I have a thorfire s70, of the old ones, just add r100 on resistance just like convoy L6 and get 7amp on the tail, it does not need to desolder, just remove the ring, the biggest difference in favor of convoy is choice of dyes and better Quality of construction and components in general, thorfire is not bad, but L6 is better, regards!
Please stop fanboyism
I am gladly going into debate about which is better yet not in a topic specifically about either one of them
My S70 and L6 both run on Liitokala cells
I checked the anodization inside both tubes and both do not conduct
I use a magnet in between the cells
When it is time to recharge I take the cells out, stick the little magnets to the other cell and thus every charging the cells swap position.
Hi The Miller, I used to use magnets on cells that wouldn”t make contact in series with no problems but noticed after taking some tail cap readings that with magnets I was seeing the best part of .5A less current than the same cells without magnets (solder blob, Jaxman cell connector or bend the positive slightly upwards).
This was with Liitokala 26650”s in my S70.
Now I don”t know if the magnets I was using (N52”s I think) were just particularly poor at conducting & adding a lot of resistance & other magnets are fine but that is what I found anyway.
I have stopped using magnets because of this.
It would be interesting if you took a tail cap reading with fully charged cells with a magnet then either solder blobbed them, used a connector or bent the positive & took another reading
Ofc X70 is better than L6, yet Thorfire support sux great time- i asked them many time for spare drivers( not free ofc) , hosts, other spares and various other stuff and they NEVER responded me- that makes the user sad…
I have to admit, in my memory the S70(S) looked better than it actually does…
And frankly i think the L6 in matte black looks pretty good actually.
But for 37 bucks i couldn’t resist buying an S70S.
Can you recommend some good 26650? Some posts said to use protected as this light has the batteries in series. I already placed an order for 2x26650 thorfire batteries on Amazon but the seller seems fake as they are being sold for $5.
I have 2 S70 lights. One with both springs bypassed, solder blob, and 18AWG from driver to led. For the price this thing is a monster. But, even more impressive is that I dropped the modded light from chest high straight onto my concrete garage floor. It was like watching it in slow motion. It slammed into the concrete and then bounced back and forth from head to tail about 10 times. When I picked it back up hardly a dent in the fender. The only blemish I found was one of the aluminum edges right around the tailcap button had crushed in slightly. If you didn’t know where to look you would never notice it. So, it may not be the prettiest light to some, but I can attest it can take a good beating.
Yeah same here, I use my S70 every day and it looks good
Big drop on concrete caused a dent in the bezel but it is hard to see since the ano is so thick and did not chipped off.
The L6 draws 5.25A at the tail for 3800lm. I believe the S70 might pull the same or maybe up to 6A (corrected = 5.5A). I don’t know if the S70 can be easily modded like the L6 with a resistor due to the different driver, but tail draw can be increased to 7 or even 9 amps. It’s a nice bump up in brightness. So getting batteries that can do 10A are a smart choice.
