New WildTrail (former LuckSun) BLF-D80v2 Sale is open.
1257 posts / 0 new
AguassissiM
AguassissiM's picture
Last seen: 17 hours 1 min ago
@DBSAR
That`s awesome news. Beer
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
pipopopo
Code for d80v2 pls
hodor
hodor's picture
Last seen: 1 hour 1 min ago
Bit of a necro but thought this might be useful for someone.
Mode groups image courtesy of DB Custom (ignore the arrow). As mentioned already in this thread, default is mode group 12.
Below is info on how to interpret the groups (from TA’s driver thread ).
Texas_Ace wrote:
For reference :
Moon = optional in menu and not shown
ONE7135 = 8
ALL7135s = 14
Turbo = 20
Modes approx mA and lumen values for single XP-L LED
1 = 5.5ma = .5lm
3 = 19ma = 4lm
4 = 37mA = 12lm
5 = 66ma = 24lm
6 = 135ma = 60lm
8 (one7135) = 355ma = 150lm
Above this it will depend on how many 7135’s are installed
With 7× 7135
10 = 640mA
12 = 1A = ~335lm
14 (7× 7135) = 2.55A = ~830lm
Above this you are using the FET and it will vary wildly depending on the build.
16 = ALL7135s + 25% FET
18 = ALL7135s + 60% FET
Turbo = 100% FET
mrbill
Satan@103TFS wrote:
Dark brown is nice Thumbs Up
Is it possible to have a 21700 tube option ?
+1 to this. I don’t mind if the tube is a bit bigger – in fact, it would be preferable.
hodor
hodor's picture
Just wondered, for the no-ano folks, how did you get on with cleaning up / deburring the battery tube? Or did you just leave it alone?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 5 min ago
I polished mine with a rotary tool and some aluminium polish.
Tom E
Tom E's picture
Last seen: 2 hours 58 min ago
I know djozz posted his pic earlier, but this is the best look'n MCPCB I've ever seen. It's worth another take:
mrbill
If anyone is interested in an inexpensive holster or pouch for the D80v2: https://www.aliexpress.com/item/32490680742.html Works well - about an inch of space at the bottom, but does not detract from usefulness. The elastic keeps the light in place very well.
DBSAR
DBSAR's picture
Last seen: 3 days 17 hours ago
Congratulations Wildtrail BLF D80… you have been the first BLF light to RUIN, and destroy THREE, i repeat.. three ( 3) good 18650 cells, by draining them unexpectedly to 0.002 volts. This is the first BLF light i will throw in the trash. Angry Crying I have never been so disappointed in a custom light as this one.. I do not want this to b the last light to fail me at the end of my painful life.
Scallywag
Scallywag's picture
Last seen: 4 min 37 sec ago
That’s quite surprising! I assume this was while the light was left running?
If you’re up for it, I’d pay to ship it here for a driver swap (something with LVP, maybe) rather than let it see the trash. IMO the design is beautiful, but I never picked one up.
DBSAR
DBSAR's picture
Nope, it sat turned off, but drained 3 cells dead. i don’t know if it was a shorted switch or shorted driver, I had originally thought the first two cells i put in it was defective, but the third was the end of the line. This light was used as a back-up, but it killed 3 cells even with the tail cap left loose. its now sitting in this weeks trash bag to go. Done with it. Adios.
SKV89
Last seen: 3 days 15 hours ago
The D80 driver was designed by Lexel. Maybe ask Lexel
Scallywag
Scallywag's picture
If it was off, there’s something wrong with the switch. That should physically break the current path, regardless of what the driver’s doing.
djozz
djozz's picture
Last seen: 5 hours 37 min ago
Very weird stuff, it has a mechanical switch, the circuit is completely broken when switched off. It uses a common switch (I believe an Omten) used in many other lights. As far as I’m aware the BLF D80 is one of the best designed lights out there, mechanically everything is simple and well-proven. Only the user interface (modified biscotti by flintrock) was a gamble but appears to work very well.
My two D80V2 do not drain cells fwiw.
Could be a soldering defect (slight solder bridge) at the tail spring causing a tiny trickle current bypassing the switch, not enough to start up the MCU and cause a faint moonlight, but enough to drain cells?
DBSAR
DBSAR's picture
i thought originally the first cell was just defective and went dead, so i tried a second, ( and third) and killed them too the same, drained the voltage to near zero.
raccoon city
raccoon city's picture
Last seen: 6 hours 18 min ago
Wow, that's terrible, DBSAR!
(I hope your experience is an isolated incident.)
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 15 min 8 sec ago
Den, if you want I can inform Jacky (WildTrail/LuckySun) about this incident to see what he can do about it. Unfortunately, Sven („TheOnlyDocc“) has never shown up again since 09/2019 and all communication attempts to reach him were unsuccessful. So, I would try to help you in his stead.
Cheers,
Thomas
Sw1f7
Last seen: 1 month 3 days ago
Does the BLF-D80v2 have a forward or reverse switch?
How does its throw compare to a good C8 with SST40 5000k?
contactcr
Last seen: 1 hour 31 min ago
Sw1f7 wrote:
Does the BLF-D80v2 have a forward or reverse switch? How does its throw compare to a good C8 with SST40 5000k?
Reverse.
If by good C8 you mean a direct drive one like this light is then the C8 will have longer throw.
Sw1f7
Thanks
djozz
djozz's picture
contactcr wrote:
Reverse.
But this one is more compact and feels better. And this driver plus firmware is superb.
Sw1f7
Seems like a good choice of emitter too. Fantastic light, I need a forward clicky though with momentarily half press to last used ramp.
Would be great if these lights could be offered with a forward clicky option for people who need a tactical style light.
contactcr
Forward clicky makes it a few mm longer and IMO makes a lot of the modes more difficult to transition between. I don’t mind them on some lights though.
I see you said “ramp”, none of the lights with only one mechanical switch will “ramp”. However, there are dual switch lights that can work like you describe (Sofirn C8F). A bit bigger light though.
MtnDon
MtnDon's picture
Last seen: 2 hours 7 min ago
Depends. If a driver uses a attiny 13 and up MCU (best with attiny25 or higher) it could be flashed with Toykeepers Crescendo, which ramps. Reverse clicky mechanical switch is easiet to use.
contactcr
I should have known a senior member would mention this, lol. That is hardly a solution for 2 month member with forward switch request. BUT, yes technically correct. Silly
Sw1f7
Thanks for all the advice Smile
This is probably getting way off topic but…
Here is a link to a Convoy C8+ with ramping
Convoy C8 with ramping driver
Will this work with a forward switch?
I have a C8G and it works great (I realise that it has two switches as mentioned, just saying). Set the ramp and then just use the half press to access it. Fantastic for night patrols. Only gripe is the CW tint else it would have been perfect for me. Hence me looking at the BLF-D80v2 which seems like a awesome light. Another user suggested that I could swap the emitter of the C8G but I’ll rather look for a stock light that meets my needs before resorting to modding.
