the chip in the blue cloths line thing.
The blue cloths line thing is connected to a complicated looking thing that connects the chip to a laptop in a process known as “magic”.
This is “C” coding of a firmware known as “STAR”, also developed by a forum member. I’ve tweaked a few things and removed all modes but “high”.
The program spits out a “hex” file which we save to an appropriate location on the laptop.
Here we see a bit of code which loads the hex file onto the little spidery chip. We can also see a lumpy creeper with a camera.
Done! Avrdude is always so polite despite all the names I’ve called him in the past.
Next, we solder the chip onto the driver and give it a test.
Now we solder a wire from the positive of the driver to the positive of the switch. Coil the wire and glue the driver to the switch.
Now we drill a hole through the switch body and run an 18 gauge wire to carry the main current to the emitters.
The switch/driver is ready to install!
Onto the head of the light.
First we make a heatsink out of 1.875” aluminum rod, the major stages are in the pic below.
Here are the emitters on noctigon and the centering rings to be used.
There isn’t enough room in the head to fit everything in so we need to measure how tall the new innards will be.
Then comes mathing and puppies.
Having a reasonable depth, we proceed to the basement to ream out the head with the dremel and metal cutting bit.
With the head a bit deeper, we can epoxy the emitters to the heatsink and wire them electrically in parallel.
Once we wire the emitters to the switch we can install the whole thing into the light and then install the reflectors, lens, and bezel.
To be continued in the next post…
