Today I put together an SFT40 3000k D4Sv2 for a customer as well, the beam is the same as my 5000k D4Sv2 though it is nowhere near as intense. Using convoy-sourced emitters, the DUV was -0.0005 and a CRI of 96.7
I’m looking forward to seeing how the FFL505A perform, should be a lot more rosy and noticeably more intense.
I also swapped my TS10v2 to dedomed 519a 5700k, because the original emitters were burned and I got a refund. Was my first time putting together an aux PCB, surprisingly tricky to hand solder.
Used an MCPCB and aux board from Master_Nate (on Reddit), worked well though needed a lot of sanding of the edges to remove the manufacturing leftovers.
The tint is incredible, 219b-levels of rosy, though the beam is not as good as the originals, possibly of my own fault for not getting the emitters perfectly seated.
Also, did some more modding today and in the last few days.
Roughly 2 weeks ago, I swapped 4000k XHP70.3HI into my Haikelite MT09R to replace the incredibly high-CCT XHP70.2. Sorry not many pics of the operation, I was busy working on the light. @Texas_Ace you might enjoy this one
Incredibly high intensity, with Samsung 20S and dual-FETs it has 252.8kcd of intensity, though it is R70. Surprisingly neutral tint, doesn’t get too rosy or green, right at a DUV of -0.0003
Few days ago I finally got around to fixing my Pioneman K75 (equivalent to a Convoy 3x21C with SFN43), the replacement driver for it wasn’t working so I decided to piggyback it with a spare D4v2 driver that I had. It’s a miracle all those wires were able to fit.
I also “restored” a Mateminco MT07 I bought used, fully disassembled it, washed it with soap and water and a brush, repasted it and updated it from Anduril1.
A previous owner swapped a mix of partially dedomed 519a (2700k outer, 5700k inner) into it, which gives it a gorgeous beam at 2650k and -0.0045 DUV. Surprisingly tricky to reassemble, compared to the Hanklights I’m used to, because of how short the emitter leads were.
