ohaya, that heat sink looks fine for emitter testing. Just put a dab of thermal compound on and stick the emitter to it. If you want, you can drill holes and tap them for screws to ensure the emitter doesn’t pop off while testing. I did that for integrating sphere tests; I just hold the heat sink up to the hole in the sphere.
I decided to go ahead with the direct drive build with a 0.5 ohm resistor, using some Kapton tape instead of the heat shrink tubing. Also, instead of soldering the resistor lead directly to the pad on the Noctigon, I connected a short piece of 24 AWG silicon wire to the resistor lead, and connected that to the Noctigon pad.
I just got that done, and it’s working, but the original DST driver (now the contact PCB) doesn’t want to stay in the pill… it keeps popping out. I guess with all of the removing/putting back, it must’ve gotten loose. Any ideas how to get that to stay in the pill?
Yes, they are available in Canadian Home Depot stores - but the staff will have the same difficulty that the US guys had back in Feb.
The SKU shows up on their inventory - but with no “home” location, so you may have to search around the store a bit to find them located in their display box.
The display was in the (wait for it…) flashlight aisle in the HD I was in. I would not be surprised if other HDs have in next to the drywall or the garden gnomes. Seems to be random sometimes.
ohaya, yeah I was thinking just on a small part of the edge.
The solder wick idea would work as well, I’ve done that before. Getting the thickness right can be a pain though.
I’ll try the tape, but it’s non-conductive, so I’ll have to be careful which part of the edge I cover. Actually, I just had another thought: Maybe try a thin piece of aluminum foil on the edge, instead of the Kapton tape? That would add to the diameter, but also provide conductivity, right?
That would work too, and give the conductivity.
I was thinking tape would be OK, with conductivity from the other side of the driver.
Foil is a better option if it can me placed right without hitting something else.
I always thought that adding copper wire to various light springs was a little too cork sniffy for me. I was wrong.
I was taking light readings with my new FT driver in the HD thrower and found that when I used the A8 tube with the extra switch instead of the long tube with a spacer and a 18650, light output dropped from 31k to about 27k. Say what?
So I soldered some copper wire in the tail cap spring and in the long skinny spring. I also replaced the glavanized bolt in my spacer for the 18650 battery with copper wire from some romex. Light output zoomed from 31k to 35-36k. It really made a difference.
I’m waiting for a fasttech U3 and a lck L2. I bet those will take the lux up to 40k or so, or that’s what I’m hoping. I got like a 3k lux increase with a standard driver and the u3. I also have some 4a drivers on the way. This driver is 2.8 and the light never even gets warm after 30 minutes. I’m hoping it can take the extra heat of a 4a driver and reward me with increased lux output.
Thanks. FYI, right now, the pill is pretty much empty, except for the resistor and wires. I had removed the 8-pin IC already from the original DST PCB, but left the resistor. I also ohmed the lead to the emitter negative pad, and confirmed that that is shorted to the negative trace on the spring side of the PCB, so everything is truly direct except for the battery positive to the emitter positive, which has the 0.5 ohm resistor in series.
I’ll have to make the aluminum foil width be as small as possible, so that it doesn’t wrap around either the top or bottom of the PCB and inadverdently touch something or short something, but I think that that’s doable. I’ll post some pics of the whole thing here later, just for the record.
Also, FYI, so far, I’m a little disappointed in this project. The beam is really nice, with a very clean hotspot and lots of spill with no artifacts.
The thing that I’m disappointed in is even though when you look at the beam on a white wall, it’s almost blinding (really), but when I did the lux measurements, from 14 feet (~4.3 meters), I’m only getting about slightly less than 1500 lux, which is only ~27735 lux @ 1 meter. I also took the light out last night, and it lights up a row of trees about 100+ meters away, and also a lot of what is in between me and the tree row, so that lux measurement really has me puzzled.
The LUX reading doesn’t durprise me much. The only light that I modded with an MT-G2 that maintains any reasonable throw is the UF T90 (almost 80mm reflector), which was designed for an SST-90 emitter.
My Zy-T08 MT-G2 mod is in the same ball park. On paper it’s an underwhelming mid-20k ‘thrower’ with monster spill. In actual use, it lights up things quite well, very useable. It’s no thrower anymore, though.
I will probably try one of these with an MT-G2 driven around 5A to see what I can get. Who knows, it might surprise.
I should have been more explicit. The reason I’m disappointed about the lux is that when I first started trying an MT-G2 with the DST, I, at one point, was able to get 2070 lux (again at ~4.3 meters):
Since that post, I had to move my lux measurement setup to a different place, in my basement, and I think that the numbers have been lower since then, but I don’t know why…
Edit: relic, you mentioned “UF T90”, but isn’t the “UF T90” a 4 emitter light?
Off-topic: That light you linked looks similar to the TrustFire X6, which I have.
If I couldn’t get the MT-G2 + DST working well, the X6 was going to be my next “stop”, i.e., I would be looking at putting the MT-G2 into the X6.
However, from reading through the X6 mod threads, it seemed like getting the cover off of the driver was a real pain. The threads I saw said they had to drill 3 holes in the cover to pull it off.
But, it looks like you were able to get the cover off without having to drill holes in the cover?
No holes drilled.
I just pried under the lip of the brass ring thingy. Alternating sides and after a few times it popped off.
The first time it was quite tight ( ) but after a few in and outs ( ) it loosened up a lot ( ).
I really like that light now with the MT-G2. Not sure how the X6 compares internally though, hopefully similar so you can refer to my mod.
If you choose that path, feel free to ask any Q’s.
I have several of the A8 clones and use the body/tube with my DST head to make a “shorty DST” that can run on 1x18650 or 1x26650, but I’ve modified one of my DSTs to use an MT-G2 emitter, direct-drive.
So, right now, with that shorty DST, I am limited to using 2x18350 batteries, and I was wondering if there’re any bodies/tubes that can be used with the DST that would allow 2x26650s or, with an adapter, 2x18650s?
I don’t mind getting some other light or lights (depending on cost) to use as “sacrificial lambs”, i.e., to just use the body/tube with the DST.
