Hi,
I still don’t have my MT-G2 emitter on Noctigon in yet, but it should be arriving tomorrow or the next day.
I’m also still awaiting the 0.5 ohm and 1.3 ohm (2W) resistors and some heatshrink.
In the meantime, I was messing around with the DST pill, using a 1 ohm 3W resistor. I’m pretty sure this is larger than either the 0.5 ohm or 1.3 ohm 2W ones, so I figured if I could cram that into the DST pill, I should be ok with the other resistors.
So, here’s what I did:
- Unsoldered the leads to the original emitter (XM-L) and removed it (it wasn’t glued, just some thermal compound underneath(!)
- Removed the press-fit “driver”/contact board
Underneath the 8-pin IC site, there was a thru-hole to the positive pad on the other side (where the spring was soldered). I cleaned out that hole.
I took the 1 ohm resistor and bent one lead with 2 right angles, such that the lead would go through one of the holes in the pill.
I pushed the other resistor lead through that hole on the contact/driver board.
I then pushed the contact board back in place, and it fit, with a reasonable amount of space, length-wise, still, probably about 1/8 - 1/4”.
So, I think that doing the inline resistor should be ok, size-wise.
I’m thinking that if I put some heatshrink over the lead that goes through the pill hole, I might be able to solder that lead directly to the + pad on the MT-G2/Noctigon.
Then, I could just solder the other lead to the contact board (and through the hole I mentioned above).
I left the - lead on the contact board, so I could then solder that to the - pad on the Noctigon, and then I should be done?
If I can do that, the path from the Noctigon + pad to the resistor would be a SOLID WIRE (with heat shrink around it). I know that usually, the wire to the emitter pads are stranded.
Is this going to be a problem?
I guess that one possible problem is getting the Noctigon to lay flat on the top of the pill with that one lead being solid wire? Also, I’ll have to make sure that that lead wire doesn’t make contact with anything except with the + pad on the Noctigon.
Thoughts?
Thanks,
Jim
Edit: Here’s a rough drawing showing what I described above:
