My YUPARD 5500 Lm 3* XM-L2 LED Super Bright Spotlight Searchlight Flashlight super T6 arrived today, so I took some quick photos and a tear down for those that are still waiting for theirs.
It arrived well boxed with the flashlight inside another sturdy gift box.
It was smaller than I thought it would be. Smaller in a good way. This light is nice and compact. I would compare it to the Solarstorm/FandyFire Warrior.
It feels nice in the hand. The handle isn’t cumbersome, and with it being attached at the back is less likely to slip from your grip. I find these type of lights to generally be top heavy, and handles that are attached at the front can slip from your grip if you don’t hang on.
The electronic switch is placed perfectly for easy reach. There is no long press required to turn on. The switch is instantaneous, and hair trigger.
The modes are High ~ Medium ~ Off. You have to go through medium to get to off. It’s just one extra click, and the switch is fast and sensitive. Strobe is hidden, and can be accessed by holding the switch for a few seconds. The light will go back to high.
Here is the Yupard between a Nage triple and a FandyFire Warrior
Even though it is advertised as 3 x XML T6, it is in fact 3 x XM-L2
The reflector is pretty much the same as the Warrior except the emitter holes are a bit wider at the base, with room to accommodate a centering disc. The beam pretty much matches my FandyFire Warrior.
Alright. Here’s the battery side of the drive.
I couldn’t go through the head to push the driver out because the reflector is screwed on from inside the head, so it looks like the switch will have to come out.
The switch comes out easily enough by unscrewing the retaining ring. Pull out the switch and insert something with a right angle. I used a bent nosed pliers, but I usually just use an Allen key and give it a tap with a mallet. The driver pops right out. I think it’s just pressed in.
You can see the charging port. It’s a direct charge to the cells with no supported circuitry. I would just remove it.
And there is that beautiful driver. I’ve already done a few threads about this driver. I love it. There are three sectors with pads for six AMC7135 chips per sector. The sectors can be linked if you want to drive a single emitter.
The Yupard has four chips per sector and six unused pads. That would give this light I.4A per emitter. You can populate the empty pads with more chips, and then keep stacking. I love it.
Here’s the inside of the body tube. You’ve all seen springs before. I couldn’t get the tail off. It’s glued pretty good. I don’t even know if its threaded.
The cover for the charge port is just a rubber plug connected to an elastic that girds the head. Needs work.
It’s late and I have to get to bed. I kinda rushed this one to the presses, so if I left anything out, or can answer some questions…speak up.
