Tonight I pretty much wrapped up my 3C Maglite mod, at least to the point of testing it out so I thought I'd do some beamshots for comparisons. (Beamshots taken at the same spot as these.) The camera was on a tripod and I used the following settings: f/3.5 (lowest I could go), ISO 100, and 2-sec exposure time. I set the white balance to "fine" (whatever that is) so it wouldn't auto-adjust on me. I feel these photos are just a tad dimmer than what I saw with my eye. The shed in these shots is believed to be between 150 to 200 feet away 184 feet away. (EDIT 4/19/2013 - finally measured this distance at 184 feet.) The flashlights are set on the fencepost you see the shadow of. All lights were using good freshly charged batteries. All shots taken on flashlights high setting. Camera did not move during photos (except with the 2D Mag short shot).
First up, the Maglite 3C with an XP-G R5 4C (neutral tint from Shiningbeam). Boy do I LOVE this tint! Wow! Driver is 3 mode Nanjg 1.4Amp. I used the Mag LED reflector and it's currently powered by AA NiMh's in C cell adaptors:
Next, the Palight XP-G R5 Cool White modded with the same Nanjg 1.4A driver:
Next is a KD C8 XM-L with LOP reflector (3A on High, "SG PCB" driver):
Next is my fake Solarforce L2 (P60) from Lightake with Lightake's XM-L drop-in (3A on high & SMO):
Next is my 2D size Maglite with DX's 52mm XM-L drop-in running on (2) 18650's (approx 1.65A on high). This is my backyard flooder:
Next is my Dongrui All-920 from Manafont running an XR-E Q5 (1.96A+). My favorite thrower:
(See what I've been meaning by large hotspot thrower with very useable spill?)
Next is my Super Tactics Q5 thrower (+/- 1.6A):
(You can barely see that the hotspot is smaller than the Dongrui's. Also, this one is more of a true cool white, while the Dongrui shows a little purple.)
Next I decided to backup another 100 110 feet. So in these shots I'll estimate the distance to that shed as 250 to 300' 294 feet. Distance to the light pole is about 60' 81 feet; to the wooden fence post just to the left of the pole is about 120' 126 feet (this is the fencepost I had the first shots taken from). (EDIT 4/19/2013 - finally measured these distances).
Mag 3C:
KD C8:
Mag 2D XM-L:
Mouse overs:
Mag 3C Neutral XP-G (mouse out) and Palight cool white XP-G (mouse over):
KD C8 (mouse out) and Fake L2 (Mouse over):
Dongrui (mouse out) and Super Tactics (mouse over):
There you have it. Seems my KD C8 doesn't have that bad of a tint. I'm surprised by how it leans toward neutral (just slightly). I also see that the KD C8 does in fact throw better than the Fake L2. While using the lights I thought the beams looked nearly identical. I did take some photos of my Ultrafire sipik SK68 clone on NiMh & 14500 both flood and zoom but decided to leave them out. For some reason there isn't much difference in output between NiMh and the 14500 (I can barely tell a difference). I also took photos of the Mag 3C on med and low, but will save them for my future build thread.
It's late here, I'm going to bed!
-Garry
