[Review] SST-20 in FW3A is divine!
98 posts / 0 new
Joshk
Joshk's picture
Last seen: 54 sec ago
ToyKeeper wrote:
SST-20 with minus-green filter
Maybe I didn’t explain completely. The meter is recommending I use a minus green filter because I have the target CCT set at 5500K. It is also recommending a CC filter too, and the combination will swing down the BBL to 5500K. It’s a significant green subtraction, way more than the 2 MacAdams it takes to bring the Floor to the BBL.
My intention was to demonstrate a method of adjusting a minus green filter.
Neither me nor the meter recommend putting a filter on this SST.
Joshk
Joshk's picture
ToyKeeper wrote:
Because of these results, the researchers are proposing a revision to the ANSI standard for white light, to lower the line for recommended tints and hopefully get manufacturers to produce rosier shades in common lighting devices like bulbs.
We don’t need a new line as much as a “Keep Out” zone in the green area.
m00nshine
Last seen: 5 days 4 hours ago
This stuff is new to me. I know what CRI is but I would love to learn more about some of the units you guys are posting about. Is there an ultimate guide to all the different metrics? CCT, Duv, CRI (Ra), TLCI and even lumens and candelas. Kinda like what they have on baseball sabermetrics on fangraphs haha.
Joshk
Joshk's picture
Welcome to BLF!
I can give a quick rundown of the stuff.
CCT is Color Correlated Temperature. It tells you how warm or cold the light appears. Cold colors have more blue, warm colors have more red tones.
Duv is actually how we type Δuv. The greek Delta stands for “change” in math. So Duv is distance from the Black Body Locus (that line we like).
CRI originally evaluated 8 colors. Now it evaluates 15. When we refer to all 15, it’s often called Ra. So “CRI (Ra)” is just a catch-all to make sure everyone understands Ra replaces CRI.
TLCI is like CRI for cameras. Cameras see light a little different than our eyes.
Hope that helps.
contactcr
Last seen: 1 hour 37 min ago
Sekonic press release:
Quote:
Sekonic Corporation, Light Meter Sales Department, has announced that the new firmware for SPECTROMASTER C‐800-U is now available.
WHITE PLAINS, N.Y., Sept. 16, 2019 /PRNewswire-PRWeb/ — The C‐800-U SPECTROMASTER is the industry-leading handheld spectrometer for cinematographers and photographers around the world. Sekonic strives to keep this meter on the cutting edge of technology and works with top lighting manufacturers, standards organizations and organizations such as The Academy of Motion Picture Arts and Sciences, Science and Technology Council to keep the C‐800-U the most relevant tool for cinematographers and photographers.
The newest firmware will update the TM‐30 metric from TM‐30‐15 to TM‐30‐18, which Rf is identical with Rf of CIE 224:2017, international standard. This is a standard that many feel will replace CRI (Ra) as a more accurate way to measure the color fidelity (Rf) because TM‐30 measures 99 colors chosen from more than 100,000 measured objects vs CRI’s 8 colors. TM‐30 also measures gamut (Rg) which helps the user better understand how saturated colors will look.
This recent firmware update also shows the CCT, LB and CC properties of a preset when chosen in the Tool Box under the Preset Selection menu.
C-800-U firmware update can be done by C-800-U Utility, downloadable from the Sekonic website: GO NOW
Joshk, feel free to try out the new C-800 firmware and do the TM-30-18 report
m00nshine
Joshk wrote:
Welcome to BLF!
Duv is actually how we type Δuv. The greek Delta stands for “change” in math. So Duv is distance from the Black Body Locust (that line we like).
Hope that helps.
Correct me if I’m wrong. So if the SST-20 led is rated for 4000K the CCT gives a more accurate measure in Kelvins. It goes from a scale of 1000-10,000, warm to cold. CRI and TLCI is a rating of the ability to produce the full the colour spectrum with 100 being perfect. But what would an extreme example of poor CRI look like? Is it like an old sepia filtered WWI picture?
I’m not sure I understand duv fully. The measurement seems quite sensitive with people complain about the 10000th measure. I found this article.. Does Duv give another dimension to CCT? Is it measured as the perpendicular distance from the desirable locus line? Is rosy, to the bottom right, a negative measure and yellow/green, above the line, positive? Thanks
Joshk
Joshk's picture
Kelvin is the unit used for CCT, CCT = 4000K for example. Yes, 100 is perfect for CRI and TLCI. An example of poor CRI would be if you looked at a bundle of wires with a light, and couldn’t tell the difference between pink and red, or blue and purple for example.
Yea people are sensitive to Duv. I think it’s because of our nature to see greenish things as diseased.
Joshk
Joshk's picture
That just added some pie slices. What do they tell us?
contactcr
Hell if I know, but if this is set to replace Ra/R9 we should probably figure it out Smile
AFAIK you want a big wide circle like this for even, full spectrum. If it jets in or out too much you will have a bias towards that
treellama
Last seen: 3 hours 44 min ago
Joshk wrote:
Black Body Locust
Tally-ho
Tally-ho's picture
Last seen: 2 hours 33 min ago
The black circle is the reference, the red circle is the SST20. When the arrow goes to the interior of the circle, the colors of the region are less saturated than the reference ( = negative chroma shift), when it goes to the exterior = more saturated than the reference ( = positive chroma shift). When it goes to the left or the right, there is a hue shift.
The SST20 colors rendition are very close to the reference but with slight hue shift, overall saturation matches the reference except for colors of region 14 which are a bit more saturated.
This sample is very good for colors rendition with high fidelity (compared to the reference), better than a 219B SW45K.
Is it a filtered SST20 ?
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 8 hours ago
The SST-20 actually renders colors better vs a 219B SW45K, since it doesn’t have a tendency to saturate on the magenta part of the spectrum due to its more balanced tint, and actually having less tint shift.
TLDR: The SST-20 is better than the 219B in every aspect, even in terms of tint since the FD2 is now more easily available, and the FA3 and FA1 color tint bins will hopefully be available as binning gets better.
twisted raven
Last seen: 21 min 24 sec ago
Tint though different amperages is its biggest weakness, but I’m okay with it being on bbl at lowest outputs and rosy at highest.
Joshk
Joshk's picture
Tally-ho wrote:
Yea, but that was all part of the TM-30 before the update. I was wondering what difference the update made.
Joshk
Joshk's picture
+1
I think it’s just going to take some time for the general opinion on the forum to accept the 219B is obsolete by all perceivable measures.
Rayoui
Rayoui's picture
Last seen: 8 hours 10 min ago
I think a lot of folks just tend to subjectively prefer the rosier tint of the 219B SW45K. Under normal circumstances, I don’t find the tint of the SST-20s in my FW3x’s to be particularly green, but when I put them directly next to some SW45K on a white wall, the SST-20s look dreadfully green (at low outputs) and the SW45Ks are decidedly pink.
I prefer the SW45K tint but its efficiency drawbacks and sensitivity to high currents make it impractical for a lot of applications.
An FA1 or FA4 binned SST-20 might be perfection.
Bob_McBob
Last seen: 6 hours 33 min ago
Tint is quite perceivable, and multiple studies have clearly demonstrated most people prefer a tint no available bin of SST-20 can achieve even at unsustainably high currents. I don’t want a light that’s 0.0016 at a level I use regularly when I could just use a 219B and get a much more pleasing neutral or rosy tint that becomes even rosier at higher outputs. There is still strong demand for 219B years after it was discontinued precisely because no other LED can replicate what it does, except perhaps E21A, which is impractical to use in most lights due to the lack of mounting options.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 10 min ago
I may not have explained completely either. I’m not aiming for a meter-verifiable value of 0.000 duv. I’m aiming for something which I think looks good in person… like ~4500K with negative duv.
Adding a minus-green filter is a pretty common modification when using SST-20 emitters, LH351D, and sometimes others. The 89% transmittance value given earlier is a bit generous though… the range I generally see is 70% to 86% transmission, and I’m expecting to need roughly an 80% model to get most of my greenish lights down to a nice-looking tint.
As is, when I use this SST-20 FW3A outdoors, the grass looks nice and green… but so does the sidewalk. And when I point it at purple-colored objects, they turn blue. When aimed at objects with several shades of green, I find it difficult to tell the shades apart. It’s all lemongrass. So I’m hoping a filter can fix that.
I recently ended up with a D4 SST-20, which demonstrates the low-mode tint issue pretty vividly. If I put it in stepped ramp mode, steps 1 to 4 are green while steps 5 – 7 are white. If I make it go back and forth between steps 4 and 5, it looks like two different lights… green, white, green, white, green, white. Because of this, I’m tempted to convert it from a FET+1 light to FET-only, to make the tint usable below 150 lm.
… except for hitting the tint sweet spot which studies have found agreeable to the most people.
It can be tint-corrected with a minus green filter, but after filter losses it ends up making fewer lumens per amp than the aging 219B.
It’s definitely old, but there are good reasons why people still prefer 219B over 219C, why people prefer XP-G2 over XP-G3, and why SST-20 isn’t universally loved. In the quest for ever-increasing efficiency, several different LED manufacturers over the past few years sacrificed optical quality for higher total output.
The changes, like in Cree’s current-gen emitters, make a lot of sense for use in lighting fixtures where the LED is meant to run near full power all the time behind a diffuser. In that sort of device, the Cree rainbow doesn’t matter and neither does current-related tint shift. It only needs to look good when integrated and running at the recommended power level.
That sucks a bit for flashlight purposes, but flashlights aren’t a big enough market for LED companies to really care. So we’ve been using a lot of old stuff lately instead of always adopting new tech.
In any case, the point I’ve been getting at this whole time is: There is no One True LED. Different people prefer different lighting, and that’s okay.
ToyKeeper
ToyKeeper's picture
Not everything, but an ANSI white chart should answer a few questions…
CCT goes lower left to upper right along the dotted line. Tint goes up and down along the more vertical lines. “Duv” is the distance from the dotted line. The shades most people prefer are below the dotted line between 4000K and 5000K.
The SST-20 4000K emitter this thread is about would fall into the 5A3 square, according to its official specs and the measurements it gets on turbo. However, at lower levels it shifts up and to the right, to about 5C4.
The “FA1” bin mentioned a couple comments ago is “5A1” on this chart. It might be a decent tint for SST-20, since at low levels it should only shift as far as 5D2. However, as far as I’m aware, no one on this site has ever acquired any in the FA1 bin. They don’t seem to exist. Most SST-20 around here are the 5B4 bin, which is roughly 5C3 at low levels.
1stein
1stein's picture
Last seen: 4 hours 34 min ago
My 2c:
Some time ago I owned two D4S, XP-L HI 3D 4000K and SST-20 4000K because I wanted to check which I prefer and leave just one for myself.
The throw was nearly the same, I had problems to determine which throws further.
But with both lit up at the same time, the SST-20 tint was obviously biassed with green. And I’d guess SST-20 boils up 20% sooner.
For these two reasons I sacrified high CRI for better tint and less heat. XP-L version is still with me.
(After all I still consider SST-20 to be a great LED. But similary to 219B – it just should not be pushed hard. A perfect diodes for keychain or other small lights)
KevinZA1988
KevinZA1988's picture
Last seen: 3 weeks 6 days ago
I agree…. Love my 219B’s. And there are many out there who would agree.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
m00nshine
Thank you! This was very informative!
Joshk
Joshk's picture
Do you have a link to the filter products you are referring to? I would like to have a look.
Joshk
Joshk's picture
I’m surprised nobody seems to complain about rosy tints. I have an equal dislike for rosy tints and green tints.
Joshk
Joshk's picture
It seems green-tint phobia is a thing?
BlueSwordM
Yes.
I don’t actually like rosy tints, which is why I dislike the 219B, which I’ve actually seen in real life.
I prefer the FD2 SST-20’s tint.
Of course, we can’t deny that the current high power LEDs that have the best tint are the E21As, and in the mid-power range, the Optsolis.
Joshk
Joshk's picture
My 5000K E21’s have major changes at powers above 700ma. Granted the worst in this CIE are just bare emitter.
CLB
+1. It may well be that, statistically, more people prefer rosy Duv to green Duv, and maybe even to perfect BBL. But there must be a significant, if silent, minority, that, for general usage, prefers no Duv. Just as, I guess, I find myself in what must be a significant minority of people who prioritze CRI over tint. My eyes can compensate for tint variations, but there is no way to compensate for low CRI.
id30209
id30209's picture
Last seen: 39 min ago
Well i like rosy tint, especially at night during work. So much easier on your eyes than other tints/colors
For daytime ops SST20 looks better
WTB Titanium 4sevens 2xAA tube
ToyKeeper
ToyKeeper's picture
I would be surprised, but this matches what the researchers found. There was always someone who complained, no matter which tint was used… so no single choice will please everyone. However, the tints which had the fewest complaints were rosy to a degree of approximately -10 to -15 mduv.
It may also relate to the old idiom about rose-colored glasses. The phrase didn’t come from nowhere. Humans, in general, seem to find a touch of pink to be a bit more pleasant. Meanwhile, the counter-idiom of jade-colored glasses (or being jaded) refers to a more unpleasant outlook.
Joshk wrote:
ToyKeeper wrote:
Adding a minus-green filter is a pretty common modification …
The ones I see discussed most often are the Lee minus-green filters. For example:
http://budgetlightforum.com/node/43104
http://budgetlightforum.com/node/53384
$2 for a swatch book, if you’d like to try a few.
Joshk wrote:
green-tint phobia
Facepalm
Ridiculing people over a minor difference in visual perception? Dude.
I’m confused about why it’s so hard to accept that different people like different things. One man’s divine is another man’s lemongrass, and that’s okay.
