[Sale] Buck drivers 20, 21, 22, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
212 posts / 0 new
Lexel
Lexel's picture
Last seen: 4 hours 7 min ago
Buck drivers with adjustable input and output voltages and current up to 8A
selected parts for best efficiency
The base price for the driver is 16€
46/47.5mm cost 1€ more
20 and 22mm got pretty expensive Coilcraft XAL7070 inductor +2€
2€ shipping worldwide from Germany with priority air mail
optional tracking with 25€ insurance adds 4€
for very big orders I can add for 2€ per additional 100€ insurance
The drivers use NarsilM, but can be flashed as well with Anduril
Each driver gets calibrated for output current, LVP and step down temperature
XHP35 LED max. 2.5A same as the GT
XHP50/70 2S → 6 / 4S → 12V up to 8A
2S → 3V up to 7A white flat for example
4S -> 6V depends on size as the shottky diode produces a lot of heat
older driver designs:
Buck frequency changed from 600-800 to 200-350kHz
input and output caps increased, the design already has pads to fit more caps
3A diode replace with 20A
inductor from 6A 10uH to 15.5A 4.7uH
6-7A is possible
new upgraded driver
MF02S (originally MF02 XHP70.2 mod) driver is out now a few months
basically there had do be made a few improvements and parts change to get it more efficient
as well get some ringing problem on the LDO fixed that occured on higher currents
MOSFET was changed to a far better one
less voltage drop 5.5 vs. the old 12.8mOhms,
It has 1/4 of the switching losses as it switches faster
I could go up in switching frequency a lot which was reduced on the first XHP70.2 mods
total loss compared to old 1/3
Inductor value cut to half now 2.2uH with new FET and resistance as well (XHP35 has 10uH, old XHP70.2 4.7uH)
Output and Input caps sustained to handle the more current
I also made 4S carrier boards for people who dont want to mod the OEM boards
2$ for a pair of boards one tray
3$ pair cut out and sanded to size
add 3$ to with Berylliumbronze springs and gold plated button soldered
XHP35, 50 and 70(.2) will work well
for XHP50 and 70 a Star with the thermal pad not connecting the 2 LED pads over the thermal pad is mandatory
so for 12V reroute over a separate trace would be needed, usually a wire can do it on a modded 6V MCPCB
new 20mm and 22mm
23mm for Klarus XT11/12GT running 2 18350s for Oslon BF or other 3V LED
new 30mm for L6 or similar lights
TN42 XHP35
new TN40 XHP35 8A 12V
HaikeLite MT07S MT09S
MF01 3S LED mod to 4S carrier
MF02 XHP35 12V 2.5A
MF02S XHP70.2 12V added some more thermal conduction as well as programming port
The battery carrier needs to be modified to 4S its pretty easy
2 trace cut on both ends and add one bridge
MF01 v2 MCPCB-mod for Buck driver
BLF Q8 XHP35
BLF GT Oslon Black flat (needs 2S carrier mod or 2 cell dummies)
Acebeam K65 the latest gen with programming port
Acebeam X45 the latest gen with programming port
BLF GigaThrower driver
Acebeam K65 latest gen with programming port
Niwalker BK-FA30S
added 3 pads for the auxillary switches,
one providing 5V for the Turbo switch
one sets multiples the current by 10 or goes to Turbo
the other divides the current by 10
Edited by: Lexel on 03/12/2020 - 04:39
Lexel
Lexel's picture
the driver Sale is in my TA driver Excel spreadsheet which contains also DD+7135 drivers and other stuff
Efficiency measure on my 12V MF02S driver
Let me give it a try as I modded today for someone else a MF02S
I am bad at making videos but I post it anyways
actually the PSU voltage meter uses calvin clamps so its reading on contact points on driver to compensate losses on the wires, even if they are 2.5mm²
Turbo (measure 3 times and used average later on video the clamp meter offset were off 70mA)
Input: 15,15V 5.4-5,44A
Output: 13,44-13,51V 5,70-5,74A
Efficiency: 94,4%
I also changed the calibration resistor to get to 6.09A later and did again 2 measurements
15,11V 5,8A
13,6V 6,09A
94,5%
fully charged VTC6 should give this voltage
16,17 5,37A
13,55V 6,04A
94,25%
2A
Input: 15,73V 1,766A
Output: 12,06V 2,12A
Efficiency: 95,5%
500mA switching frequency is over 1 MHz as output voltage low and input high
Input: 15,94V 415mA
Output: 11,2V 502mA
Efficiency: 85%
look also in my other driver topic for more Information
http://budgetlightforum.com/node/59724
Niwalker Connections are special for the Aux buttons
The left row is for the aux buttons
V is 5V for Turbo and 10X for the switch
10X increases current by 10 max. is Turbo
T turbo even when electronic lock out or light off
M reduced the current by factor of 10
needs to be connected to (G) ground pad on 2. wire
right
G common Ground
L Switch LED MCU controlled
S Switch for UI ramping settings
Athlon2350
Last seen: 13 hours 7 min ago
interested
prisma
Last seen: 1 week 3 days ago
Interested
lcortez321
Interested. But I have no technical expertise in modding anything, not even a cucumber, much less a flashlight, will you offer your services, to those who need help?
Lexel
Lexel's picture
I bet there is someone near you who can help with the driver change and battery carrier mod
I am from Germany so shipping costs would kill it
MRsDNF
MRsDNF's picture
Last seen: 1 day 3 hours ago
I’d be interested in a couple. Are you planning different options with it in respect to current and output voltages?
Lexel
Lexel's picture
I will build those with 4 shunt pads
The standard BLF Buck from del has a 0.091 shunt
I will be using 3 0.33 and one 1 Ohm resistor —>0.091 Ohms
Of course it is possible to go to different values for different output currents
The inductor is rated 6A, so that’s a current that should be without any problems availiable
Zeratull
Hi! Sorry I am not expert in MOD but I would like to know what do you expect with this Driver in the Astrolux MF02? I am going to buy a MF02.
Thanks.
Lexel
Lexel's picture
Zeratull wrote:
Hi! Sorry I am not expert in MOD but I would like to know what do you expect with this Driver in the Astrolux MF02? I am going to buy a MF02. Thanks.
This driver has the awesome Firmware Narsil
Battery carrier needs 2 traces cut and one bridge soldered to go to 4S/1P
Driver will be same size as MF02, so basically solder wires from one driver to the other
MRsDNF
MRsDNF's picture
Thanks. Do you need to change anything to go from 12 volt to 6 volt output?
ramptosd
Last seen: 2 weeks 3 days ago
Hi Lexel. I have not done my first mod yet but I am interested and this does not seem like it would be too complicated. Would you let me know what you think this might do for the MF02, how it might affect performance of the light? Thank you
Rat
Last seen: 2 years 1 week ago
I’m in. Put me down.
Lexel
Lexel's picture
Not too complicated the Battery carrier and driver replacement
The LED will be driven as hard as in the BLF GT and you got a great Firmware with NarsilM, highly customable
you have to ask DEL if that’s possible its his driver circuit
Lights-Out
Lights-Out's picture
If there will be so options I’ll be in for a few, I’d like to have one for my sbt-70 led if possible ?
Lexel
Lexel's picture
This driver is for 12V LEDs, SBT-70 is a 3V one and wont work with the current it needs
XHP35, 50 and 70 will work well
Those Sinkpads are OK, MTN, Fasttech and LEDDNA sells em
This LED star will not work if the star is not insulated from the body
steel_1024
steel_1024's picture
Last seen: 1 day 10 hours ago
Interested +1
Sorry for my poor english.
firedome
Last seen: 4 months 2 days ago
Interested Big Smile
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
Gj
Gj's picture
Last seen: 2 days 14 hours ago
Interested.
g_sintornillos
g_sintornillos's picture
Last seen: 3 weeks 4 hours ago
Interested
Sorry for my bad English (gogole transtorla)
Lexel
Lexel's picture
I think I can live with this
the question is if a 8.5mm high inductor fits the head or if I have to take a smaller one
P.S.
Design got improved
MF02 measured 8.3mm for parts height so the 7.5mm inductor will fit
GozonM
GozonM's picture
Interested
giorgoskok
giorgoskok's picture
Will you add this board on your boards page after you test it ? And parts list if possible!
Lexel
Lexel's picture
I will order those boards not from Oshpark so witch 30 boards on the batch I should get down to about 2$ per PCB
When I sold the batch I will make em public including mouser parts list
giorgoskok
Hmm , if you order 30 and are cheap as you mention , maybe i can get 2 pcbs from you ?
Lexel
Lexel's picture
Parts ordered for 30 drivers
final design
mikey1299
Interested
Lexel
Lexel's picture
OP changed to sale topic
Price is 22$ plus shipping
PM sent to all that replied in this topic
parts and boards for 30 drivers ordered
(10% extra parts for tests and maybe 3 boards from Oshpark)
I also added the 2×2 LED boards to the Seed order,
so if you like different colors or just more even lighted switch you can take one as well
I got SMD LEDs in different colors
CW, NW, green, emerald green, yellow, orange, red, blue, ice blue and pink
steel_1024
take one
Lexel
Lexel's picture
lol just realized my calculation was missing the MCUs
price 1$ increased
MRsDNF
MRsDNF's picture
Hi Lexel. I guess you received my payment for two drivers, just cant see my name on your spread sheet. I slipped you a couple of dollars extra so all should be good here. Beer
