BLF Designed Budget Thrower GB Question
253 posts / 0 new
Roberrt777
I have been wanting a GB for a Thrower. It seems the magic number for GBs is $20.00 to $30.00 how much can you exect this GB to be?
chuckhov
Last seen: 3 years 10 months ago
@DavidEF,
Actually I Was being serious.
Who more knowledgeable than you, a Man that understands the parameters ahead of time, and (with permission) the driver all sorted out beforehand?
There is Always a way to make more time (is a divorce all that bad?) – Just less of this and less of that in your life, but just think about all of the praise you will receive from the BLF community! – WE are Many, and will support you all the way! – That should be what’s really important to you. – Helping Others.
Hey! – We Love You Man!
I’m Totally Convinced that… You Are Da Man for This!
Just Roll with it man… Smile
-Chuck
Smile
2 DOGS
Last seen: 3 years 2 months ago
I don’t remember if anyone else has suggested being able to lego X6 or A6 bodies and extensions but it might be nice. Smile
Rufusbduck
Rufusbduck's picture
Quote:
Before I buy one, I thought I might ask if it would be possible for BLF to again work magic and develop a light with our specs, driver, etc and create a budget big head thrower? If so, I would totally wait while something like that was developed.
BLF is you. Start a thread and make it happen.
Scott
M4D M4X
M4D M4X's picture
Last seen: 10 months 2 weeks ago
that would sell on a T-shirt….
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
DavidEF
DavidEF's picture
…on the back of the TK BLF A6-SE UI diagram t-shirt! Wink
- The YKK Philosophy
vēer
vēer's picture
Last seen: 6 months 4 weeks ago
Hmm, spectacular thrower light made to BLF desired specs sounds great!
bugsy36
bugsy36's picture
Last seen: 10 months 3 weeks ago
DavidEF wrote:
M4D M4X wrote:
that would sell on a T-shirt....
...on the _back_ of the TK BLF A6-SE UI diagram t-shirt! ;)
Good idea!! I will tell Neal. He has some ideas too Smile
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
bugsy36
bugsy36's picture
Very true about the "sweet spot"...buy many and give them away knowing that they cannot be had elsewhere Smile
I do not know anything about where this would go BUT...
  • Triples....3 expensive emitters on a board with optics alone is going to run about $40....without the host.
  • Host prototyping is where the money really goes. $600-1000 without even thinking. Do it a few times and we could spend thousands on prototypes. That gets added
  • The list goes on
Not trying to discourage anybody and open dialog is good but bigger-headed lights get expensive quickly. If you know what driver...then look for a ready host. Fastest, cheapest, easiest way.
chuckhov
“Triples….3 expensive emitters on a board with optics alone is going to run about $40….without the host.”
Well, there’s one thing that we don’t have to worry about – A Triple is Not what I would call a Thrower.
There has got to be a good host out there somewhere that we could use as a base… I keep thinking Courui D01, but will they play ball?
http://budgetlightforum.com/node/40255
Thanks,
-Chuck
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 42 min ago
Here is a triple that throw’s and Floods!…………………………………………………………………………………………….Fenix Tk75vn XML2 PDT KT burn in edition
Sony vtc5
3184@ turn on
3158@ 30 sec
1598 high
611 mid
17 low
Throw – 341,000 Lux http://www.candlepowerforums.com/vb/showthread.php?387655-Jmpaul320-OTF-Lumen-Sphere-Readings-amp-throw-measurements!
KB1428 “Live Life WOT
chuckhov
Yes Sir!
But, Throwers that also Flood make it awful hard to see down range, with the high foreground brightness blasting me in the face.
Thanks!
-Chuck
Jubeldum
Jubeldum's picture
Last seen: 6 years 3 months ago
Thanks,
-Chuck
Excuse me?
Triple XHP 70 using the LUM 5-90 reflectors and a huge head – 05/06/15 Finished- with beam shots.
cajampa
Last seen: 6 years 2 days ago
DavidEF wrote:
thijsco19 wrote:
JasonJ wrote:
^ +1 on Every David just said.
I already planned on a D01 anyhow.. if I can pay a wee bit more and get a much improved light pre-modded to BLF preferences, all the better!
+2 :bigsmile:
Oh yeah, just remembered – the Courui D01 needs a better thermal path from the emitter. The thin pill/plate that is used in the stock light is not going to work for a hot-rod mod! Some guys have already in the past made and sold replacement pills for this light, so we at least know what we need already. Wink
So, if we’re in agreement about the BLF Courui D01-SE group buy, who’s gonna be the one to get it going? 8)
The better pill isn’t needed for only 4-6A that a XP-G2 S4, XP-L HI or a XM-L2 U4 would pull. Just because a better pill has been sold doesn’t mean it is absolutely necessary.
The better pill give less heat sag & is needed for emitters with higher amp pull, like that old high amp round one with high CRI, that i can’t remember the name of right now sorry.
I hope a BLF Courui D01-SE with the big kaidomain reflector could be made, with crazy performance like that i am pretty sure a lot of people would be ready to pay much more than the old sweet spot of $20-$30.
If we could get that with a FET driver or even cheaper just running DD, it would beat almost anything out there in throw.
chuckhov
Yeah – But, that’s not a Thrower, that’s a BLASTER! – It Throws simply by using brute force.
Can you imagine how bright the foreground would be in your face with that Monster?
Try using that thing in most locals, and the Cops will be called:-)
Hey! – Justin is The Man, that’s just not my idea of a Thrower.
Please understand that I do understand that a Triple can Throw, it’s just if it does, you have to have the very high foreground along with it:-( … I already have more of that than I need with my lowly Acebeam K40M – If we can’t get a GB going, I think that I’m going to be talking to Vinh about one of his Acebeam K40L with Genuine XP-L HI. – That’s the same concept as the proposed BLF-SE Courui D01, but at MUCH greater cost.
Maybe Justin will make us some custom Courui Pills?
Thanks all the same,
-Chuck
cajampa
Big Smile a cop calling light……that could have its uses, that would kind of be like a reverse bat signal Wink
I hope I one day actually build a light so bright that cops are called :bigsmile:
The best i have done so far is just piss off some neighbors Big Smile
KawiBoy1428
Not budget at all :_( , but wow xpg2-s2! Shocked Super Duper thrower! 8) http://www.candlepowerforums.com/vb/showthread.php?404463-TM36vnM-Limite...
DavidEF
DavidEF's picture
cajampa wrote:
DavidEF wrote:
+2 :bigsmile:
Well, it has been a while since I had mine open, but IIRC, the pill is thin, like around 1/4” and the threads are not very tight. I don’t know how much current the existing pill can or cannot take, but it doesn’t impress me much. I’d want at least a thicker piece of metal with better threading just as a matter of build quality.
thijsco19
Last seen: 1 day 5 hours ago
Any updateds on this subject? Silly :bigsmile:
zelee
zelee's picture
Last seen: 1 week 5 days ago
Definitely subscribe.
Can’t wait for update of batman call sign light
ohaya
Last seen: 6 months 1 week ago
djozz wrote:
What really would be nice is a BLF version of the Jacob A60 that is discontinued but still very much in demand, wthout the drawbacks:
-50+ mm aluminium reflector
-single  18650
-XP-L Hi or dedomed XP-G2
-standard body, such as the X6 or A6, with thrower head
-FET driver, (and why not the BLF A6 driver)
I’m late to this thread, probably because I’m not much into throwers lately, but I’m with you, and especially for the idea of a small light that is very bright and throws huge. That would be more “special” than a huge light that throws well IMO.
The Jacob A60 has a nice structural design also with the “light engine” section, so it might make a good base for something like that.
Nicolaas
Last seen: 2 years 5 months ago
My vote goes to a single 18650/26650 or even a single 18350 dedicated thrower.
For a 18650/26650 light the A60 seems ok, although the golden rule with throwers is “the larger the reflector the better the throw”. The A60 head diameter is 55mm, so the reflector itself will be 50mm at best.
Alternatives: Maxtoch M12. Not cheap, but high quality. Mine does with dedomed XM L2 and LD1 driver around 235Kcd.
If and only IF the reflector works well with a dedomed XP G2, this light could reach as much as 375Kcd.
Alternatives: the light shown previously in this thread – single 18650 from Ali Express. Again, depending on reflector diameter and how well it works with a dedomed XP G2. Provided the heat transfer is or can be easily made adequate.
Just a “warning” from my own experiences: the reflector size is no guarantee: the reflector has to be able to work well with the dedomed led you will be using.
In my BTU STR1 (yes the fugly light with all those cooling fins) a perfectly centrered dedomed XP G2 and a LD2 driver could not get it above 340Kcd. The spot was still too big, almost as big as with a dedomed XM L2.
On the other hand, my Courui D01 “Big Head” (LD2, 5A) does 361Kcd with dedomed XM L2 and fully charged Efest IMR2500 purple.
That light has a bigger reflector, but not that much bigger and the spots are same size.
If this reflector works well with a dedomed XP G2 (and from other posts in this forum I do believe it does Smile it could potentially reach as much as 550-600Kcd. With a tiny, tiny hotspot, that is.
Grtz
Nico
MTAmanda
MTAmanda's picture
Last seen: 1 year 3 weeks ago
MAXTOCH Dedomed 2X, 1000Meters Thrower, 280Klux, let me know if there’s any interest in it. Beer
chuckhov
Only if it begins life “Domeless” with a XP-L HI.
I really prefer a more “normal” tint – Not Green.
Thanks,
-Chuck
MTAmanda
MTAmanda's picture
It’s dedomed U2. I think it’s tint is quite normal then…
G0OSE
G0OSE's picture
Subscribed, +1 for courui Wink
djozz
djozz's picture
Last seen: 4 days 12 hours ago
A Maxtoch flashlight would be a great quality light, worthy of a BLF-version, but I'm not sure if it would be really budged, I think the idea would be under $25 or $30 the most.
Mitko
Mitko's picture
Last seen: 1 year 6 months ago
-single  18650
I knew you have a hunting potential m8! I knew it
Mitko
Mitko's picture
Yes we know its an OK flashlight, but its problem is that its too heavy for 227 and 223/ even 3006 caliber based rifles..not everybody lives in Australia, and not everybody has a guy to carry his backpack/10kg rifle while hunting :bigsmile:
crnkin
Last seen: 6 years 1 month ago
Fandyfire stl-v6 is available around the $25-$30 mark.
Simply changing the design of the body and head, using high quality components and a modern emitter should net somewhere around 250-300k lux.
Could probably get a group buy done for around the $30 mark I’d say.
Chris
