What did you mod today?
10478 posts / 0 new
Geuzzz
Geuzzz's picture
Last seen: 8 min 3 sec ago
zak.wilson wrote:
Dedome a 5000K 219C. You end up with about 4000K, lots of throw and nicer tint than most dedomed Crees.
I have some 4000k’s laying around. Guess I’ll try to dedome those first.
Is slicing the dome still the way to go? Or is there a new proofed method for 219c’s?
giorgoskok
giorgoskok's picture
Last seen: 4 days 15 hours ago
Maglite 2AA – Triple mini mag mod
Bored out the head using a 19,5mm drill :
Modded a threaded copper pill from Rey Ti , added a 16mm round copper plate to make the flat surface on top , all using only hand tools , and installed a fet driver and nichia 219b hi cri leds on KD board and optics :
Added some solder on the bottom , now even flat top batteries work :
And inside the head :
About the tube , i shortened it using the human lathe method kyfishguy described :
It could be better of course Smile .
Changed tailcap’s spring to a bigger and more flexible one :
Khaki painting was in pretty bad shaped , so i removed it from the areas without knurling .
And final product :
Thanks to kyfishguy for helping me , and Lexel for providing the light .
djozz
djozz's picture
Last seen: 9 hours 5 min ago
I guess that modding Maglites will never cease, it is sort of tradition on BLF to do them. I will do mine one day!
Nice mod, giorgoskok!
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 22 hours ago
Buying an led conversion for a 2AA mag was the first mod I ever did. That’s where it started for me Big Smile nice mod giorgoskok
giorgoskok
Thanks for your kind words Smile It wasn’t an easy mod since i have no lathe , but worth every minute . Love
kyfishguy
kyfishguy's picture
Last seen: 9 months 4 weeks ago
Hey George,
It’s great to see you’ve finally completed your triple micro mag. It looks great and I bet it puts out a pretty wall of light! That seam on the battery tube actually looks pretty good, did it take much adjusting to function smoothly or was it one of those rare ones that goes back together great on the first try?
Brian
giorgoskok
kyfishguy wrote:
Hey George, It’s great to see you’ve finally completed your triple micro mag. It looks great and I bet it puts out a pretty wall of light! That seam on the battery tube actually looks pretty good, did it take much adjusting to function smoothly or was it one of those rare ones that goes back together great on the first try?
Brian
Thanks Brian .
The battery tube came pretty good , i was modifying it and testing it back again for 2-3 times until i get a good fit , without creating much resistance .
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Love the mod George and good to see Justins traditions being carried on. I’ve said this before and will more than likely say it again, The AA Maglite would have to be one of the best looking lights on the market.
NeutralFan
NeutralFan's picture
Last seen: 4 hours 46 min ago
Very nice giorgoskok! I like the way it turned out. Was it hard to bore out the head?
I’d rather use my flashlight around the house than turn on the lights.
giorgoskok
Thanks guys! It was the easiest part for me , making the pill was the challenge !
djburkes
djburkes's picture
Last seen: 3 years 8 months ago
I modded a ThorFire TG06S…Nichia 219C and a fet+1 w/ bistro. The mcpcb was around 15.2mm…all I had was a 20mm so I sanded it down to fit. There was no need to sand the 17mm driver as it fit perfectly. I also drilled a hole in the switch and ran a wire from the spring to the switch leg. I added a little resistance by using 24awg wire so I don’t end up smoking the led. ThorFire did good by going with a reverse clicky in the TG06S instead of a forward clicky like the previous model. Here’s a couple of pics…
Modded TG06S left…stock TG06S right
No PWM from fet…lots of PWM from stock driver
Rufusbduck
Rufusbduck's picture
Last seen: 5 months 1 day ago
To bore a Minimag I start with a step drill to keep it well centered then finish with a hole saw to get a flat bottom shelf. The rough cut from that is then reamed with a sandpaper wrapped bit. The head is first wrapped in tape then pressed into a 1“hole in a 1 × 4 wood block clamped to the bench press table.
Scott
Mike C
Mike C's picture
Last seen: 1 day 16 hours ago
I don’t have much use for throwers but it is time to do something with my L4 hosts that I’ve had for ages so I made a Convoy L4 driver based on my ATtiny841 design with 14 × 7135s where any number of them can be turned on in constant current, and a single dedicated 7135 to PWM between the 350mA steps. I had a bunch of switches with the same footprint laying around and figured one of them would work:
The placement works fine (although not perfectly centered) but the feel of the switch isn’t very nice so it was a bit of a mistake to design the driver for this type of switch footprint. I should have gone with the classic momentary side switch type.
The firmware isn’t ready, but that doesn’t matter as I don’t have to take the driver out when flashing, I can just update as I go alone. Instead of attaching wires to a clip like for the 85 I use cut up paper clips:
I’ve color coded a picture with circles that match the color of the correct wire so it’s easy to see which wire goes in which via:
Perform the acupuncture and it’s ready for flashing:
I haven’t decided which LED to use yet. Throwers are generally not much use to me so I’m thinking I’ll just use up one of my older XM-L2s are collecting dust… or does this host deserve a XPL-HI?
ToyKeeper
ToyKeeper's picture
Last seen: 2 min 16 sec ago
It’ll certainly throw better with XP-L HI. You may need to adjust the reflector though, to change the depth of the focal point. A lot of reflectors are designed for emitters with domes, and need to be moved down a little to focus properly with a flat emitter.
Always a fun process, since the focus is sensitive to changes of even a tenth of a millimeter.
MRsDNF
MRsDNF's picture
Nice work Mike.
This is the first driver I’ve seen with this MCU. All the best for the firmware. Thumbs Up
Mike C
Mike C's picture
Oh no, sounds like way too much work for a light that I probably won’t use very much. Thanks for the warning! I think I’ll go with the XM-L2 option. I need to use up some of them anyway.
MRsDNF wrote:
Nice work Mike.
Thanks. I’ve updated my full range of drivers with this V6 design so all my lights will be getting an upgrade.
lostheplot
lostheplot's picture
Last seen: 6 months 3 weeks ago
EasyB wrote:
A teaser for a scratch-build I’m planning. It will be a 7x C8 reflector light with dedomed XPL emitters. 125mm diameter head. 2s 26650; the same electrical setup as my 7xXPL convoy L2. The drawing is actual size, with a convoy C8 for scale.
A drawing of the head, with my 7xXPL L2 for scale.
Should do around 9000 lumens OTF and 800+ Kcd. Made from “off the shelf” aluminum plate and tubing.
So how will you power / drive this ?????
Keep us posted
sorry all images down
thanks photobucket
raccoon city
raccoon city's picture
Last seen: 6 min 59 sec ago
Post #3000!
giorgoskok
100 pages of wonderful mods and tips from great members … Beer
EasyB
Last seen: 13 hours 38 min ago
Keep us posted
It will be 2s 26650, emitters will be (3p-4p), same setup as my previous mod. I’m in the process of fabricating and ordering parts for this new high output thrower. LOL
Rufusbduck
So true. The search feature is a good resource but the best index is the active members who remember what’s been done and where to find it or are willing to look.
A bit more work on a triple C8 using a kd 40mm reflector. I used the led centering discs to locate the stars in a pour of JB weld on a ziplock bag(doesn’t stick) then made up a thin brass buss bar. Then cut the ends off a perfectly good battery tube and sanded them down just past the tube stops.
Scott
MRsDNF
MRsDNF's picture
Very nice RBD.
This is going to be another masterpiece from you. Smile
Rufusbduck
I hope so. LOL If you look at the middle pic you can see a step in the ID of the left hand tube end. It’s there so that the tube can slip past the pill at the driver. Both ends get reamed to that larger ID to fit the brass sleeve that joins the two pieces electrically. Clearing the pill in this instance can be accomplished by backing the pill up into the head ~1mm(the copper spacer has a hollow partially filled by a 1/4” thick aluminum slug) or by the simple expedient of shortening the tube threads by the amount needed. I have a brass pill for this light as well that will get loaded as well so I haven’t decided which way to go or whether another option exists.
Scott
EasyB
The build is coming together. This will be the back of the head, with fabricated flange and tailcap, and 6 heatsinks. C8 for scale.
MRsDNF
MRsDNF's picture
How about your own thread for your build EasyB. It will make following your build easier and more interesting. Smile
EasyB
I plan to make a thread with a write-up and pictures when I finish the light.
MRsDNF
MRsDNF's picture
Thumbs Up Thanks.
1C3
Last seen: 3 weeks 8 hours ago
Hi everybody!
I’ve been lurking here for a while and I thought what best first post than one showing my modded lights Big Smile
So here they are:
On the top is a thrunite th20 which I emitter swapped to a sw57k 219b.
Left is a zebralight sc600fd, with a minus green filter on the lens to correct the greenish tint ( not cool having to do this on a $100 light Facepalm , but on the other hand I love everything else about it ).
Right is a jaxman m8 with a shaved dome sw40k 219b and the convoy biscotti driver.
Here are some beamshots ( 5000k wb, from top to bottom: th20, sc600, m8 )
Now these may be some fairly simple mods, but I have a feeling I will be doing increasingly complicated stuff as I fall deeper into the rabbit hole Silly
pinkpanda3310
Great first post 1C3 Thumbs Up
Welcome Smile
khas
Last seen: 1 week 2 days ago
Very nice first post Smile
Welcome to BLF 1C3
