New 105D. replacing Nanjg-105c @ FT? (no stars!)
132 posts / 0 new
wight
Last seen: 11 months 2 weeks ago
I just got in an order from FT which included this item:
8* AMC7135 2-Group 2~5 Modes LED Flashlight Driver
Instead this is what I received:
The top side looks nearly identical to the QLite and older Nanjg-105c I’ve got here. The silkscreen is not exactly the same as the older drivers. Other layers (copper, stop mask) may be the same, I don’t know. They are definitely close.
I don’t know if it’s ‘official’ or a knockoff, but this layout should improve clearances on some lights with retaining rings. It just happens to completely eliminate the stars at the same time. Wink
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
MRsDNF
MRsDNF's picture
Last seen: 2 months 4 days ago
I have used these and they work as described. I'd like to see them with medium at 30 % of high and low a little lower as low is bright and medium brightness to close to high for me.
wight
Do you know where you got them?
MRsDNF
MRsDNF's picture
FT from memory. I have one in my bedside light and low is not that low.
wight
Thanks, just somewhat curious about these, their provenance, and whether they are intended to replace the 105c or whether FT just made a mistake when placing the order.
I won’t be leaving the stock program on it, so the stock Low doesn’t bother me. Wink
MRsDNF
MRsDNF's picture
I'll send my left over ones to you tonight to reprogram. Thanks in advance.Smile
wight
No problem. Don’t forget that the exchange rate between AUS drivers and US drivers is around 2:1.
hank
hank's picture
Last seen: 2 days 13 hours ago
I think I finally figured that out — looking at the night sky brightness maps worldwide.
Anyone both living and workiing in a big city — US or China — who doesn’t spend time camping just never sees a dark night.
No wonder they don’t understand the need for low levels from flashlights.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 8 months 4 weeks ago
Interesting…thanks!
Mike C
Mike C's picture
It won’t be a favorite of mine. The stars are good solder points, for example for off time cap and additional PWM output.
I have a couple of those in your link on order from FastTech and won’t be happy if I get these new drivers instead.
dnkyblf
Last seen: 2 days 4 hours ago
Agree.. I use the stars for eSwitch and 2nd PWM for FET (in a hybrid FET+7135s Nanjg driver), especially during developing the firmware (this leaves the MCU pins free for the soic test clip). When the driver is being deployed/installed, depends on which side of the driver board I want the wires to be connected to, sometimes I just soldered them directly to the MCU pins.
AlexTG
Last seen: 2 days 11 hours ago
wight, can you please make a macro pics for both sides of this driver?
DavidEF
DavidEF's picture
Last seen: 3 days 9 hours ago
I just did a Google search for Nanjg 105d drivers and couldn’t find any. So, I went to the FT website and used their search to find it. It doesn’t exist. All of their 105’s are listed as 105c. Is this 105d an actual thing or did someone make this custom and slip it in on us? I’d like to know if it can be bought (on purpose) anywhere, and whether the price is cheaper or if it’s just that it’s easier to use these with retaining rings like wight said.
- The YKK Philosophy
Werner
Werner's picture
Exactly what I thought. I also have some on order…
wight
I can take better pictures, but is there a reason to? This one is already detailed. The other side looks just like a 105c, I will post a picture of that if it’s somehow helpful. What, specifically, do you need?
IMO you should not expect to find a cheaper 8×7135+ATtiny13A driver than the ones on FT, at least in the quantity you are talking about. I think it’s fair to assume that the cost to manufacture this 105D. driver is not significantly different from the cost to manufacture a 105c. My assumption is that FT had the option to order a driver with “improved fitment” and took it without realizing the downside.
AlexTG
For me – yes. Would appreciate it a lot ^^
I sometimes do quite heavy modifications to the 105C, with lots of trace cutting and rearranging, so I’d like to know if I can do all this to 105D.
Good pics of both sides, perpendicular to the PCB plane. Something similar to the original FT driver pics from their product page. IC markings, traces, all that stuff.
wight
IC markings are the same. I checked. I did not check resistor values or the Vf of the diode.
I will strip one soon, how about I just take pictures of the bare PCB after it’s stripped?
AlexTG
Suits me perfectly, thanks!
freeme
freeme's picture
Last seen: 1 hour 15 min ago
105D Innocent Hopefully it is good. I just stocked up 5 pieces last week.
Unfortunately they never update it with 4 modes like Qlite.
DavidEF
DavidEF's picture
That’s what I thought, but I still wonder if this is something that will be sold on its own merits (sold as Nanjg 105d) or if it is just being slipped in to the place of the 105c.
wight
Good question, I wonder the same thing.
tryps
Crap, just noticed I got the same ones last week. I wanted to use the stars for OTCs… propobly gonna strip them for parts now.
Didn’t even notice that time, I’ve ordered them on 11.11. (105c 2 Group 2,8A)
Edit: My Convoy M2 I got today from FT has the same driver inside. I’d realy like to get my solder points back where they belong.
AlexTG
Created a ticket at FT, maybe they’ll sort it out.
Simon should know about these drivers then.
tryps
FYI, have manged to get a 5$ gift card (had 5 pcs).
Okay for me so far, didn’t want to spend any more time on this.
Don’t know what I’ll use the drives for, except it will most likely be in a flashlight.
convoy-flashlight
Last seen: 5 years 7 months ago
my aliexpress store:
http://www.aliexpress.com/store/330416
skype: simon.maomao
AlexTG
Thanks for the info, Simon!
Is it 2-group (3/5 modes), like before?
convoy-flashlight
AlexTG wrote:
Thanks for the info, Simon! Is it 2-group (3/5 modes), like before?
yes ,the stars is useless ,so i removed them
and of course i also have four groups version (with stars)
skype: simon.maomao
DavidEF
DavidEF's picture
So, the 105d is YOUR design? Are they for sale anywhere alone?
Chloe
Chloe's picture
Last seen: 4 years 7 months ago
!http://kfdown.a.aliimg.com/kf/HTB1HQiSGVXXXXaqXVXXq6xXFXXXu/121130677/HT...!
Nice! Though I do prefer the old way of soldering star than the updated 2 group version. The way it flashes once on low in three mode, always distracting.
wight
I agree. I strongly dislike the blink/flash – it is startling.
convoy-flashlight
and i have old 7135 verison ,
i also have LD25 with hidden strobe .
i think LD25 is better,no pwm
skype: simon.maomao
