Application example (simulated)
Nichia NF2W757GR-V3 R70 (6V)
Condition: 350mA, CC driver, 3S12P (18V), 85°C Tsp
Output = 1000 lm
Efficacy = 191 lm/watt
Wattage = 5,5 watt
Condition: 700mA, CC driver, 3S12P (18V), 85°C Tsp
Output = 2000 lm
Efficacy = 179 lm/watt
Wattage = 11,4 watt
Condition: 1400mA, CC driver, 3S12P (18V), 85°C Tsp
Output = 3900 lm
Efficacy = 160 lm/watt
Wattage = 24,4 watt
Condition: 2800mA, CC driver, 3S12P (18V), 85°C Tsp
Output = 7100 lm
Efficacy = 133 lm/watt
Wattage = 53,9 watt
Nichia NF2W757GR-V3 R8000 (6V)
Output = 940 lm
Efficacy = 172 lm/watt
Wattage = 5,5 watt
Output = 1800 lm
Efficacy = 162 lm/watt
Wattage = 11,4 watt
Output = 3500 lm
Efficacy = 145 lm/watt
Wattage = 24,4 watt
Output = 6570 lm
Efficacy = 122 lm/watt
Wattage = 53,9 watt
Nichia NF2W757GR-V3 R95 (6V)
Output = 720 lm
Efficacy = 135 lm/watt
Wattage = 5,3 watt
Output = 1400 lm
Efficacy = 125 lm/watt
Wattage = 11,2 watt
Output = 2670 lm
Efficacy = 110 lm/watt
Wattage = 24,3 watt
Output = 4800 lm
Efficacy = 89 lm/watt
Wattage = 54,5 watt
Nichia NF2W757-F1/Optisolis (3V)
Condition: 350mA, CC driver, 3S12P (9V), 85°C Tsp
Output = 340 lm
Efficacy = 127 lm/watt
Wattage = 2,7 watt
Condition: 700mA, CC driver, 3S12P (9V), 85°C Tsp
Output = 680 lm
Wattage = 5,6 watt
Condition: 1400mA, CC driver, 3S12P (9V), 85°C Tsp
Output = 1300 lm
Efficacy = 113 lm/watt
Wattage = 11,6 watt
Condition: 2400mA, CC driver, 3S12P (9V), 85°C Tsp
Output = 2100 lm
Efficacy = 103 lm/watt
Wattage = 21 watt
UPDATE 190617:
5700K (18x sm503 rfc00 & 18x sm653 rfa00) Optisolis module (9v configuration) prepared for testing in Finland
UPDATE 190628: Maukka’s preliminary test result with Optisolis
UPDATE 190707: Soldering Tips
You can solder this MCPCB with almost any common solder paste, as long as it contains active flux (no expired). HASL surface finish makes solder wet readily on it. Sn63Pb37 or Sn96,5Ag3Cu0,5 works best.
The correct and easiest method to apply solder paste is to use solder paste stencil. Although you can get away with solder wires, it’s a mess to work with and dosing would not be accurate (larger pads will hold more solder). I have found the best stecil dimension for my application using laser cut 0,15mm thick polyimide sheet. You can download the DXF file here.
Adjust the aperture size according to your preferred stencil thickness. Thicker stencil requires smaller aperture area. Never use the “tapping” method to solder Nichia 757 on this MCPCB. It’s a bad practice and should never be used anyway. Tapping will only make the excess solder balls to short circuit neighboring LEDs. Almost all 757 Nichias have exposed contact points at their four sides, solder balls will cling to it.
UPDATE 190729: Test Result
[Clemence]
