So you dont trust your mom with cell phones, cordless tools, laptops, or the countless other Li-Ion powered devices that are scattered around the typical house?
Almost all Li-Ion failures are the result of negligence. A quality cell, with quality protection circuit, in a quality light that charges properly will be as safe or safer than a cellphone
Cell phones do not use the same kind of LiIon as 18650 flashlights.
Many 18650 flashlights lack overdischarge protection, and many flashlight batteries are UNprotected
I would not give mom a flashlight with an UNprotected LiIon, unless the light itself had built in OverDischarge protection. The battery I recommended does have OverDischarge Protection built in.
Some flashlights wont even fit a Protected 18650, they only work with UNprotected. Zebralight is an example of a light that only accepts UNprotected cells. Fortunately Zebralighs do have Built IN OverDischarge protection. A Zebra wont work with a protected 18650, and a Zebra wont charge an 18650, you will need a separate charger. None of this is MOM friendly.
What causes LiIon 18650 cells to go BOOM! is OverDischarging, they then overheat during charging and can burn the house down unless an intelligent operator is supervising the process. Mom is not that intelligent, or she might be sleeping while the 18650 is charging (bad operator behavior).
I agree that giving mom an 18650 light verges on irresponsible gifting, there are a lot of details that need to be verified first.
For example, the MecArmy PT18 uses a PROTECTED 18650, that is included with the light. The light itself has a USB charging port. That means that during charging, the light is not useable.
Soooo
pick a light that accepts PROTECTED 18650, unless the light has built in OverDischarge PROTECTION. If you buy a light that does not have built in charging, then buy a Protected battery that has built in charging, so you dont have to rely on MOM to operate a LiIon Charger. And so Mom can use the light with a spare battery, while the other one is charging OUTSIDE the light.
I would be willing to put money on most failures of 18650s are not over discharging them, and is short circuits or trying to drive them too hard (pull 20a on a cell only good for 5).
Many name brand lights have LVC (low voltage cutoff), and will keep the cell from being over discharged. Many protected cells also offer LVC, and over current protection.
I would have no problem giving any adult in my family an Olight with magnetic charger.
I have the old version of it, and despite it is not “bad”, it is not necessarily good! The new version had the UI improved, but not much.
A “mom” deserves better than this light Both in interface and reliability!!
BTW: If you decide for 16340 flashlight, I would say that the Wuben TO10R is better (I am not even entering the Olight S1R Baton…), even if it is heavier. It brings a protected 16340, has tail magnet, has USB charging. If you want one, contact member the !
From page 3 onwards it is discussed the light with the new UI (Low > Medium > High + “Stepless dimming” + Strobe). Before that, the old UI (Low > High > Strobe + “Stepless dimming”).
Please note that the “ramping” is nothing like the one from the Emisars!!
It is not actually bad, specially after the change of UI. Now it can be used without need to pass the strobe, so that was an improvement!
But do not expect a high quality cell (it is a blue generic 16340 one, unprotected), and a superb light!
The tint is neutral to warm, with XPL-HD Led.
Just curious, how old are you, do you remember gas being piped into homes with a live flame pilot light?
Electricity with life threateningly high voltage, 120/240V?
My Mom lived through those perilous times by paying attention to the rules of use.
So should yours.
I gave my mum Niteye TF25 that takes one 18650 since 2013 and change the battery for her every 6 months or so. I visit her every weekend, so it is not a problem. I have many USB rechargeable lights now, but I don’t gift it to her because I still think charging those loose battery cells are not necessarily safe for old folks.
I think for parents, they don’t need very bright flashlight. Flashlight without any parasitic battery drain is even better since they seldom switch it on.
And gift them a beautiful flashlight actually makes them happy for a few moment but they will put it aside until they need it though :person_facepalming:
I still have a gas stove. The light goes out every day. I tried to clean it but it still does it. I would rather replace it but my father wants to keep it.
We even have an old TV that is probably from the 1970s.
