US - Defiant "Super Thrower" 3C (New Model - +/-64mm Head XM-L) - Get To Home Depot Now!
Checked out my local Home Depot store this morning and low and behold there's a new Defiant light in town! This was located up front in the seasonal deals area and there was an entire display of them. Of course I grabbed one! Only $22.97. These must have just come in stock because I was there last week and didn't see them. I'm at work now, so I haven't been able to even take it out of the package yet, but I measured approx. 64mm across the bezel (I measured 2 1/2 inches and converted). It also has a very deep reflector, fins behind the head, and side switch. I'm 99% certain it's an XM-L emitter. I expect it will need a driver swap, but it should be a heck of a thrower!
Some Photos:
So RUN NOW to your local Home Depot!!! (Those outside the US, or not near a Home Depot store, I apologize.)
-Garry
2000 Post Giveaway - ImA4Wheelr (Winner Announced)
DST using 3 18650's (Finished)
4,000 Post Give-Away! Now Closed! (Available to Non-US / Non-Canadian Members Only!)
Defiant Super Thrower is now $12.00 get back to Home Depot now!
Need driver for 3C Defiant super thrower
Mod: (Updated!) YinHex YH-X9 5xT6 4x18650 Flashlight: Pocketable 45W Wall of Light
*Closed* Keltex78's 1000 post GIVEAWAY!
Mod: HD Defiant 3C Super Thrower 18650 Driver and Emitter Swap
Lens Comparison: Uncoated Glass vs. Plastic vs. Coated Glass
US - Defiant ArmorMax 3D Tactical Flashlight - 3D XML light $29.97 - GET BACK TO HD NOW!!!!
SOLD - CONUS or International - Defiant Super Thrower modified. - SOLD
Home Depot Deal Alerts & Discussion Thread
HD2010 vs Defiant Super Thrower vs other?
Possible 2x26650 host for MT-G2?
Source for 26650 spacer? Or how to trim PVC
REVIEW: Uniquefire UF-1405 (XM-L2 , 2x26650/2x18650)
Lowes seems to be following Home Depots lead in flashlights
(Finished, mostly) DST 2x Protected 18650 and Emitter/Driver/Lens Swap
any flashlights with more throw then a hd2010 for less then 50 bucks?
What thrower next?
AR Lenses - Lets Measure Improvement
are there any 2 or 3x18650 in series flashlight with a side switch clickie out there?
Looking for best ~30$ flash light, trying to get it fast
Good Morning from Montana
The three most popular Budget lights... ( Under $50 )
Anything better than the HD2010 since I've been away?
Thrower gap HD2010 to TK70/BTU Shocker
Need a big head with Deeeeep reflector. Any ideas?
FYI - some 'new' Fujitsu laptop batteries
Brightest Flashlight with a good flood setting
AA or "C"
What have you got on order and why :)
What takes C batteries? Is there such thing as a B battery?
Magic of modern LED's and Utility
Defiant 550 lumen tactical flashlight vs. Defiant 493 lumen flashlight
Are we there yet? - 500 Lms hi on 1 battery 4 hours runtime. No heat...
New guy with Coleman CT-20 LED flashlight
Reminiscing the Defiant Super Thrower (DST)......
Looking for a Thrower with nice beam and spot
Defiant LED Tactical Super Thrower 3C Light At Home Depot
Good Old Times ?
Re : Harbor Freight Tools Quantum 3 D
XML-T6 LEDs STlLL in a bunch of torches.......
Recommend any D cell flash light ?
I wonder how much shipping would be on one of those…… 0:)
Well, us flashaholics just became a little less cool.
Beamshots!
Thanks, Garry! I'll check it out at lunch.
Really interesting find.
Impressive numbers, 1400ft ANSI throw = 45.5klux @1m. And 493 lumens? If it is what it says it is… this is quite remarkable.
I still find it a bit hard to believe those numbers coming from C cells though. Time will tell. Look forward to see more measurements, garry. :slight_smile:
I'll try to get them, but can't promise anything.
-Garry
Nice find! I passed on the first Defiant XM-L but this one has piqued my interest.
45 kCd and only 500 lumens from an underdriven XM-L throws a red flag, though. That’s likely to be physically impossible to have those kind of numbers with only a 5.6 cm (guessing) diameter reflector. Regardless it looks like a great host!
Just read and looked again, it appears the bezel inside edge is 2.5”. Cool.
Let us know what you think of it!
It is interesting that the first Defiant XM-L was rated "550 lumens" for "4 hours" but this one is rated "493 lumens" for "5hours".
-Garry
Sweet find Garry! Now crack that baby open and tell the rest of the story!!! :bigsmile:
This thing is huge. Good sized reflector, I believe 57mm wide, I think at least 65mm deep. Comes apart in 3 pieces, aluminum threaded pill, plastic isolation disk, definitely XM-L. Has a nice hot spot, one brightness level. That's all I can do from here, I'm sure Garry will post some pics later.
Is that a side switch I see? Lflex swap might be possible! 3 nimh C’s will drive an XML at 3 amps I think…
Yes side switch, and yes 3 C NiMh's (even 3AA's in AA->C adapters) should do 3A easily.
-Garry
Yes it is! I should have taken it out of the package and got a photo of it in my hand! Thanks for the feedback on it; mine is still packaged up.
-Garry
Mag-lite could have been doing this, and made in USA to boot. But nahhh…
And Tecmo nailed it. We aren’t quite as cutting edge anymore :frowning:
Subscribed! Great find. I'm looking forward to take-down pics tonight :)
Finish is shiny painted, by the way, not anodized.
I feel like I'm under so much pressure!
-Garry
Haha, who knows, I might just pick one up.
Is it this? http://www.homedepot.com/h_d1/N-5yc1v/R-203418847/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=defiant&storeId=10051#.UP76Oh071Bk
You can handle it Garry! It is very easy to disassemble. I know you will beat me to it as I'm Central time and can't look at it tonight until at least 7pm CST.
Nope, that's the older model many picked up around Black Friday. This one has a HUGE head. I checked the HD website and it's not there.
-Garry
