[[ GXB20 Driver – Homemade Constant Current Programmable XHP50 Single-Cell Boost Driver! ]]
204 posts / 0 new
mattlward
mattlward's picture
Last seen: 8 hours 59 min ago
I would love to try one of these out as well. I am thinking 18650 powered mini C8 with an XHP50.2. After having build one XHP50.2 in 4000k for an old SupFire I have, I have really decided that I like this new led. I would be willing to build 1 to test if I had a programmed MCU and a shopping cart list.
Looks like good work to me!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
jack-bkk
great job
i am interested too
Lexel
Lexel's picture
Last seen: 10 months 2 weeks ago
Building this on 17mm size would probably need a sandwitch of 2 PCBs to fit all components
On the other hand you could try to bore the C8 to 20mm and use a spacer to the shelf, no retaining ring just the driver between spacer and tube
Lowtech
Last seen: 10 months 3 days ago
Is that something you would sell or is it for personal use only?
Realy like the output of my ee x7 xhp50.2
But the driver is….not great.
Would love to put one in a m2 or similar host.
loneoceans
loneoceans's picture
DB Custom wrote:
Thank you for bringing this little experiment of yours to BLF. I am also one that is very interested in trying one, whether building it myself with your flashed MCU or a complete driver. Might would have to build a whole new flashlight from scratch just to honor your work on this ! :)
Thanks for your kind words! I’m currently working on a write-up on this project and releasing all open-source as well as offering the boards on oshpark so everyone can build one for themselves. I do have extra boards and I can offer firmware-flashed boards with MCU at a later time, but I really will not have time to offer built drivers. I do understand it’s a bit tricky to put together and I highly recommend either a micro-soldering station with magnification for hand-assembly, or even better if you have solder paste (can apply using a needle) and reflow with an oven or hot-air. Updates will be on this thread.
JasonWW wrote:
How sweet would it be if cree decided to offer the xhp70.2 with a 3 volt option? All 4 dies would be parallel. Just dreaming out loud. Lol
I’m not quite sure if it makes sense from an electrical point of view, since there’s really not much use case for it except in flashlights (which makes up a very small % of their sales), and that it’s not electrically efficient since resistive losses go up by the square of the current.
Lexel wrote:
Building this on 17mm size would probably need a sandwitch of 2 PCBs to fit all components On the other hand you could try to bore the C8 to 20mm and use a spacer to the shelf, no retaining ring just the driver between spacer and tube
I’m 100% sure I can fit it all onto a 17mm driver with no less functionality and with a single PCB. Just need to find some time to do it!
Lowtech wrote:
Is that something you would sell or is it for personal use only? Realy like the output of my ee x7 xhp50.2 But the driver is....not great. Would love to put one in a m2 or similar host.
It takes a while to assemble this together by hand only because it’s fairly small. So I don’t really have any plans to offer these for sale as whole drivers, unless I have some help in getting this mass-produced! Otherwise I’ll be releasing more open-source so anyone can buy the PCBs themselves on OSHpark or similar and assemble it smile
www.loneoceans.com/labs/
- Next-gen Switching Drivers: Lume X1 and Lume1
- High Power Boost Drivers: GXB100 GAN 100W, GXB172 17mm 50W
- Older: GXF22, GFS16, GXB17 & GXB20
Tom E
Tom E's picture
Last seen: 6 hours 34 min ago
I'm seconding Dale's post, wow!
Very much interested in building a couple of these. Also very interested in the "New 0.4mm pitch micro programming header for ATtiny84A" you mentioned, and how to utilize it. I would like to be able to make "tweaks". I'm sure real estate is tight, but if you haven't yet, if you can add 1 to 3 pads for spare I/O pins, much appreciated. Indicator LED's is one thing I'm thinking of or possible dual e-switch support.
I'd also love to see those pics of the board blown up a bit.
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
What Dale and Tom said. Wow. Thanks for sharing the project with us and who knows, maybe I’ll build one that works. Smile
Lowtech
Quote:
It takes a while to assemble this together by hand only because it’s fairly small. So I don’t really have any plans to offer these for sale as whole drivers, unless I have some help in getting this mass-produced! Otherwise I’ll be releasing open-source so anyone can buy the PCBs themselves on OSHpark
Totalt understand that.
To me it would probably be morr of a pain to find all the correct components than the accual soldering.
I think if the 17mm works it would be a huge demand as there is nothing like it and lots of people want to get away from a 2×18350 setup.
Schoki
Schoki's picture
Last seen: 3 weeks 5 days ago
I managed to get all the components on a 17mm board, I used a different digital potentiometer, so I had to change the connections to the ATTiny.
One more thing: In this design you need one wire across the board on the top side, so it’s usable, but not great…
Much more work needed for this design…
JasonWW
JasonWW's picture
Last seen: 6 hours 10 min ago
Would anyone buy these over the H1-A which is also 20mm?
If you could get a better firmware for your driver (with off time memory, etc…) then that would surely give it an advantage.
Squeezing it down to 17mm would be another big advantage for those that already use hosts with that size.
Otherwise, new builds can be done with hosts that take 20mm drivers.
DavidEF
DavidEF's picture
Last seen: 2 days 23 hours ago
!{width:20%}http://i1320.photobucket.com/albums/u524/Schoki123/xhp_17mm_small_zpspjp...!
Could you eliminate the air wire by using four-layer boards and running traces in the middle layers?
- The YKK Philosophy
Schoki
Schoki's picture
Sure that’s possible with blind vias and buried vias, but I’m stuck with 2-Layer designs on my software.
I think it’s even possible with 2-Layer and without an air wire, but that takes a lot of time, just positioning all the components.
Rufusbduck
Rufusbduck's picture
Last seen: 5 months 5 days ago
Does Oshpark even do 4-layer? I think you’d need a larger minimum order from Seeed studio or someone else to get them. This is where I was thinking some of the miller’s donation/developement money should go if we want a boost design to get from open source to production.
Scott
DavidEF
DavidEF's picture
Yeah, OSHPark does 4-layer. Richard made one of his MTN-MAX buck drivers in 4-layer. I don’t know if he still sells that one. But, he was getting them from OSHPark. The price is a bit higher and the lead time is longer compared to the regular 2-layer boards.
Mike C
Mike C's picture
Last seen: 5 days 20 hours ago
OSH Park does four layer boards. They don’t support buried or blind vias though. The lead time is shorter than the two layer boards with extra copper thickness, and not noticeably longer than regular two layer boards.
DavidEF
DavidEF's picture
Oh yeah, I forgot that they don’t do blind vias. But, even if you have to do a via all the way through the board, that still takes up less space on the top and bottom than a complete trace. The vias can be made small and placed under components or in some other out-of-the-way place. Still, if the layout can be made to fit onto a regular two-layer board with a 17mm diameter and no air-wires, that would be better.
Rufusbduck
Cool, great way to add copper
Scott
clemence
clemence's picture
Last seen: 1 year 6 days ago
Very nice indeed. I just saw this thread after finished reading your PM. I’ve been looking for a compact 20mm buck boost driver for some of my projects too (non flashlight). Sweet, now we have a good programmable driver for those 144AM.
- Clemence
Schoki
Schoki's picture
Mike C asked me to share the libraries I used in EAGLE to design my first attempt of the 17mm board,
so here are the devices I created myself: My Library
If you need the ATTiny84a footprint as well, I suggest downloading the Sparkfun library here: Sparkfun Library
If you want me to design the MAX5424 as well, just ask for it
Mike C
Mike C's picture
Thanks for sharing Schoki!
loneoceans: When you have made these boards, have you used stencils or applied solder paste by hand? I have had a few shorts on MCU pins when using default MCU footprint for my 841 when applying by hand. The default mask pad size is bigger than the actual pin and overlapped with the other pins. I made it better by customizing the footprint so the mask pad size is exactly the same is pin pad size. However, I’m now using stencils I made with an even smaller cream pad size for the pins.
Schoki
Schoki's picture
I think he soldered it by hand, pre tinning the pads and then reheating them holding the parts with tweezers
finges
Last seen: 3 days 5 min ago
Looking good! The 20mm version would be perfect to put into a Convoy L2 with short battery tube.
loneoceans
DavidEF wrote:
Oh yeah, I forgot that they don't do blind vias. But, even if you have to do a via all the way through the board, that still takes up less space on the top and bottom than a complete trace. The vias can be made small and placed under components or in some other out-of-the-way place. Still, if the layout can be made to fit onto a regular two-layer board with a 17mm diameter and no air-wires, that would be better.
Laying out the board on 4 layers would certainly not only allow better performance but also allow better routing. However specifically avoided a 4 layer stack to keep the PCB costs as low as possible. Adding blind or buried vias significantly increases cost so I usually try to avoid them as much as possible. I'll explore a little with the 17mm version when I have time though it looks to me that there should be no problems making a 2-layer 17mm version.
Mike C wrote:
Thanks for sharing Schoki! loneoceans: When you have made these boards, have you used stencils or applied solder paste by hand? I have had a few shorts on MCU pins when using default MCU footprint for my 841 when applying by hand. The default mask pad size is bigger than the actual pin and overlapped with the other pins. I made it better by customizing the footprint so the mask pad size is exactly the same is pin pad size. However, I'm now using stencils I made with an even smaller cream pad size for the pins.
I didn't bother fabricating a stencil for this since I was expecting to only make a very small number of boards, so I soldered them all by hand with a combination of reflow and solder paste applied by hand using a toothpick (typically I don't get any bridges if the right amount of paste is used, or I fix it using solderwick), and solder the rest by hand under magnification with a tiny tip soldering iron. Like you mentioned soldermask expansion needs to be adjusted. I think I used 1 or 2mil expansion, depending on the fab I go with.
Evgeniy
Last seen: 1 week 4 days ago
“Improved lowest level of CC brightness (just around 1mA – true ‘firefly’ mode) Modes for my own firmware: 1 = firefly <1mA, 2 = low ~180mA, 3 = mid ~600mA, 4 = ~1.8A (~1000 lumens), 5 = 3A (turbo)
Measured efficiency of 92% at 3A (~6.5V) output”
Can this driver correctly work with triple LEDs, 8-9V ?
Flashlights : custom (Jaxman E2L with led4power LD-4 drivers and 3xOsram CQAR.CC), custom Skillhunt H03 with Osram 3К/4К, Zebralight {H600fc IV, Sc600fc IV, H600fc III}, Jaxman E2(N219b), Convoy UV.
Previous: Zebralight {H501, H600W, H600W II, H602W}, NiteCore TIPCRI, A A01, Fenix L2D CE/CEQ5.
Evgeniy
Xoden wrote:
Nice! I wonder if it’s possible to get a smaller design with lower power. Like 17mm 9V/1A for 219C triple.
17mm 9V/1A for 219C triple will be very interesting driver.
(and <=5mm height, for E2L host)
loneoceans
Evgeniy wrote:
"Improved lowest level of CC brightness (just around 1mA - true 'firefly' mode) Modes for my own firmware: 1 = firefly <1mA, 2 = low ~180mA, 3 = mid ~600mA, 4 = ~1.8A (~1000 lumens), 5 = 3A (turbo) Measured efficiency of 92% at 3A (~6.5V) output" Can this driver correctly work with triple LEDs, 8-9V ?
Yes it will work just fine with some small adjustments (e.g. to make sure it doesn't try to drive 9V at 3A, adjust components to make it more efficient st the desired drive currents etc).
Evgeniy
3A - huge overload for N219C (with serial connection), ~1-1.3A current in (turbo) mode will be nice.
Wanted 17mm (and 5mm height) driver .
fine modes may be, for example :
1 = firefly 1mA,
2 = low ~30-40mA,
3 = mid ~100-130mA,
4 = high ~400mA,
5 = turbo ~1-1.3A
Texas_Ace
Texas_Ace's picture
Last seen: 10 hours 14 min ago
Evgeniy wrote:
loneoceans wrote:
Yes it will work just fine with some small adjustments (e.g. to make sure it doesn’t try to drive 9V at 3A, adjust components to make it more efficient st the desired drive currents etc).
3A – huge overload for N219C (with serial connection), ~1-1.3A current in (turbo) mode will be nice.
1 = firefly 1mA,
2 = low ~30-40mA,
3 = mid ~100-130mA,
4 = high ~400mA,
5 = turbo ~1-1.3A
3A is a huge overload for the 219C???
I have run them up to 12A and they still worked fine. Check my sig for a test of them, they didn’t even reach peak lumens until ~6A. Although around 4-5A is ideal IMO.
Evgeniy
Texas_Ace wrote:
3A is a huge overload for the 219C??? I have run them up to 12A and they still worked fine. Check my sig for a test of them, they didn't even reach peak lumens until ~6A. Although around 4-5A is ideal IMO.
thanks, but I tell about triple of 219C with serial connection, for every-day usage (not about 1-time tests).
And, for serial connection, 3x219C & 1A will require 8-9W, for 3A it will be ~27Watts of power, and ~36-38W for 4A.
30-35W in small case - overheat in few seconds.
Texas_Ace
Texas_Ace's picture
Ok, so you are saying that 3A is too much for the host, not for the 219C LED’s themselves. That makes more sense.
