Lumileds Luxeon V, test of a 4000K 70CRI emitter
210 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 18 min ago
It has been a long time since Lumileds released an emitter that was really appealing for flashlight use. In fact, ever since Cree smashed all prior existing performance with the introduction of the XR-E, the Luxeon leds never took the lead again. The tints (at same CRI) of the Luxeons were always good, and superior (IMO) to the Cree leds, but the performance lagged behind. So how about the new Luxeon V ? (confusingly there already used to exist a Luxeon V led in the old days, it is a bit of a mystery that Lumileds chose an existing name this new led).
The Luxeon V is a new high power single die white led from Lumileds that has a similar footprint shape as the Cree XP and XM leds but in size it is in between those. The specifications are quite remarkable (specs),  rated for almost 5A and 1700 lumen (which is similar to the Luminus SST-40) but with a thermal resistance of 0.8 degC/W, which is 3 times as low as any existing high power led. For the moment it only comes in 70 CRI (same story as the SST-40) and in 3000, 4000, 5000, 5700 and 6500K
I bought 5 pieces of the 4000K 70CRI Luxeon V leds from Mouser (they also have 6500K but no other colour temperatures as yet) and put one to the test and used one for a mod in a Thorfire VG10. The price was modest ($3.63 a piece ex VAT) but as usual I had to buy several extra leds (innocent) to get to the free shipping threshold.
Before buying, by examining the specs, I knew that the footprint would become problematic for there is no existing ledboard out there fitting it. But I reckoned by inspecting the dimensions that I would by a hair get away with a XP-board. This would of course not show the full thermal potential of the Luxeon V. Upon receiving the leds I could see how close the led is to not fitting:
It could by just work on a Noctigon, but I have some other XP boards in my junk-box that probably would not work.
So this was one of the most careful reflows ever, correcting the led on the Noctigon many times until it was exactly centered on the solder pads, trying to use enough solder paste to fully cover the central pad but not too much because the trick of squeezing out excess solder only works for well fitting leds. The result was not perfect but would have to do:
The led is slightly lifted on the side visible in the picture, but the backside is tight on the board. This will have to do for the test.
So it does light up on a XP-Noctigon (few mA in the picture) while keeping the core of the board electrically neutral, and as you can see the apparent die size is similar to the XP-L led. The phosfor seems a bit damaged in the middle and I'm not surprised because I took the pictures after the test. innocent
On to the test...
The test was done like all my more recent emitter tests. I described it in detail in my XP-L test. , with two minor differences that should not matter significantly for the results: I used my Integrating sphere no. II instead of no. I, and for the current I used a clamp meter, which appears to measure 0.1A lower than the power supply current-reading that I used before.
In summary: 1) just one led was tested, reflowed on a DTP copper board (XP-Noctigon 16mm diameter),  2) I used my large version II integrating sphere with high quality luxmeter, 3) the output numbers and voltages were measured with the led close to 'steady state' for each current, so warmed up and settled, you should be able to get these numbers in a well heatsinked flashlight. Mind that these are output numbers of the bare led, in a flashlight there will be losses from light obstructions, lens and optic, 4) output is in 'djozz-lumen' defined as 1/550 of the output of my Sunwayman D40A on high setting, which I hope is close to the real lumen, but at least is consistent over all my emitter tests done in integrating spheres. (my recent comparison with maukka's sphere shows that the djozz-lumen is 5-11% high compared to his fully calibrated set-up, but I keep using the djozz-lumen because it is consistent over all my led- and flashlight tests and thus makes comparison easy)
Here's the results. I took my earlier SST-40 N4 bin data for comparison because that is the best performing led in this class that I have tested before. I would have liked to include XP-L2 data but I have never tested it so I do not have data at hand, please refer to Texas Ace's XP-L2 test for that, the performance seems a bit lower than the SST-40 and Luxeon V.
What can be seen?
  • On this ledboard, the current to output performance of the Luxeon V is almost exactly that of the SST-40 in N4 bin, but because the voltage is lower, especially at high currents, it is more efficient. This higher efficiency will however not be obtained in a flashlight with lineair driver (like a 7135-based current controlled driver) because any voltage difference is burnt off by the driver. The very low voltage does increase the current in direct drive flashlights, which will or will not be an advantage; it may be too high for comfort/safety or will cause a decreased efficiency, especially of course if the current is higher than 9.5A at which current the light output maxes out.
  • We do not know yet how this led will perform on a dedicated DTP-board. Somehow I think that the difference will not be great, but I can be wrong, only a test will tell.
  • Like the XP-L2 (but unlike the SST-40 that burnt its bond wires at 9.5A), this led survives high current at least up to 15A, without loss of performance afterwards. I had the led at 15A for two minutes, and after cooling down, the performance at 6A was just 2% less than before. Even at 15A I did not see an obvious tint shift to blue, like what usually happens when severely overdriving leds. I did see some slight irregularity in the phosfor afterwards (see picture above), that was perhaps not present before the test (did not check).
A mod.
Now that we know that the Luxeon V has very good performance but does not stand out way above its competitors (at least not when reflowed on a XP-board, on a dedicated board it may be different), how are the other parameters that determine how well a led performs in a flashlight: tint, beam, does it dedome? That will require a mod!
I did a mod in a Thorfire VG-10 (the good type) with a BLF-A6 direct driver. Because this led has the lowest voltage of them all, I expect to get this led easily to 9.5A and its maximum output, perhaps even more. I used a VG10, a Luxeon V led, a 20mm Kaidomain DTP-XP board, a BLF-A6 driver with short  20 AWG ledwires, 20AWG bypassed driver-spring, phosfor bronze (djozz-) tail-spring, PD68 low resistance switch-board, small omten switch. The ledboard-shelf was a tiny bit hollow (better than convex!) but the ledboard is 20mmx1.6mm copper so heat-shedding to the shell should still be ok (with help of a generous layer of Arctic Silver sealed). I had a led centering piece of which the outside was too wide for the reflector and the inside too narrow for the 4x4mm led, so the reflector hole and the centerpiece hole were reamed to fit; advantage was perfect fit and centering.
So now some real world performance could be found. First the numbers at maximum output on a freshly charged Sony VTC6 battery: current with tail-off measured with a tick copper loop and clamp meter: 9.5A, output at start 2170 lm, output at 30 seconds 2015 lm. Not shabby, is this the best output ever for a single-die-led-single-18650 flashlight? Throw at 30 seconds was 30 kcd. Then the beam and tint:
The beam is really good, quite a few new high output leds (Cree) have huge tint variation over the beam, while the luxeon V has a very pleasant beam with little tint variation, one of the best beams I have seen (apart from a slight ring out in the spill not caused by the led but by the shiny VG10 bezel).
The tint is also really good. I can just judge the 4000K version, but it is the best 4000K tint that I have seen, with the right amount of yellow and rosy in it (you could always trust Lumileds for good tints!). I would choose the light of this led over the light of many higher CRI leds. Of course the reds are more orangy than the light from a 90 CRI Nichia, and wood tints are more yellow, but that is what you get at 70 CRI.
I have not tried to dedome the led. The way the construction of the led looks (seems like a flip-chip design) I expect dedoming it will not be as easy as the old Cree's and the SST-40, and the result may disappoint (see for an interesting read the experiments and discussion from EasyB here). So I leave dedoming attempts to others this time, moreover because I'm not that good at it.
Conclusion and thoughts.
The Luxeon V for now seems not made for throwers but other than that, for its sheer output, toughness, tint and optical behaviour I think in the single die category it is the best out there, even when reflowed on a non-fitting XP-board. I hope that someone (not me this time) will have a batch of dedicated DTP-boards made for the Luxeon V by Kerui Electronics  (BLF-member leo ou (Sundy) is the representative), so we can really find out what this led is capable of. It makes an obvious Q8 mod too, the reflow on the XP-pads will require precision and the centering pieces need reaming a bit, but then you have an instant 8000 lumen (and a ridiculous amount of heat cool )
Thanks for reading!
EDIT oct 8 2017: Good news, Led4power has made and sells a dedicated 16mm DTP-board for the Luxeon V cool , see post #31 and www.led4power.com. I have tested this board, result in post #73.
Edited by: djozz on 10/09/2017 - 10:17
CRX
CRX's picture
Last seen: 1 month 1 week ago
Thanks, looks interesting Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 5 hours 45 min ago
Orsm testing djozz. Makes you wonder when Cree are going to release new low voltage leds.
The Miller
The Miller's picture
Last seen: 10 months 3 weeks ago
Thanks
Hmm that dual pad Q8 board might just happen seeing this, xmlband XHP70 pads are tricky, but these so close to XP hmmm
Nice tint…
Agro
Agro's picture
Last seen: 58 sec ago
Interesting, thanks djozz.
Which flux/Vf bin is that?
BTW it would be interesting to see output vs. efficacy of Luxeon V, XP-L, XP-L2, SST-40, XHP35, XHP50.2 …
djozz
djozz's picture
The flux and Vf bins are not given (yet?). All there is is that the output at the Mouser site is stated as 510lm min-576lm typ, at 1400mA, which comes straight from a partnr.table in the datasheet, one partnr per colour temperature, that does not include bin nrs. for output or voltage. Further on in the datasheet there’s indeed a table that explains output bin nrs. with accompanyoning min and max output (so not min and typ like the above table). The 510min/576typ if loosely translated into these bin nrs. would cover the whole range of the 4 highest output bins, in other words they do not tell you.
mrheosuper
is this the best bin?
looklike 2000 lumen is safe zone for this led
Forgot my pen
Geuzzz
Geuzzz's picture
Last seen: 3 hours 14 min ago
Thnx Djozz! Looks like a winner. Now I have to choose a light to put one in.
One thing I don’t like about this newer leds is the huge amount of heat they produce ( high amps, low voltage). How is the heat generation on this one compared to 219c for instance.
Jerommel
Jerommel's picture
Last seen: 5 months 2 days ago
Thumbs Up Thumbs Up Thumbs Up Djozz.
Jerommel
Jerommel's picture
They are more efficient, so they produce less heat, and more light.
(edit) I mean, what do you mean? Smile
Henk4U2
Henk4U2's picture
Last seen: 1 hour 40 min ago
Electric power is measured in Watt’s = Joules/sec. And it is the product of voltage and amperage. Ergo: W = V * A
On paper you can double the amperage and halve the voltage, the power is the same, and so is the heat production.
One thing about (a very) low voltage and (a very) high amperage is the leads at some point can become a limiting factor.
But with LED’s we’re talking percentage, not doubling.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Agro
Agro's picture
Would like to see it directly driven in some 10180 light. With Vf curve so low it could produce nice output.
And, dedomed, in Emisar D1 with 18350.
Geuzzz
Geuzzz's picture
I do think to notice a diverence between higher voltage/ lower amps and lower voltage/higher amps at the same watts.
This is also the reason why electricitylines for electricity transportation are all very high voltage and low amps. This is to limit lossses (heat).
Jerommel
Jerommel's picture
Yeah, that’s true, Geuzzz.
But those power lines are kilometres long and can’t be too thick because of weight and cost.
I.i.r.c. they’re not even copper, but aluminium. (Aluminium has the best weight to conductivity ratio).
In a flashlight we can use a couple of centimetre of copper AWG18 if we want to, and bypass the springs, making losses negligible.
But, the lower the Vf, the more voltage drop over a linear driver.
With a fully charged battery this can be up to 1 Volt.
So when you have a 12 Amperes regulated linear driver, it will have to dissipate up to 12 Watts in heat with a fully charged low sag (high drain) battery.
djozz
djozz's picture
Yes, these low voltage leds loose a lot of their efficiency in our use in flashlights because the difference between led voltage and battery voltage is higher, while the two most used types of drivers, lineair and direct drive (both are simple and compact), are pretty bad handling that: the lineair driver just burns off the voltage difference and the direct driver results in a very high current region in which the led is least efficient. Small batteries are limited in current so in direct drive the led is still in a quite efficient region, but then the battery works against efficiency: at their highest current the capacity of the battery decreases.
Perhaps the voltage of the Luxeon V is so low that the difference between battery and led voltage is high enough to use a buck driver? (I have no idea, not into driver electronics). Say you want 3A (a bit over 1000lm OTF), the led voltage is then 3.2V, the battery voltage under 3A load is for most of the drainage over 3.6V. Hmm, 0.4V difference is probably not enough. For 1A/450lmOTF it may work.
Henk4U2
Henk4U2's picture
Jerommel is right. The losses in thick lines at low voltage is the same as in thin lines at high voltage. That’s why the E-backbone of Netherland is running on 380 kV. To “save” on the cost of lines, which are of aluminum with a steel core. And the cost of electricity pylons, which have to carry less weight. Insulators are more expensive at ultra-high voltage.
thijsco19
Last seen: 3 days 5 hours ago
I might remember it wrong but I thought I have red that 0.4 volt difference will be enough for some buck regulator’s.
Could also have been for a different type driver…
The_Driver
The_Driver's picture
Last seen: 1 day 4 hours ago
Thanks for the test!
A buck driver is always possible, but doesn’t always make sense. Most stock single-cell lights with 3V LED (XM-L2 for exmaple) have a buck driver. A lower VF means that the output stays constant for higher percentage of the runtime and the average current pulled from the battery is lower. So the lower the Vf, the more sense a buck driver makes.
Jtm94
Last seen: 2 weeks 6 days ago
Definitely interested in this as a Q8 mod candidate. Thanks a lot for all of the information djozz! Big Smile
You could maintain efficiency with a boost driver running these in series correct? I’ve been getting too many ideas lately, not good for the wallet.
mrheosuper
why use this led in 1000 lumen light, i mean, if you want 1000 lumen, go with xpl-hi,hd, xm-l2, or even xp-g3, and it’s also easier to reflow the led on MCPCB
if i use this led, i will push it over 1800, close to 2000 lumen(or even higher)
Forgot my pen
The_Driver
It’s more efficient and produces a beam with a more even tint. Those are big benefits.
sac02
sac02's picture
Last seen: 1 week 3 days ago
mrheosuper wrote:
why use this led in 1000 lumen light, i mean, if you want 1000 lumen, go with xpl-hi,hd, xm-l2, or even xp-g3, and it’s also easier to reflow the led on MCPCB if i use this led, i will push it over 1800, close to 2000 lumen(or even higher)
LEDs are more efficient when they are driven softly (look at the slope of the graph in the OP). So to acheive 1000Lm, a “2000Lm” LED driven at 50% will be more efficient than a 1000Lm LED driven at 100%.
The Miller
Djozz, ylu know this was bound to come…please do the Q8 with these?
For me newbie it is kind of mixed.
On the one hand lots of lumens, on the other driver burning off volts. (And end Ferry Mingele mode Wink )
If these are a good Q8 candidate, we really should have the XML pad ledboard redesigned to have pads for this as well.
XML and XHP70 would not fit, but these small pads would.
djozz
djozz's picture
Hmm, ok, I will mod a Q8 with these, but I may wait for the new ones to do that. But mind that the stock light puts out 5000 lumen at 20A, and with Luxeon Z’s it is 8000 lumen at 36A, it will get kind of way too hot.
Jensen567
Last seen: 1 year 4 months ago
Thanks for the test djozz. Need to get you some samples of XP-L2. I’d donate to the cause. Impressive that the 4000k Luxeon V has almost identical output to a 6500k SST-40, and at a lower voltage to boot. Tint looks wonderful too! Can’t wait for some high CRI and more color temps.
How much does a custom run of DTP copper boards usually cost?
Jerommel
Jerommel's picture
…and Thumbs Up Thumbs Up Thumbs Up Lumileds of course.
Very interesting LED.
Maybe start a ‘groupbuy feeler’ thread.
But Djozz, how off is the size for an XM board?
Looks as if it could fit just as good bad as on an XP board..
djozz
djozz's picture
The Luxeon V will not fit XM-boards at all.
Jensen567
I just posted over on RMMs thread to see if he has any plans to stock the Luxeon V and perhaps even get some custom DTP boards made up for it. He has his MTN Quad boards which are top notch, so if he did a Luxeon V board I would be in for quite a few. A triple or quad Luxeon V board would be really interesting as well.
Tom E
Tom E's picture
Last seen: 6 min 37 sec ago
Wow! Nice job on this test!
ImA4Wheelr
Last seen: 3 months 6 days ago
Exciting.  If Vf's get a bit lower, one could nicely buck drive 4S emitters with 4S cells.
Thank you for another great contribution to the hobby.
led4power
led4power's picture
Last seen: 7 hours 14 min ago
16mm DTP
